01-27-2022, 06:56 PM | #45 | |
Rep 2,538
Wheels Front 10X20 ET11 Rear 10.5X20 ET8 Tires Front Michelin 275/30ZR20 Pilot Sport 4s * Read Michelin 285/30ZR20 Pilot Sport 4s * https://agluxurywheels.com/agl68.html |
01-28-2022, 12:17 AM | #46 | |
Rep 542
2022 G82 M4 Competition xDrive in indiv. Sunset Orange
Incoming: 2023 F40 M135i xDrive in indiv. Tansanite Blue |
Patton2502939.50 |
01-28-2022, 03:39 AM | #47 |
Rep 2,538
I appreciate that. I know zero knowledge about this stuff. And just listening to the wheel store manager, even know he’s excited and nice I just know there’s way more knowledge on this forum then he has. At least when it comes to these cars.
I thought some of you guys might not like the half inch difference between the front and back wheels. This was recommended by the wheel manufacturer. The wheel store manager suggested 305‘s on the back with 11 inch wheels. Do you know what size tires Michelin makes BMW stars in? I guess my question is there a master list? |
01-28-2022, 03:49 AM | #48 | |
Rep 542
But thats just a minor tweak and really not necessary. As for the * rated tires, these are specifically engineered by BMW and Michelin and there is no "list". For the M3/4 there are only the stock 275/35 19" and 285/30 20" tires either PS4s* or Pirelli Pzero4* or, if you want to have more grip, go for the Cup2* or Pzero4 Corsa*. You can go with 305 in the back, but with xdrive you have to adjust your front tire aswell. The wider tire gives you no real bonus because, well, you have xdrive. So id go with what you are planningn now. |
01-28-2022, 09:21 AM | #49 | |
Rep 2,538
01-28-2022, 09:25 AM | #50 | |
Rep 542
If * is a must, then you have to go with 285/30 20" square. |
02-02-2022, 10:37 AM | #51 |
Rep 373
Ok so i dont understand offset and rims for that matter I reached out to BMW Parts they can get a set of OEM Rears 20 ET 20x10.5 so would these fit up front or would you need any modification??
I see guys running 20x10 up front but not 20x10.5 Appreciate the help guys
22 G83 X Drive Toronto Red Black Interior
Blue Calipers Frozen Black Edelweiss LT3 |
02-02-2022, 11:00 AM | #52 | |
You got my money?
3159
Rep 4,646
Drives: Ice Cream Truck
https://g80.bimmerpost.com/forums/sh...7#post27348907
02-02-2022, 11:16 AM | #53 | |
Rep 542
997CABOVA187.00 |
02-02-2022, 11:25 AM | #54 |
Rep 373
Thanks man yeah got a AWD incoming
Would/Are you gonna run spacers???
02-02-2022, 02:34 PM | #56 | |
Rep 453
I'm trying to finalize my spec for a set of Forgelines for summer use. The roads near me are very bad, so I'm actually thinking of running square 19s with 285/35/19s all around. I'd like to do a 19x10.5 wheel, but I'm not seeing how the math of the additional width, increased tire width, and new offset would work... At the same offset, adding an inch to the oem 9.5 adds a half inch of wheel on the inside. So to get the inner wheel clearance back to stock (which is already pretty tight, although not terrible), need to reduce offset from 20mm to about 8mm, right? Then, this would have already added a half inch on the outside (from the additional inch of the wheel), plus we'd be moving the wheel out another half inch (from the offset change to 8mm, to get the inner clearance back) - so that's the equivalent of a 25mm spacer in terms of the outer clearance. Not taking into account the additional 10mm of rubber width (although on a 10.5, a 285 probably wouldn't bulge like the oem PZeros do, do maybe from a sidewall perspective, the difference is only a mm or two on the outside). What am I missing? How are people clearing 10.5s up front? Thanks! |
02-02-2022, 02:43 PM | #57 | |
Rep 542
So you really just have the additional width of the wheel. If you want a proper fit, then id suggest to go with an offset of 15-20mm for a 10,5" wheel. I myself chose 10.5 x20" ET15 all around, with 12mm spacers for the rear. |
02-02-2022, 03:42 PM | #58 | |
Rep 453
02-02-2022, 07:17 PM | #59 | |
You got my money?
3159
Rep 4,646
02-03-2022, 12:17 AM | #61 |
Rep 542
Custom forged wheels have an offset limit. For the ones i picked, the limit is ET10, so id need spacers anyway. Thats why I went with ET15 to be able to square the wheels.
BIGW0RM3159.00 |
02-05-2022, 08:45 AM | #62 |
Rep 989
02-07-2022, 07:52 PM | #63 |
i can haz horsepowr ??
3831
Rep 1,927
My ANRKY wheels arrived at AutoCouture but won't be mounted until winter is over. 20" all around, I think it's gonna look killer.
Dakar Yellow G80 M3
02-07-2022, 08:11 PM | #64 |
Rep 2,538
02-07-2022, 09:03 PM | #65 | |
3831
Rep 1,927
Dakar Yellow G80 M3
02-08-2022, 04:30 AM | #66 | |
Rep 2,538
