02-20-2024, 10:39 AM | #23 |
Rep 261
So I have a G87 M2. I have done 9 track days since I got it last August. I will probably do 12-15 a year. The car has had some new mod on it just about every time as it is an evolution. Currently it has MCS 3-way coilovers w/ Vosrshlag Camber plates, 305 Nankang CRS (square), and Gloc R-16/R10 pads. On to your questions-
- Do you track and daily this car? Drive to and on the track only with the occasional spin on the weekend - How often do you track it? planned 12-15 times a year - What are you consuming most on the car? (assuming brakes / tires) yes, one set of tires lasted me 7 track days and front brake pads about 3 track days. I have been experimenting with different pads to be fair. - Anything unexpected break on the car after track use? nothing that wasn't my fault. Although this weekend I heard some clicking/clunking noise on the front right and I wonder if I have a wheel bearing issue.... not sure yet. I need to investigate. - Bonus: Are you happy or disappointed with the fun you have tracking this car? (why?) I am happy. Lots of good tech and for a base price of around ~$70K I am filling the mirrors and often passing GT4's and C8's. The speed, acceleration, and handling is impressive. My only complaint is there are a lot of nannies, warnings, and obstacles to modify (EDC, specific brake pad replacement procedure that will give you errors if you get the sequence wrong, ECU has to be unlocked in order to do a proper tune, tire reset procedure every time you swap to track tires, alarms on the dash if your cold tire temp is below 27 psi etc)
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
02-20-2024, 12:17 PM | #24 | |
1919
Rep 1,889
Drives: E92 M3
A very significant problem for a taxi-type program would be a reliable supply of replacement parts which didn't exist at that time. In 2021, my car spent a month on two separate occasions at the dealership waiting for simple replacement parts. Two failed parts could prevent the use of the car for most of a season. The supply of aftermarket parts was also affected meaning the usual companies where you would source brake pads, rotors, etc, do not have any items in stock or if they did, it was at ridiculously high prices. There were some small companies with unproven products that stepped in, but I wouldn't rely on those with heavy duty track use. If 2021 wasn't bad enough for supply chain issues, it was worse in 2022 for some parts. As for that weight, it's comparable to the E9x M3s which was used as a taxi. If I'm remembering correctly, the E9x was a stripped out Schirmer while the G8x was not quite as stripped out. Wasn't the F80 even more stripped and built out compared to the E9x? Not sure, but it's probable. Going further with the weight reduction on the G8x would have helped decrease some of the consumable costs, but they didn't. As far as "way too heavy to be a called a track car," the Camaro ZL1 1LE weight more at 3800 lbs and is much quicker around the Nurburgring. Finally, regular tracks can be much harder on brakes and tires than the Nurburgring. Plenty of tracks where you are losing close to 100 MPH in a braking zone, then 50 MPH or so in subsequent corners only to repeat it a couple of minutes later. Nurburgring has plenty of high speed areas followed by high speed/low braking corners giving plenty of opportunity to cool off the brakes. A novice would overslow in those areas and that's where they wear out their brake pads.
BackOnBlack714.00 |
02-20-2024, 03:11 PM | #25 |
Rep 728
Is the G87 different from the G82? I have a track set of wheels/tires with TPMS. I don't have to do anything, the car automatically picks up the change and reports the new monitor's settings.
Am I missing something?
02-20-2024, 05:12 PM | #26 |
Rep 261
on the G87 it will pop up with an error/message that new tires have been installed. you have to go through a few screens and select the reset procedure and then drive for a bit (my experience is anywhere from 2 loops around the paddock to get on the highway and drive 5 miles). Nothing bad happens if you don't do this other than the annoying message and the tire data will not be displayed.
2022 M850i
m4ml1834.00 |
02-20-2024, 06:13 PM | #27 | |
Rep 728
ZPD439.00 |
02-20-2024, 06:57 PM | #28 | |
Rep 261
2022 M850i
m4ml1834.00 |
02-20-2024, 09:26 PM | #29 |
1919
Rep 1,889
Drives: E92 M3
"Universal" TPMS sensors may have to be programmed for a certain type of car compared to the vehicle specific ones provided by BMW.
