11-16-2023, 04:43 PM | #45 |
this is the way
18160
Rep 8,527
M2siast5876.00 |
11-16-2023, 04:57 PM | #46 | |
Rep 6,701
11-16-2023, 05:03 PM | #47 | |
Rep 6,701
My buddy is a big time track rat and is awaiting delivery of his 992 GT3 RS. He's owned 2 991 GT3's, a 997 GT3 and two 997 Cup cars. He does a bunch of Porsche experience trackdays around the world (spain, nurburgring, iceland) and has chatted up the Porsche engineers a bunch. He asked a few of them about the CL's. Every single one of them HATE Cl's. Two of them told him the CL mechanism has been subtly re-engineered like 7 times. It offers no weight savings, no performance benefit unlike CCB's. It's pure motorsports theater. Guys who do track and change wheels a lot general either hate them or have gotten used to them by now, but the Porsche tightening spec is less than these, like 440 ft-lbs. You have to have the huge breaker bar and massive torque wrench, or plump for the $5k hytorc system (which, by the way Porsche does NOT endorse). So yeah....this is PURELY show. No go. Get some lightweight wheels and titanium lugs for way cheaper and you're same or ahead. Sorry, there's no performance benefits from CL's. |
chris7197334.00 BrendanZ0402283.50 meko178.50 SYT_Shadow11490.00 LaKuan56.00 alexy228.50 ///M TOWN16584.00 |
11-16-2023, 05:16 PM | #48 | |
Rep 7,299
Still, they make very little difference for the $$ as the data provided by GM illustrates. You are again making claims with no substantiation like ride quality improvement. Why does an S class use heavy wheels if this is an important component of ride quality? Where is any accelerometer data? I am not claiming there is ZERO improvement. I highly suspect there is very little real-world improvement, however, within the bounds of available wheels. My M2C winter setup weighs 10-15 lbs more per wheel and tire and rides better than my summer setup. Same sizes and profile. Whatever effect there is, it's swamped by the tire. Last edited by chris719; 11-16-2023 at 05:28 PM.. |
11-16-2023, 05:48 PM | #49 | |
this is the way
18160
Rep 8,527
11-16-2023, 06:30 PM | #50 |
Rep 322
Needsdecaf6606.00 chris7197334.00 nearwater4me1916.00 Quadruple VANOS1173.00 G30 B581548.00 stormlv932.00 |
11-16-2023, 08:05 PM | #52 |
Rep 734
Drives: M340i x-drive
This looks very good!
11-16-2023, 08:42 PM | #53 |
Rep 687
When Porsche went to center locks there were threads on Rennlist on how to convert to 5 lug with GT parts. That’s how bad center locks are on street cars.
In addition there were track rats removing the carbon rotors from their GT3 RS and installing GT3 steel rotors because of the cost to replace the carbon rotors. Reduced weight doesn’t matter at HPDE events. This kit is a money flex. |
chris7197334.00 |
11-17-2023, 01:40 AM | #57 |
Rep 875
Drives: ///M2
What are the benefits of the center lock rim versus the traditional set up?
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
11-17-2023, 03:17 AM | #58 |
Rep 647
Either way these photos are opulent.
///Meant-to-be-sent
carseatsm5839.50 |
11-17-2023, 04:11 AM | #59 | |
Rep 4,001
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
11-17-2023, 08:11 AM | #62 | |
Rep 6,701
Supposedly "easier to change wheels" because of one locking nut...but these don't go on like racing wheels. Here's a GREAT video that Matt at Obsessed Garage has made to sell the $5,000 Hytorc tool for CL's. Look at what a mess it is to do the CL's. 1. Car has to be jacked in the air. Do NOT loosen on ground. Which means. 2. Someone has to be in the car holding the brakes. Some people use a clamp to press the brake pedal down (spreader clamp pressed against the front seat) but that doesn't... 3. Hold the steering wheel straight for the front wheels. 4. Pop off the centerlock cap 5. Properly depress the locking pin. This can be a giant pain. 6. Deploy your 5' breaker bar to loosen the center nut. Matt is a strong dude...crossfitter. Look how much he is pulling up on the bar (oh, you can't push down, you have to pull up). 7. Pull wheel off. Re-installation is as follows: 1. Again, do in air, do not tighten on ground 2. Completely clean the CL nut and mating surface on wheel of old optimoly paste. 3. Apply new, very thin, layer of optimoly paste. This stuff gets everywhere, reportedly. 4. Reinstall wheel and nut. 5. Get your 440 ft-lbs huge torque wrench out. 6. Tighten wheel. 7. Loosen wheel and turn breaker bar 90 degrees. 8. Re-tighten wheel. Does this sound faster than zipping off 5 bolts with an impact? And everyone goes on about lightness...that locking mechanism isn't exactly small guys. Keep in mind, with this video, Matt has probably done a centerlock wheel like few hundred times, literally. The amount of times he's had his CL's off on his 991 GT3, 991 RS, 991.2 RS and now this 997 RS is....a lot. The biggest drawback of using these if you're not tracking and don't have the equipment is that you MUST go to the dealer, unless you carry the equipment with you and plan on doing it for an independent tire shop if you should need to.... Last edited by Needsdecaf; 11-17-2023 at 09:57 AM.. |
11-17-2023, 08:31 AM | #63 | |
Rep 2,606
carseatsm5839.50 |
11-17-2023, 08:47 AM | #64 |
Rep 1,929
Ok so utterly pointless confirmed.
21.1 kg 19" forged center lock front wheel + tire 22.7 kg 19" forged m3 front wheel + tire (just measured mine) 24.1 kg 19" cast m2 front wheel + tire 334 grams stock lug bolts 1350 grams center lock 22.45 kg 19" forged center lock front wheel + center lock 23.00 kg 19" forged m3 wheel + lug bolts 24.40 kg 19" cast m2 wheels + lug bolts So 2 kilo savings for m2 owners or 550 gram saving for m3 owners... how much are these again? You're better off buying lighter aftermarket forged wheels or even carbon fiber ones than this center lock crap. And they didn't even weigh the actual hub, which will probably be heavier than a stock one.
Needsdecaf6606.00 chris7197334.00 |
11-17-2023, 09:57 AM | #65 |
Rep 6,701
11-17-2023, 10:26 AM | #66 |
Rep 1,964
This...... Bragging rights is all it is and $12k Euros for the right.
No functional use at all for the street and marginal even for the track. You are limited in wheel choice too. I can find a bunch of other upgrade north of $12k that would be more fun.
Arctic Metallic\CF Splitters,Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1\M-Performance Brakes\Cobb Tuned\xHP Flash ->
