01-05-2021, 12:52 AM | #67 |
Rep 262
01-05-2021, 10:33 AM | #68 | |
Rep 2,956
https://www.tirerack.com/tires/tires...omCompare1=yes Half an inch is a fair bit of extra contact area so you can see why tire profiles keep getting lower and lower. |
01-05-2021, 11:18 AM | #69 | |
General
21121
Rep 20,741
Drives: 2021 911 turbo
See below a counter example. Comparing the 265/40R18, 265/35R19 and 265/30R20 PSS where not one of the five 265/35R19 offering has a wider tread than the two 265/40R18 offerings and with the 265/30R20 having the narrowest tread of all. Picking such examples does not prove that higher profiles have larger treads, but it does prove what I said earlier: that the tread width is defined by the tire's construction and is not directly related to sidewall profile. Period. Yes, facts are facts...
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-07-2021 at 12:23 PM.. |
chris7197334.00 |
01-05-2021, 04:35 PM | #70 |
Rep 2,349
CanAutM3
I remember your comments and comparisons with various PSS and PS4S threads such as the below ones and definitely respect your tyre knowledge! https://f80.bimmerpost.com/forums/sh....php?t=1089535 https://f80.bimmerpost.com/forums/sh....php?t=1730589 https://f80.bimmerpost.com/forums/sh....php?t=1350040 Those pages will give some people more things to argue about What I wanted to say was that I find it interesting that as the G8x cars have had their weight distribution become less balanced and get closer to an Audi weight distribution with an increase of about 1.5% heavier at the front compared to F80. From this I believe that is why the front tyres are now only 10mm narrower than the rear whereas they were previously 20mm. Of course there is an overall weight increase as well and I'm sure that the wider front tyres are there to provide more grip as it is now needed due to the extra weight. I wonder if the staggered diameter allowed them to meet the compromise they were looking for between grip, ride quality and so on. This article touches on it slightly for the 992. https://www.motorauthority.com/news/...r-the-2020-911 My only complaint about the different sizes is that with 20mm difference in width the previous sidewall height difference was about 7-8% whether the wheels were the same size with the rear sidewall being a bit bigger on normal cars or with the staggered diameter setup the difference was still about 8%, just the other way around as the rear sidewall was of course smaller due to the larger wheel. Now that sidewall height difference is 12.5% larger at the front which is the problem here - it will be much more noticeable and can look a bit weird. The other manufacturers doing staggered diameters front and rear are making the rear tyres a lot taller for their outer diameter which means that the sidewall size is much closer from front to rear, ie the C8 is 6%, the 992 is 6% and I'm sure there are other similar examples out there - as mentioned in the first post. I'm sure someone out there will be running 265/35r19 and 295/30r20 on their GTS or CS and I bet that will look really good but I'm not sure if that is fixable easily on the G8x, 275/35r19 and 305/30r20 would fix the looks issue but I'm not sure if the stability control will understand that difference. The stock rear wheels are 10.5" wide so will support a 305/30r20 if there is enough room for the tyre.
CanAutM321121.00 |
01-05-2021, 06:51 PM | #71 | ||
Plenipotentiary
2614
Rep 3,046
solstice5457.50 |
01-05-2021, 09:39 PM | #72 | ||
General
21121
Rep 20,741
Curious here, when you say "larger Ø rear", are you talking tire diameter or rim diameter?
