02-08-2022, 06:22 AM | #67 |
Rep 616
02-08-2022, 01:10 PM | #68 |
Rep 542
02-09-2022, 12:50 PM | #69 |
i can haz horsepowr ??
3833
Rep 1,929
Which is why I intend on having a friend that's a mobile detailer do the cleaning
Dakar Yellow G80 M3
02-09-2022, 08:30 PM | #70 |
Rep 290
Can anyone absolutely confirm that a stock rear rim (20x10.5 ET20) does indeed fit on the front without a spacer?
There are links to the Evolve thread and people have spoken about it, but no one has confirmed that no spacer is required. I've seen how little clearance there is with the stock 9.5 inch rim, so really surprised to hear an extra 12.5mm less clearance (with a 10.5 inch rim) manages to avoid clashing the strut. |
02-11-2022, 03:52 AM | #72 |
Chief Petty Officer
645
Rep 517
02-11-2022, 06:30 AM | #73 | |
Rep 2,538
Front 20X9.5 ET5 with 275/30ZR20 Back 20X10.5 ET8 with 285/30ZR20 This will cause zero issues even after the car is lowered. There’s no engineering dynamic reason to go wider than what the factory provided other than it might make an individual feel better about him or herself. A wider tire does not have better handling, traction or stability benefits. It won’t even have better aesthetics because you can’t tell how wide the front tires are unless you look at it from a particular angle and 10mm is just not going to make that big difference to the eye. So in the end it’s just not worth taking the risk of having mechanical challenges like rubbing all so I can say I went wider. That’s my conclusion after in my opinion, spending entirely too much time researching all this crap. Lol. It has been exhausting simply because there really is not a lot of knowledge on this either here or even at wheel shops. Somewhere there’s a thread were some shop in Korea put 295’s on the front lol. |
08-20-2022, 05:46 PM | #74 | |
Enthusiast
1725
Rep 826
Drives: '24 G83 M4C xDrive
'24 G83 M4 Comp xDrive SG/Black, '23 U11 X1 PB/Oyster
Gone but not forgotten:'22 G82 M4Comp xDrive, '21 F90 M5 Comp,'19 Porsche 911 C4S, 15 Audi RS5, etc.. Last edited by eman4517; 08-20-2022 at 06:02 PM.. |
Limegrntaln13477.50 |
08-20-2022, 05:51 PM | #75 | ||
Rep 6,962
YT: G Dubyou |
eman45171724.50 |
08-20-2022, 05:56 PM | #76 |
Enthusiast
1725
Rep 826
Thanks! This was totally super helpful and great news...Will give it a shot. Now time to fix the pictures..
Gone but not forgotten:'22 G82 M4Comp xDrive, '21 F90 M5 Comp,'19 Porsche 911 C4S, 15 Audi RS5, etc.. |
08-20-2022, 06:48 PM | #77 |
Rep 6,962
No problem. We do what we can to help out, on here.
YT: G Dubyou |
eman45171724.50 |
08-22-2022, 03:32 PM | #78 |
Enthusiast
1725
Rep 826
Think I changing wheel direction again! Argh!
Can of worms officially opened! Arguments both ways.. https://www.bimmerpost.com/forums/sh...php?p=29250684
02-20-2023, 11:50 PM | #79 | |
Rep 37
02-22-2023, 01:51 PM | #80 |
Rep 5,484
Drives: 23 X7 40i; 23 M3; 24 cooper s
I have:
Front: 20X9.5 ET10 with 285/30/20 Rear: 20X10.5 ET10 with 295/30/20 I've noticed while reversing, if I turn the wheel a certain degree I'll get some rubbing. That's the only situation where I get rubbing (that I've noticed so far), so trying to see if it's a big issue that'll require some modification of the fender or not.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
03-10-2023, 06:51 PM | #81 |
Rep 297
I'm running with Titan 7 T-S5s 5-Spoke Euro Exotic (20 x 20 setup) with 275/30 (f) and 295/30 (r). Installed the wheels a couple of weeks ago and just installed a KW HAS kit on Monday of this week, experienced ZERO rubbing issues since putting the 20 x 20 setup on the car.
Laguna01///M31397.50 |
03-13-2023, 09:04 PM | #82 |
Rep 393
Drives: 22 G80 Sao Paulo Yellow
03-20-2023, 12:43 AM | #83 |
Rep 301
I’m going to be running a square setup 20 10.5 M826 wheels all four corners with 285X30X20s. I have 12mm Spacer in rear and 12mm in front. I will post photos and details regarding any issues on the front wheels. Note my car is also lower in HAS kit. I’ve now for a fact the OEM 20 10.5 do rub without any spacers on the brake ducts at full lock when turning the wheels. That is the reason I will see if the 12mm spacer will solve that issue 🙂.
At the moment my wheels are getting powder coated so i should have an update by next week My car is RWD Manual. Last edited by myg80m3; 03-20-2023 at 06:29 PM.. |
03-20-2023, 03:45 PM | #85 | |
Rep 979
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
03-20-2023, 04:28 PM | #86 |
Rep 301
03-20-2023, 06:16 PM | #87 |
Rep 979
10” in front with 285/30 (pretty sure on the 285.. will double check once I get car back), and 11” in rear with 295/30
