05-21-2021, 01:41 PM | #1 |
8960
Rep 7,589
What do you not like or think could be improved about your G8x?
Not a thread to bitch about the grilles, but what small or big things do you think could maybe be improved for future model years or LCI? Maybe BMW will read some from this thread for some ideas? Or perhaps some people might have work around for people's ideas/problems.
One of the things that annoys me is that the AC on off is now buried in the iDrive menu as opposed to being a button. Sometimes I just want 'fresh' air through the vents and sometimes I want cooled air and a simple button was handy for that as was in previous models. Sure, I can "Hey BMW, turn on the air conditioner" but for something like this a button would be much easier. There are also a few iDrive things that I'd like to program to buttons that it won't let me do. Also, I miss the 12v outlet in the passenger footwell and wish the center console 12v adaptor was in a little better place for plugging something like a radar detector in. As it's right in between and in front of the 2 cup holders a wire would be a bit in the way and unsightly.
05-21-2021, 01:47 PM | #2 |
Rep 53
The AC on/off being buried, as well as the sync temp between passenger and driver. Everytime a passenger changes the temp I have to go into the menu and check the sync button. edit/ If it's space they're trying to save, get rid of the shortcut buttons which never seem to work for anything anyway. /edit First world problems
Vintage377.50 My8thMandcounting117.00 |
05-21-2021, 01:50 PM | #3 |
Rep 297
For me i have 2 really small complaints. I am coming from a G30 5 Series Diesel, so that is my reference with which i compare my G80.
First complaint : The volume button has a delay. It does not respond instantly as in the G30. When i push it and turn on the radio there is a slight delay, and also when turning up the volume there is a small delay. This was not the case in my (I-drive 6) G30 5 Series Second Complaint : Delayed creep from automatic transmission when driving away : i think this is likely a Diesel vs Petrol thing. My 5 series was a Diesel with ZF 8 speed automatic. When driving away from a parking position all was needed is just releasing the brake pedal and it would instantly roll away. With the M3 competition there is a delay before the car starts rolling away. I think this has something to do with the higher RPM after engine start, which is something the Diesel cars do not have. I think therefore they can not just make it like a Diesel which rolls away instantly when releasing the brake pedal. But really these are very minor irritations in a otherwise brilliant car : the best car i have ever owned by far. By very far. |
05-21-2021, 02:00 PM | #4 | |
8960
Rep 7,589
05-21-2021, 02:34 PM | #5 |
Rep 3,247
iDrive 7 Voice Control. I realize that you have to "get to know" the weird spirit inhabiting your car, but it and I are not getting along as well the iDrive 6 spirit and I did. I'm working on it.
05-21-2021, 03:18 PM | #7 |
Rep 596
The A/C being buried infuriates me. It just seems completely bizarre that there's not a button for it. I turn the recirculated air on if I'm by a truck I think will spew smoke, which activates the AC, and then the only way to turn it off again is to go back into the menu, so it's a minimum 3 clicks to turn off
05-21-2021, 03:30 PM | #8 |
Rep 1,621
Only one 12V outlet. There should be at least one more either in the rear seating area or inside the armrest compartment. Same for USB-A connection.
Occasionally buggy Apple CarPlay integration. Sometimes, the connection between the car and phone is interrupted. Gesture control doesn't appear to work while wearing gloves. Comfort access "kick to open the trunk" feature was deleted. I'd like to mix M-Mode Sport HUD with Road mode Live Cockpit. Horn requires a bit too much force to trigger. A quick and friendly beep can be tricky. I'd like M tri-color stitching on my seatbelts (6MT car). Speed Limit Info seems less accurate than in previous cars. Google Maps/Waze directions should propagate to the main BMW navigation system and display directions in the HUD and Live Cockpit. Analog dials option in Live Cockpit. I'm actually satisfied with what's provided, but the setup is digital, so no reason to not have another gauge cluster skin. Option to color match gloss black lower body trim pieces. BMW M made a good decision making everything separate parts that are easily taken off, so I'm not as worried about how they'll wear (mine are already showing swirls, though). I think the car will look lower with an even more imposing street presence with all of the pieces painted. Digital Key for 6MT cars. While I understand that Remote Start doesn't make sense with a 3-pedal car, I should be able to use my iPhone to unlock the car if other models allow this. I'd like the Competition factory tune on the 6MT base car. I'd like an illuminated shift knob. All nitpicks. It's been a while since I've been this satisfied with a purchase. |
05-21-2021, 03:45 PM | #9 | |
Rep 664
2021 BMW M3 Comp
2021 BMW X3M 2018 BMW M3 - SO/SS ZCP - Gone 2017 BMW X5 40e M-Sport - Gone 2015 BMW M3 - Gone - ED Pickup June 2nd, 2015 |
05-21-2021, 03:47 PM | #10 | |
Rep 630
Drives: 2021 G80 M3
Not the best, but I found this is my most used voice command right now "Hey stupid, turn on the AC" |
05-21-2021, 03:48 PM | #11 |
Rep 78
Carbon Exterior Package should include front lip and side skirts. It's a complete b/s that the current $4k package doesn't include this.
05-21-2021, 03:49 PM | #12 | |
Rep 664
Did you specifically call out Google Maps/Waze on iOS because native Apple Maps does display in the HUD? Only asking because the one time I used Apple Maps for directions instead of BMW Navigation, to my surprise I saw directions in the HUD. But now I'm wondering if I just imagined it
2021 BMW M3 Comp
05-21-2021, 03:51 PM | #13 | |
Rep 7,933
Drives: 2024 X5 M60i
05-21-2021, 04:10 PM | #14 | |
Rep 1,621
Yep, others here have reported that Apple Maps directions make it to the HUD. Funny thing - I just got a call from someone in BMW M product a few moments ago conducting a customer satisfaction and feedback survey. I relayed my list. |
05-21-2021, 04:52 PM | #15 |
8960
Rep 7,589
It works, but its too delayed gratification for me. And her response is too wordy. It's always a surprise if she understood me correctly. I just want her to say "ok". Similar to Alexa vs Google. Alexa says ok and Google repeats everything I just said.
05-21-2021, 06:43 PM | #16 |
Rep 82
i had to look up the AC button, pretty strange decision, definitely the one so far that has bothered me the most often. (have not tried the BMW assistant yet)
and audio skipping over Bluetooth. |
05-21-2021, 07:32 PM | #17 | |
Rep 300
Drives: E92 M3 Comp/G80 M3 Comp on Ord
Isn’t the AC on button in the center with the fan selector? That’s what I use. |
05-21-2021, 07:36 PM | #18 |
Rep 300
I love it for turning the radio up and down. Also it’s very useful for skipping tracks. Lastly, I use the open, close, open hand to get back and forth between the Vehicle Home button and the screen to change between sport modes.
TrentMeister2845.00 |
05-21-2021, 08:12 PM | #19 | |
Rep 142
05-21-2021, 08:13 PM | #20 | ||
Rep 142
05-21-2021, 09:20 PM | #21 |
8960
Rep 7,589
But can you turn the AC OFF with it?
05-21-2021, 10:39 PM | #22 | ||
Rep 596