01-10-2021, 03:09 AM | #73 | |||
Rep 5,110
There are quite a few misconceptions/misunderstandings in this thread. A few posters seem to confuse rim diameter and tyre diameter. Porsche has a staggered setup on the 992 where both rim and tyre diameter is increased on the rear compared to the front. That obviously gives a larger contact area, not due to the increased rim diameter but due to the increased tyre diameter. Hence Porsche's reasoning of increased traction/grip on the rear with this setup. BMW has, as CanAutM3 has pointed out multiple times, not done this. They have retained a tyre diameter of less than 1% difference between f/r, and only increased rear rim diameter. So no gain in tyre diameter or contact area from a 1" larger rear rim diameter in BMW's case. Better turn in on the front axle and more stable rear due to a lower sidewall tyre. Best of both worlds! This also lines up with Sport Auto's test drive of the G82 M4 on a track. It had a much better front end when it came to turn in than the F82 M4 Comp they drove back to back with on the same track on the same day. |
01-10-2021, 03:53 AM | #74 | |
Rep 5,110
How large was the difference in % You might be surprised... It's easy to disregard the difference in contact area because both are so small compared to the remaining area of the objects. But, even though both still have a very small contact area, the bowling ball will have a much larger area than the smaller ball. A tennis ball is around 67mm (6,7cm) in diameter A bowling ball is around 217mm (21,7cm) in diameter Surface area of a sphere: A = 4πr2 Surface area of the tennis ball: 141cm2 Surface area of the bowling ball: 1256cm2 For arguments sake, let's say that 0,01% of the surface of a sphere (ball) touches the ground. Tennis ball area touching the ground: 0,0141cm2 Bowling ball area touching the ground: 0,1256cm2 Percentage increase in contact area: 890% |
01-10-2021, 08:52 AM | #75 | ||
Rep 5,874
lol nice work. |
Boxer63.00 |
01-10-2021, 09:03 AM | #76 | |
Rep 3,218
Drives: 2018 BMW 440i GC
01-10-2021, 09:45 AM | #77 | |||
Rep 5,110
Forgot that facts and math are not the recipe for making a case on the interwebz... 😉 |
01-10-2021, 01:41 PM | #78 |
General
21121
Rep 20,741
They might not have many other choices to balance the handling, given the G8X is carrying more weight on the front axle. I have to say though, I do appreciate the 19"/20" setup on my M4cs...
antzcrashing1910.00 |
01-10-2021, 02:42 PM | #79 | |
Rep 7,037
ram9cc96.50 |
01-10-2021, 03:29 PM | #80 | ||
Rep 14,115
Drives: G82 M4C X-Drive
However, you can increase contact area simply by increasing deformation by softening the material. On a wheel, this might not be ideal because of decreasing sidewall rigidity so they increase the wheel diameter to decrease sidewall height to allow for tire deformation without losing sidewall rigidity. Or lower pressure and more deformation for increased tire patch without losing sidewall rigidity.
solstice5457.50 |
01-10-2021, 04:37 PM | #81 |
General
21121
Rep 20,741
Indeed. And it is all accurate when increasing tire rolling diameter...
01-10-2021, 04:41 PM | #82 |
Rep 7,037
I’m getting more and more convinced that lemetier is deeply involved in the development/testing of M cars and I highly doubt this was a generic statement. We asked for more information from BMW about the G8X staggered setup and I believe this is it. I’m not going to expand on how since I risk diluting or misleading the crisp and clear comment made. I leave that to lemetier if he so chooses.
ram9cc96.50 |
01-10-2021, 04:43 PM | #83 | |
General
21121
Rep 20,741
As I posted earlier, a tire with a larger rolling diameter will provide a meaningfully larger contact patch for the same radial deformation. If you do the (simplified) math for the 991 to 992 rear tire example, going from a 305/30R20 to 305/30R21 yields a ~2% longer contact patch (assuming all else is equal). And if you think 2% is negligible, consider a 315 is only ~3% wider than a 305. R^2 = (R-d)^2 + (L/2)^2 Where:
In the real word, it is way more complex than this due to all the other variables at play, but it give an appreciation. If you want to have fun, have a look at this site. I am not sure how accurate it is, but fun nonetheless: http://bndtechsource.ucoz.com/index/...alculator/0-20
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-10-2021 at 09:21 PM.. |
jmg18710.50 |
01-10-2021, 05:33 PM | #84 | |
General
21121
Rep 20,741
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-10-2021 at 11:20 PM.. |
solstice5457.50 |
01-10-2021, 05:55 PM | #85 |
Rep 7,037
I can see that with your thirst for knowing how with detailed scientific validation. Not so for me, I want to know why and I’m satisfied with a short explanation. His response clearly states why and by that I also know what the benefits are.
ram9cc96.50 |
01-10-2021, 07:46 PM | #86 | |
General
21121
Rep 20,741
Sorry to say, but his answer is not clear at all and is very open to interpretation. You are interpreting what he is saying to justify what you believe. Seeking only sources of information or interpreting according to one's own beliefs leads down a very dangerous path...
Boss3301718.00 |
01-10-2021, 07:49 PM | #87 | |
Rep 7,037
And for not being clear as for the OPs question on why, how can his comment be any clearer than it is to increase the longitudinal and overall circumference of the contact patch? That is why they staggered the diameter. There is no other way to interpret it. Last edited by solstice; 01-10-2021 at 07:57 PM.. |
ram9cc96.50 |
01-10-2021, 07:56 PM | #88 | |
General
21121
Rep 20,741
Boss3301718.00 |
