09-08-2022, 07:20 PM | #46 |
Rep 269
I've only had the car for 500 miles, but I don't notice much difference with the button on or off.
My 440 with the MPPSK was quite a bit louder and nowhere near as fast. |
09-08-2022, 07:42 PM | #47 |
Rep 764
forgot i had bimmercodes and the odb2 module, so I turned off the ASD just now after reading this thread. Not sure if what some were suggesting here that the exhaust sound is amplified, but if so mines lower having DP's and single mid's lol. But long story short it seems to have worked just need more seat time to see what the ASD hides as well.. Meaning it could also be like white noise or noise cancelling ?
09-09-2022, 01:42 AM | #48 |
Rep 323
09-09-2022, 09:52 PM | #49 |
Rep 269
08-26-2023, 12:06 AM | #50 | |
Rep 281
It drove me nuts to eventually buy an aftermarket intercooler and rip all that crap out. Solved. |
08-26-2023, 06:41 AM | #51 | |
Rep 1,000
Drives: 2024 M4 Comp X-Drive
If you code ASD off that doesn’t eliminate the actual burbles outside the car but does eliminate the piped in burble noises (and other synthetic sounds) However if you push the sound button it reduces/turns off ASD, changes valve control and turns off the burbles.
08-26-2023, 10:39 AM | #52 | |
Rep 6,827
08-26-2023, 12:03 PM | #53 |
Rep 1,000
Edited…what I meant was the burbles outside the car are real but the ASD also pipes in synthetic burble noises (along with drone/other frequencies)
Needsdecaf6904.50 |
08-27-2023, 04:13 AM | #54 | |
Rep 146
Thanks in advance for clarifying.
The fact is I don't drive just to get from A to B. I enjoy feeling the car's reactions, becoming part of it.
Enzo Ferrari |
08-27-2023, 07:36 AM | #55 | |
Rep 1,000
Try it in Sports or Sports Plus and then hit the button.
Joachim361.00 |
08-27-2023, 11:55 PM | #56 | |
Rep 1,584
In the US, the G8x sound control button seems to change at least 3 things: 1. The tone and volume level of the audio file played through the speakers that sounds like an engine, burbles, etc, 2. Exhaust valves are open more of the time to allow more exhaust to bypass the rear muffler, 3. The engine tune is altered to create more real burbles during deceleration and the tuning changes may also change the exhaust tone by changing the engine's exhaust valve opening duration, overlap, turbo wastegate behavior, things like that. If anyone is doubting that Active Sound Design is really an audio file and does not involve any microphones, you can use coding to change your car's ASD to sound like any other BMW model of your same generation. The same control unit goes in each car and the variant coding tells it which MP3 to play for us. Last edited by Remonster; 08-28-2023 at 12:03 AM.. |
Joachim361.00 |
08-28-2023, 07:17 AM | #57 | |
Rep 146
Now I remember that my earlier Alpina of 2014 (with Acrapovic) made a rampage at the cold start, amplified by the walls of the garage like in an ancient Greek amphitheater, that I always expected sticks and stones from the neighborhood. According to your detailed, solid information, the exhaust valves obviously were open these days, I'm sure. My M4 now is a whisperer compared to that car. Interesting also AMG's decision to adept the European software for the newer US cars. And, according to your last information, the sound control button in my M4 now is to be seen as a simple start button of an mp3 player. Earlier was better(tm). Thank you as well, ChrisM3, for your testing advice. Still searching for a victim to assist me, but, as outlined above, the result will be disappointing.
Enzo Ferrari |
08-28-2023, 07:53 AM | #58 | |
Rep 1,000
Poor EU customer cars are completely restricted sound wise…you have 4 cats, 2 OPF and now it appears that the exhaust valves are closed.
Joachim361.00 |
08-28-2023, 12:54 PM | #59 | |
Rep 217
But yes, do not expect too much in any case. In Europe the sound might be tamed more than in the US, even I did not notice differences when driving G8x there or here honestly.
2022 M4Cx in Brooklyn Grey
Joachim361.00 |
08-29-2023, 06:50 AM | #60 | |
Rep 146
Enzo Ferrari |
08-31-2023, 05:21 PM | #62 |
Rep 671
You can turn it off on your m1 and m2 settings. You can also push the button, but it won't be completely off. The only way to truly get it off 100% is to use something like bimmer code. If I am incorrect, please someone correct me, but I believe this to be accurate from what I have heard
08-31-2023, 05:25 PM | #63 | |
Rep 286
02-09-2024, 07:42 AM | #64 | |
Rep 15
02-09-2024, 09:37 AM | #65 | |
Rep 2,314
2001 330Ci (sold)
