01-24-2022, 11:38 AM | #1 |
Rep 172
What are people using for their M1/M2 preset settings?
I've got a few months to get ready for my car to arrive, might as well start considering this. I know that a few of the Youtubers have commented on their preferred settings, but would be interested to hear what settings folks are using and the reasoning. You can obviously go from full comfort to full racetrack, but guessing most folks have two settings in-between.
01-24-2022, 12:43 PM | #2 |
Occasionally frequent poster
3000
Rep 2,744
The car defaults to "full comfort" every time you start it, and honestly that's my default mode anyway because I'm old. So M1 is set for sport engine just to open up the exhaust valves, and M2 is set for track, with MDM on and suspension set to track or sport or whatever the stiffest setting is. I leave the steering and braking in comfort mode, because it's the best.
I never turn DSC totally off (unless I'm on the track) because there are just too many unknowns on the street.
Current inventory:
astroricardo882.00 BardG212.50 |
01-24-2022, 02:20 PM | #3 |
Rep 830
I drive the car basically always in sport+ mode…I define my M1/M2 setup like a dry and rain mode. M2 is everything on sharpest setting and M1 is just a small difference, where steering and brake is in comfort and dsc on
01-24-2022, 02:27 PM | #4 |
Rep 10,166
M1: S3, Sports Plus Engine, Sport Steering, Comfort Suspension, 4WD Sport
M2: S3, Sports Plus Engine, Sport Steering, Comfort Suspension, DSC OFF 4WD M2 is set up for Launch Control. I always press the M1 button or M2 button twice BEFORE I start the car so its all ready and LOUD.
01-24-2022, 02:29 PM | #5 |
Vault Dweller
704
Rep 577
Current (delivered 20/10/21): 2021 G80 M3 6MT; Dravit/KO/ZPP; 826M; Sunroof (yes no CF)
(More Pictures) Previous: 2018 340ix 6MT Msport(Dec 17-Sep 21); 2013 335ix 6MT Msport (Nov 13-17); 2011 328i 6MT ZSP (Aug 10-Nov 13); 07 323i 6MT ZSP (May 07-Aug 10); 97 318ti MT ZSP (Feb 97-May 07) |
01-24-2022, 03:19 PM | #7 | |
Rep 375
jocamero48.50 |
01-24-2022, 03:21 PM | #8 |
Rep 10,166
Yes, brake pressed but do not start the car, and the press your buttons (they way I have my stability set up it requires a double press) and then once you start the car it will be in M1 or M2 already.
01-24-2022, 03:44 PM | #9 | |
Vault Dweller
704
Rep 577
e.g. I have MDM on M2 so need to press M2 button twice to activate that setting.
jas1651446.50 RichardGM4521.00 |
01-24-2022, 05:24 PM | #10 |
Rep 8,030
Drives: 2024 X5 M60i
Here are mine.
01-24-2022, 06:07 PM | #11 |
Rep 585
I did not know this, now I know how to start my car in sport instead of efficient to have the valves open.
IG: Adaptiive_M
E46 M3 (Sold) E92 M3 2022 G82 M4C Xdrive |
01-24-2022, 10:10 PM | #12 |
Rep 56
M1: sport engine, sport chassis, D3, all else default
M2: sport+ engine, sport+ chassis, sport steering, sport brakes, S3, 4WD sport, DSC off (launch control) M1 is set up to mimic the "sport" setting on my 2018 M2, for a fun corner on a vacant public road or when passing on the highway. M2 is for when I did my first ever launch of any car ever on a deserted New Mexico highway ... jesus christ this car is fast. |
Arash6663.00 |
01-25-2022, 08:44 AM | #13 | |
Rep 482
01-25-2022, 09:29 AM | #14 | |
Rep 10,166
In reality, as shown in the exhaust section here, the valves still are not fully open unless under load.
01-25-2022, 10:53 AM | #15 | ||
Rep 482
01-28-2022, 09:19 PM | #16 |
Rep 14,115
Drives: G82 M4C X-Drive
M1:
Engine - Sport Transmission - D1 Chassis - Comfort Steering- Comfort Brake - Comfort Traction - DSC ON M2: Engine - Sport Plus Transmission - D3 Chassis - Sport Plus Steering- Comfort Brake - Sport Traction - MDM on the street, reprogrammed to DSC OFF for the track I have a question. On the F80 we were able to program which HUD displayed for each M mode. It looks like that's not longer possible, correct?
01-29-2022, 12:02 AM | #17 |
Rep 906
Drives: 2022 G80 Comp x-drive
Don’t have the car yet, but there are so many freaking acronyms…so take it easy on me.
For transmission settings: it seems there are two variables…S holds gears longer and downshifts more aggressively than D, and 3 shifts faster between gears than 1. So least aggressive gear holding/downshifting with smoothest shifts is d1, and longest gear holds and most aggressive downshift with fastest actual shifts regardless of smoothness is s3? I remember a thread a long time ago about someone figuring out the 1-3 part and finding a huge difference, just not sure how it all works together. Engine: changes responsiveness to throttle inputs only? Or does this have some interaction with how long gears held etc.? I am also confused between mdm and awd sport. I get the awd sport is more rear biased than regular awd setting. So what does mdm do (other than change 5pm dash display and heads up display)? Does mdm just control when limited-slip kicks in? So we get to choose: how much rwd bias the awd system has, and independent of that how quickly (if at all) the traction control the kicks in to prevent a slide? Also, the awd settings are only in idrive settings, while mdm is center console button? Chassis/steering are straightforward. Does the braking setting really change that much?
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335 |
The Nerd425.50 |
01-29-2022, 12:07 AM | #18 |
Rep 906
From what I gather from the coding discussions, the hud display is binary: regular or mdm. And based on the coding threads, it does not seem like anyone has been able to get the mdm hud independent of mdm being active. I do t have my car, but it seems the answer is: if you can link mdm to a M button, then yes, you can control it.
01-29-2022, 07:22 AM | #19 | |
Rep 3,291
Limegrntaln13440.50 |
01-29-2022, 07:35 AM | #20 |
Rep 6,953
M1: Engine in Sport+, shocks in Sport, brakes and steering both in sport.
M2: I have setup for launch control, and the settings are as follows.
YT: G Dubyou |
DavidXJ663.00 |
01-29-2022, 05:01 PM | #21 | |
Rep 906
Thanks for the clarification re:M mode and HUD as opposed to MDM.
BMWRacer5232519.00 |
01-29-2022, 10:04 PM | #22 |
Rep 247
Drives: '21 M3 base
Mine’s simple. Strictly for daily driving.
Always engine sport+, chassis comfort M1 - rev match on (for the morning commute before I’ve had my coffee) M2 - rev match off (rest of the time) |
drbachata30.00 |
