04-07-2023, 09:47 PM | #1 |
Rep 121
rivets for rear winglets and side skirts
hi, got some rear winglets and m performance side skirts i want to install. do i use 51161881149 (part number) for the side skirts and just put into rivet gun? and can i reuse the rivets for the rear winglets? if not, which rivets do i buy ?
04-07-2023, 11:58 PM | #2 |
Rep 133
I don’t know about the side skirts but I’ll be replacing one of the rear corners tomorrow. The push rivets there can be reused, just remove them carefully.
04-08-2023, 01:41 AM | #3 |
Rep 121
04-08-2023, 02:08 AM | #4 |
Rep 165
Drives: Voodoo Blue G82
Kies made a video that contains him changing out the side skirts and the rear winglets. He showed that you can reuse the rear winglet rivets, but for the side skirts you will need a rivet gun. Doesn't show the part number though, but it may be helpful for you to watch it.
Do let me know if you find out which rivets to use because I also want to change them out! |
04-08-2023, 04:57 PM | #5 |
Rep 133
Just finished. The plastic rivets come out easily. Just back out the center piece with a pry tool (I used a plastic one) then pull it out with your fingers. I taped off the painted portion of the bumper next to the trim piece just as an extra precaution. After that, start from the tire side with firm pressure on both the bumper and the trim piece in opposite directions and gently work it out. It did take a little more pressure then expected, but once the first two clips popped it was easy. Just do the reverse for the new piece.
04-09-2023, 01:15 PM | #6 | |
Rep 121
06-08-2023, 05:34 PM | #9 |
Rep 121
yea the 90 deg one would probably work better if u dont want to jack which i didnt, but i got the universal rivet gun that stands straight up and jacked the car up alittle and it fit under, you dont have to jack it high either, tires were still on the floor and it gave me enough room to get under
vmalho2703.50 |
06-08-2023, 05:36 PM | #10 | |
Rep 488
04-11-2024, 05:50 PM | #13 |
Rep 871
The expandable rivets (one time use) are 51717002953. Those are to be used with the side skirts only and require a riveter to install. The rear winglets on the bumper are reusable push clips and the P/N is 51471911992.
We use these riveters at the shop: https://www.harborfreight.com/hand-r...ets-97757.html
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
chris3g1607.50 |
04-11-2024, 05:52 PM | #14 |
Rep 871
No those are for the front fender liners. The correct P/N is 51717002953.
WolfpackCO158.50 |
04-11-2024, 05:54 PM | #15 | |
Rep 1,271
thank you! |
04-12-2024, 09:01 AM | #16 |
Rep 2,637
If you want something available via Amazon, I used these and they worked very well
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 |
04-12-2024, 09:55 AM | #17 | |
Rep 1,271
Berzerker2930.00 RichardGM4527.00 |
