04-07-2023, 09:58 PM | #1 |
Rep 73
Drives: '23 BMW G80 M3 Comp
Active Autowerke or MAD midpipe?
Deciding between the AA equal length, AA single, and MAD single midpipes on stock setup. They all seem pretty similar so I'm wondering what the minor differences are. If anyone has recommendations, please let me know!
04-08-2023, 12:01 PM | #2 |
Rep 5,041
This thread answers some of your questions.
https://g80.bimmerpost.com/forums/sh....php?t=1997084 Sound should be relatively the same. Biggest differences you will notice. 1.Price $$$ 2.We have a 2 piece mid-pipe for extra adjustability and flexibility for non oem rear mufflers. 3. We offer a Lifetime Warranty.
LeRoy389.00 Pizzathehut0494.00 |
04-08-2023, 01:49 PM | #3 |
Rep 191,249
Pros of AA, they offer X-pipe, equal length, and single midpipe
They also offer a catted X-pipe, and a resonated single midpipe MAD offers only one type, which is the regular single. MAD is an excellent value item if that's the only one you are interested in.
04-08-2023, 01:53 PM | #4 | |
Rep 73
04-08-2023, 01:55 PM | #5 | |
Rep 191,249
The single has a deep midrange tone the x-pipe is not as good in the midrange but more aggressive in the high RPM the equal length gives you the best of both worlds; the sound is clean with closed valves and gets very aggressive with open valves. But its also the most expensive, with the AA Equal length costing almost twice the MAD single.
04-12-2023, 11:22 AM | #7 |
Rep 5,041
Odd, we have more than a 1/4 inch of space between the pipe and our bracket.
04-12-2023, 01:04 PM | #8 |
Rep 191,249
i tried all three AA midpipes on my car, no washers needed with any of them
RACE M3548.50 BetMineWins22.50 |
04-12-2023, 01:24 PM | #9 |
Rep 477
04-12-2023, 02:56 PM | #11 | |
Rep 191,249
When I installed mine, it looked good, but as soon as I started driving, I could hear a drone. I put it back on the lift and adjusted it by a few mm, and thats all it took.
RACE M3548.50 |
04-12-2023, 09:24 PM | #12 | |
Rep 477
Thanks for the insight as usual! The intakes sound great btw! |
04-13-2023, 08:30 AM | #13 |
Rep 140
if it helps, what I did was leave the rear sleeve and ball clamps loose enough to let the midpipe move, just barely threaded on the brace, took a small object, in my case, a rubber bmw jack pad, and put it between the midpipe and the brace, and tightened the brace down. Then I tightened the midpipe down and wiggled the rubber jack pad out. This left me a perfect gap between the brace and the midpipe after everything was tightened down.
04-13-2023, 10:34 AM | #14 |
Rep 387
For MAD midpipe, I placed a small piece of wood between the brace and the pipe. I kept everything loose to adjust as needed especially the rear section with the smaller pipes and clamps. Sometimes the smaller pipes can be twisted in a way that will move the system up higher. Once everything is set I loosen the brace and remove the small piece of wood and then reinstall.
I have about 1/2" of clearance. |
04-13-2023, 01:13 PM | #15 |
Rep 191,249
RACE M3548.50 |
04-13-2023, 04:36 PM | #16 | |
Rep 5,041
RACE M3548.50 |
04-15-2023, 08:27 PM | #18 | |
Rep 73
04-16-2023, 11:41 AM | #19 |
Rep 191,249
Correct.
04-29-2024, 12:54 AM | #20 |
Rep 2,472
Starting to get impatient with the MAD resonated midpioe. Ordered early mid March from x-ph for a late March delivery. Then the date changed to May, now I see it states June 01….
What’s the hold up and will the part ever arrive? I prefer the sound of the MAD to the AA but the date keeps slipping |
04-29-2024, 01:56 AM | #21 |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
100
Rep 189
04-29-2024, 09:39 AM | #22 | |
Rep 5,041
pdjafari153.00 |
