05-23-2022, 02:57 PM | #1 |
Rep 34
how does m4 valve work?
Hello,
I am posting to ask about how the g82 m4 exhaust valve work. I understand that the valve won't open fully, but I would like to know in what kind of situation would it open a little. I think the exhaust button on the console isnt opening the valves to make it much louder. I heard it is the m2 button but I am not sure which setting must be on for it to work(for example engine must be set to sport plus or something?). Furthermore, is it possible to open the valve before cold start so it is louder at cold start? Right now the car is at its break in so I am not playing it too much. I thought it would be best to ask for a clearer answer. Thank you |
05-23-2022, 08:14 PM | #2 |
Rep 223
On comfort engine setting, the valves are always closed (active sound control button does nothing).
On sport and sport plus, the valves are closed if the ASD button is off (center console exhaust button that lights up green). If that's on, then the valves open and close depending on throttle input (variable open/close). Additionally, fake engine noises are piped into the cabin through the speakers. M1 and M2 map to a specific set of settings that you define. They affect the valves the same way as the above. If you buy a valve controller, you can control the valves completely, so you can open them 100%, which is not possible without the controller. On cold start, the valves are always open. If you turn on ASD on sport/sport plus, it will pipe extra fake noise through the speakers into the cabin, but the cold start will sound identical from the outside.
IG: ember.m4
05-24-2022, 01:43 AM | #3 | |
Rep 34
05-24-2022, 07:33 AM | #4 | |
Rep 191,414
Perfectly said except for the cold start, the valves are closed. You can open the valves during cold start by selecting M1/M2 and then pressing the gas pedal at least one to activate the change.
Laguna01///M31400.50 |