Once you install the new wheels onto the car, you should change the type (summer tires, >100 MPH) in the vehicle menu. This will have the car listen to all the TPMS broadcasts and narrow down which ones belong to your car by driving around. If you install new wheels without changing the type of tires in the vehicle settings, I'm not sure what will happen on the G8x. On the E9x generation if you remove your TPMS wheels and not go through the reset TPMS procedure, DSC will kick on very restrictively once the TPMS error pops up. Not very fun on track if you're in a high speed corner and the DSC kicks in. Something to keep in mind.
02-21-2024, 03:03 AM | #30 | |
Rep 728
Used my buddy's SUV to transport the new-in-box wheels to the tire shop (tires were already at the shop via tirerack.com). I tell the installer that I want new TPMS modules installed (he did use universal modules) so that when I swap the tires I can get the TPMS readings in the car at the track. He asked where my car was and I explained that I didn't bring it, and instead brought my buddy's SUV. He said that he needed the car so that he could scan each of the wheels that were on the car to configure the new modules to be registered with the car properly. I went back to my buddy's, grabbed my car, drove back to the shop and the installer then took a tool (like this one) and held it next to each wheel to read the settings (likely a MAC address and private keys or something similar). He explained that each sensor needed to be coded to the car and each tire position on the car had a different "signature". After he scanned each wheel, he said... cool, that's it. They'll be ready soon! I installed the track set at an autocross event a couple of weeks ago for the first time. There were no errors and the tires properly displayed both pressure and temperature in ID7. The same when changing them back to the street set after the autocross. And the same thing was done at SoW this past weekend without error popups. I don't know why new OEM sensors would be different in their ability to automatically sync when changed versus the universal sensors (other than the speculation that the above scan/code step wasn't done). One would think the OEM sensors would be the ones that wouldn't need the reset. Now, if the above scan/code steps weren't done, then maybe that is why the error is popping up; because the sensor's "signature" isn't the one the car was expecting at any given wheel. So it says "hey, you changed your wheels, you need to configure them". But if the signature is copied from one wheel to the next, they computer can't tell the difference and therefore is happy to just keep going. This might be something that my installer just "knew to do" because he knew that I'd be swapping back and forth - I told them they were a track set. In my case there isn't a need to change the type of tire in the settings because both sets are summer tires. One summer set for street and one summer set for track. (unless there is an option for "race", which I don't recall seeing before)
02-21-2024, 07:27 AM | #31 | |
Rep 45
I bought my car used and didn't realize the multiple traction control settings wasn't standard until after I bought the car and mine doesn't have it. Is that what your referring to as MDM? |
02-21-2024, 07:59 AM | #32 | |
Rep 74
“ MDM Uses M Traction Control Levels 4-7 for slip control based on a number of parameters, PLUS brake interventions based on vehicle yaw control. For vehicles equipped with the 10 levels M Traction Control, the driver can select Traction Control levels 0 (off) to 10 for slip control, but DSC must be off (no yaw control or brake intervention, only engine torque control). |
02-21-2024, 08:04 AM | #33 | |
1919
Rep 1,889
Drives: E92 M3
I have the BMW winter wheel package which comes with OE/vehicle specific sensors. These have their own IDs as they were not cloned from TPMS sensors already on the car. When I switch between the summer and winter wheels, I do change the tire type in the vehicle menu to indicate the car should start identifying new TPMS sensors. On the car, there should be three sensors/receivers so they can be used to triangulate the position for each of the TPMS sensors (FL, FR, RL, RR). In this case of vehicle specific TPMS sensors broadcasting their own unique IDs, the car should detect a loss of all four TPMS sensors and show an error. I would not expect it to automatically pick up the new sensors. It would also require a change of tire type (and potentially change back to original) to reset the TPMS learned IDs. I will be switching back to my summer wheels in the next month or so but this time, I'll go for a drive without resetting the TPMS (by changing the tire type in vehicle settings) to see what happens and if DSC becomes more restrictive when the error message is displayed.
