      10-08-2021, 08:02 AM   #419
mattburks
Drives: G80 6MT
Originally Posted by KevinGS View Post
Oh got it, you mean simply turn the car on (accessories)...put it in Sport Plus, and THEN start the car as the valves will be open. Got it. Thanks!
Yessir! Works like a charm- Give it a go and let us know what ya think!
      10-08-2021, 02:12 PM   #420
bimmermann88
Drives: BMW g05
Originally Posted by jmh600cbr View Post
This is the g80 6MT with the primary resonator and secondary cat removed. The first video is a drive by in second gear in sport plus mdm.
In the second video I did a warm start, comfort mode revs, sport mode revs and sport plus mdm revs. It should be noted that engaging a gear does actually make it sound much better than neutral but it's too hard to capture the sound in gear. Also you should know that with the windows up it's much quieter than when outside of the car. You hear the burble and cracks nicely from inside. There is zero droning on the highway or ever.
The guy that did the mod for me told me that if you remove the secondary resonator you will get drone. He said resonators control the depth of the sound and the cat is the volume. I couldn't be happier. Extremely excited. Oh and it added about 10hp to the car. Noticeably more exciting of a drive.
Any cels?
      10-09-2021, 01:46 PM   #421
jmh600cbr
jmh600cbr's Avatar
Drives: G80
2021 BMW G80  [0.00]
Any cels?
What is a cel?
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM
      10-09-2021, 01:47 PM   #422
bimmermann88
Drives: BMW g05
Any cels?
What is a cel?
Check engine light
      10-09-2021, 02:35 PM   #423
jmh600cbr
jmh600cbr's Avatar
Drives: G80
2021 BMW G80  [0.00]
Any cels?
What is a cel?
Check engine light
No. I would never have done it. I was assured removing the primary cat is the only scenario for dash light ups
2021 G80 6MT BSM
      10-11-2021, 12:30 PM   #424
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
In surgery. While waiting this clean 454SS showed up.
mattburks750.50
JTO245276.00
      10-11-2021, 03:29 PM   #425
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Done. Sounds really good. Bubbles are bit louder, but not crazy as F8X gen. Zero drone on the highway.
      10-11-2021, 03:50 PM   #426
M0J0
Drives: XM3C '22 JKUR '13
You put the xpipe in place of the resonators?
mattburks750.50
      10-11-2021, 04:20 PM   #427
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Yes. With cat-less DP.
      10-14-2021, 10:31 AM   #428
Gfit
Drives: 2023 X3M, 2024 X5M. Sold 2022
Looking for a shop in Westchester, NY is anyone has a tip please?
      10-14-2021, 10:36 AM   #429
mattburks
Drives: G80 6MT
m20e3087 interesting!!!! My set up sans catless DPs. Do your DPs also remove the secondary cats as well?
I have removed those bad boys, but sure would love to hear the difference! Safe to assume you are just running with cel until ECU can be un-benched locally?
Thanks in advance as I look forward to your feedback!
      10-14-2021, 10:42 AM   #430
M0J0
https://www.summitracing.com/parts/jex-sxp6ss
Looks like this simple x-pipe would work. Is it three inch?
      10-14-2021, 04:24 PM   #431
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Yes running with CEL. Only cat-less dp and both res delete. And my 2nd cats are still intact. Sounds amazing, specially in 2nd or 3rd gear, 4-7K sound is pure bliss. I am still stunned by how little I spent to get that sound. My neighbor got a S55 M4 comp with MP exhaust, he was like that Akra or Remus, told him it's X pipe and dp with stock rear. He was really surprised.
      10-14-2021, 04:27 PM   #432
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Should work. Mine was is similar also.
      10-14-2021, 04:35 PM   #433
M0J0
https://www.summitracing.com/parts/mpe-10792
https://www.summitracing.com/parts/sum-640701
These seem to be the other good options. I think the last is the one to buy.
OwnerF16852.00
      10-14-2021, 05:00 PM   #434
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Mine is 304SS. Just check with your shop, mine wasn't fully aligned but they made it happen with custom bent 3" pipe.
      10-14-2021, 10:28 PM   #435
F80M4ROCKS
F80M4ROCKS's Avatar
48
Drives: M4
has anyone tried just catless downpipes with everything else stock? this kinda seems like the most performance and pops with probably no drone. Temped to try with the r44 downpipes since they also have a cat simulator.
https://r44performance.co.uk/collect...tless-downpipe
      10-15-2021, 12:06 AM   #436
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
I ran cat-less DP for about 3 weeks. Sounded great, but I was looking for bit more volume and X pipe did the trick. No drone whatsoever with just cat-less DP and now DP plus mid pipe mod combo.
OwnerF16852.00
      10-15-2021, 06:32 AM   #437
F80M4ROCKS
F80M4ROCKS's Avatar
48
Drives: M4
Awesome thanks, seems like a great mod and keeping secondary cats prob saves you from a lot fume smells. Let us know if you can post a clip to hear it, really looking to copy you
      10-15-2021, 08:21 AM   #438
Gfit
So I'm clueless with this stuff but planning on purchasing an x pipe and having a muffler shop do the work. If I understand correctly, this mod doesn't touch the cats or O2 sensor right? Thank you
      10-15-2021, 11:02 AM   #439
Tall Tom Cruise
Tall Tom Cruise's Avatar
Drives: '21 G80 M3
Correct, deleting the 2 resonators (look like metal suitcases) and replacing with a x-pipie has no effect on any cats or O2 sensors.
There's 2 cats in the downpipes and 2 cats in the midpipe. The resonators are located behind the cats in the midpipe. They are in between the secondary cats and the stock rear section (valves). So no worries.
Gfit2716.00
ai38868.50
      10-15-2021, 11:06 AM   #440
Gfit
Thank you. Made an appointment at a local shop that comes recommended by a few friends. $300 with parts. Going this coming Tuesday
