01-02-2022, 02:12 PM | #1 |
Rep 5
ISTA - No Communincation
Greetings all,
New to the forum and was wondering if anyone can guide me in solving in what I think is a communication issue. Thank you in advance! Vehicle BMW x5 E53 – 2003 I got a hold is ISTA an to see if I can solve, why I have Traction-ABS-Brake and Check Engine Lights are on. ABS module was rebuilt 4 months ago. Items verified
ISAT is not able to identify the vehicle or read the modules. ISTA Messages
Not sure what next needs to be checked. please advise, thank you again. |
01-23-2023, 08:33 AM | #6 | |
Rep 15
This was the issue myself and friends always ran into. Tried multiple installation source files till I found one that works. Was not always same installer with car model, ie E46 vs E92. Good luck. Can be a big pain |
01-23-2023, 09:52 AM | #7 |
Rep 6,715
Check you connection in settings>VCI Config and select “Yes” for “Ethernet as preferred communication channel when connected via ICOM?”
I had same issue or similar and that’s what my fix was. Not sure what cable setup you got. I was using cable with Ethernet to USB adapter. |
02-13-2023, 07:58 PM | #9 | |
Rep 380
03-29-2024, 04:20 PM | #10 |
Rep 491
Drives: M4 GTS
I’ve read through as many forum posts as I could find and have set all the port / latency / EDSUBIAS settings as recommended and still am getting this error. I’m on ISTA+ with K +DCAN cable.
Would love some help. |