m4ml1834.00 |
02-21-2024, 01:04 PM | #34 | |
Rep 728
02-21-2024, 02:12 PM | #35 |
Rep 633
Hey folks,
Nice to meet you all virtually. - Do you track and daily this car? I do drive it somewhat daily and intend to track it 'sometimes'. - How often do you track it? Maybe 2 weekends a year while I instruct with local clubs/chapters. Just to see what this car is capable of. - What are you consuming most on the car? (assuming brakes / tires) Likely going to be stock. PS4S tires and have Ultimate Care+ - Anything unexpected break on the car after track use? - Bonus: Are you happy or disappointed with the fun you have tracking this car? (why?) Love this vehicle for what it is, drove it at Performance Center and was extremely impressed. I have a dedicated race car but from time to time I do like to just drive to the track with a helmet/cooler/suitcase versus hauling 8 wheels/tires/car/fuel on a trailer. I'll report back how she does at Summit Point Main soon. Cheers, Lutfy |
02-21-2024, 06:44 PM | #36 | |
Rep 45
02-21-2024, 07:30 PM | #37 |
Rep 728
When you turn off DSC you should have whatever options are available to you (DSC On, MDM, DSC Off) appear on the console. I'm not sure about RWD M Driver's Package, but if you are xDrive with M Driver's Package, you will also have the option in Setup for switching to 4WD-Sport and 2WD. If you switch to 2WD after turning DSC Off, you will be able to set MDM value from 0-10.
02-21-2024, 07:59 PM | #38 | |
Rep 45
02-21-2024, 11:53 PM | #39 | |
Rep 728
Part 1: Part 2:
02-22-2024, 10:32 AM | #40 |
Track Rat
1760
Rep 403
DSC on is the equivalent of driving with level 10 of Traction Control. DSC off is the equivalent of driving with level 0 of Traction Control.
If you do not have the M Drive Professional Package then you do not have the ability to access the 10 level Traction Control setup. 0=TC Off 10= Max TC. You can however access MDM which is the equivalent of level 4-7 of Traction Control. The nannies are somewhat less intrusive but will still activate if things start to go seriously wrong. You are not invincible however. It is explained in your owner's manual. In order to activate MDM you press and release the DSC button on the console. You will see MDM displayed on the dash. Push it again to turn it off.
Forzanerazzurri6918.00 |
02-25-2024, 12:02 PM | #41 | |
Rep 3,337
It's the "M Drive Professional" $900 option with the ten stage traction control:
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
Hendo741645.00 |
02-25-2024, 08:38 PM | #42 |
Rep 223
Both. - How often do you track it? About a dozen times a year. - What are you consuming most on the car? (assuming brakes / tires) Tires for sure, definitely get camber plates or you'll be replacing them all the time. Once you gain some baseline pace, I highly advise looking at track pads. I went through a stock pad in one day at Laguna Seca. - Anything unexpected break on the car after track use? Some suspension parts aren't too happy with frequent hard driving. My tie rod boots are pretty shot for example. It's just part of the cost of driving track, so I wouldn't say it's unexpected. - Bonus: Are you happy or disappointed with the fun you have tracking this car? (why?) This is a really good car if you want a single car that can hang on the track and still fit a family with luggage. However, it's still nearly 4,000 lbs. It's great for what it is, but it's important to keep expectations realistic.
IG: ember.m4
shwayne549.50 |
02-28-2024, 11:39 AM | #43 | |
Rep 633
How many miles did you get out of the rod boots? I will report back after this weekend after my outing with the G87. Cheers, Lutfy |
02-29-2024, 05:53 PM | #44 | |
Rep 223
I got around 20,000 miles out of the tie rod boots, but I also didn't track the car as much in the first 10,000 miles, so it's a bit hard to figure out what the expected wear would look like based off my data.
IG: ember.m4
