      01-04-2021, 01:20 PM   #23
heavyD^2
heavyD^2's Avatar
Drives: X3M Competition
Originally Posted by CanAutM3 View Post
OK, explain the physics to me.
Ha ha ha. I can see where this is going. Why would I go through that when there's a wealth of information on the internet supporting this? You can disagree adamantly but then I would simply lump you in with the flat earth crowd and move on.
      01-04-2021, 01:24 PM   #24
CanAutM3
General
CanAutM3's Avatar
Drives: 2021 911 turbo
Originally Posted by heavyD^2 View Post
Ha ha ha. I can see where this is going. Why would I go through that when there's a wealth of information on the internet supporting this? You can disagree adamantly but then I would simply lump you in with the flat earth group and move on.
Because it's urban legend. You can't believe everything you read on the internetz. Regarding flat earth crowd, when pot meets kettle...
A tire's contact patch size is defined by the tire's structure, tread mold and inflation pressure. A lower profile tire does not automatically translate to more rubber on the road.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
Transfer5255.00
Ilyam5896.00
Boss3301718.00
      01-04-2021, 01:25 PM   #25
heavyD^2
heavyD^2's Avatar
LOL and I'm out.
      01-04-2021, 02:09 PM   #26
solstice
Drives: 2015 M3 6MT
You'll have to explain that one to me: how does a larger wheel diameter for a given tire diameter puts more rubber on the road ?
Swedish translation error in my head. Back home wheel is translated to “hjul” rim + tire. I.e. over here I should have said tire diameter not wheel diameter, not the first time this causes confusion for me
I’ve not calculated the exact resulting tire diameter between front and rear in all cars we mention here, I guess I trust Porsche here when they stated the larger contact patch without adding width and resulting added stability of the rear as their reason for staggering them...they usually don’t do things just because fashion.
CanAutM321121.00
      01-04-2021, 02:33 PM   #27
Bimmr7
Drives: E92 M3 Comp/G80 M3 Comp on Ord
2013 BMW M3  [0.00]
2011 BMW 328  [0.00]
2010 BMW 335 M Sport  [0.00]
Originally Posted by Transfer View Post
Yes I did and I agree with that. Like I said in my post so then why a 20" rear?
As opposed to what? If the staggered set up (according to BMW and Porsche) is the ideal set up, and the front diameter is 19 inches the 20 would be the preferred diameter of the rear. Likewise the M-Performance set up is 20/21. I
      01-04-2021, 03:00 PM   #28
CanAutM3
General
CanAutM3's Avatar
I believe the staggered diameter rim is mainly to have different tire sidewall height front and rear. The larger front sidewall improving front grip to reduce understeer and the shorter rear sidewall providing more stability from improved response in transitions.
solstice5457.50
      01-04-2021, 03:08 PM   #29
solstice
Drives: 2015 M3 6MT
That could be it but the Porsche guy specifically said that the reason on the 992 was the larger contact patch on the rear tires that can be achieved without adding more width.
To be honest I’m not all that interested in the exact science behind this I’m more interested in the result. I’m getting impatient for quality reviews
heavyD^23688.50
      01-04-2021, 03:10 PM   #30
heavyD^2
heavyD^2's Avatar
Ha ha ha. Don't poke the bear as some people will argue nonsensically against this.
      01-04-2021, 03:11 PM   #31
mkoesel
Moderator
Drives: No BMW for now
That could very well be.
In any case, it seems at least plausible to me that the car simply performed best with the different diameter wheels, so that's what they went with. That is to say, irrespective of the actual science behind the engineering, sometimes you test several different configurations and go with what works best.
EXE462100.00
      01-04-2021, 03:25 PM   #32
CanAutM3
General
CanAutM3's Avatar
In the 992 does have significantly larger diameter tires in the rear. But that can be achieved without having a larger diameter rim. The different rim sizes are used to alter sidewall height.
      01-04-2021, 03:28 PM   #33
CanAutM3
General
CanAutM3's Avatar
Blissfully ignorant.
chris7197334.00
      01-04-2021, 03:37 PM   #34
Transfer
Transfer's Avatar
5255
Drives: Bronco Wildtrak, Tesla MYP
From the link above:
"Advantages of larger rear wheels in an RWD car?
Having a larger diameter rear wheel increases the amount of rubber that contacts the road along the axis of the vehicle which increases your acceleration potential. When you accelerate, much of your vehicle's weight shifts to the rear. By comparison, the front wheels don't need as large a contact patch to take care of steering and braking."
In summary more rubber to the road.
I did read that and disagree with it. Wheel diameter means nothing to this because if the tires are the same diameter then contact patch is not increased. The Lambos might have larger diameter rear tires but even if they do, a 1" taller tire won't add much to the contact patch. The tire width counts substantially more.
G8x has equal front/rear tire diameters so that is irrelevant.
Ilyam5896.00
      01-04-2021, 03:41 PM   #35
solstice
Drives: 2015 M3 6MT
It can with different tire profiles but again he did state the larger contact patch as an explanation to why they had staggered wheel sizes.
They wanted more contact patch and likely tried all options as wider wheels, more profile at the same wheel size and larger wheels and the best overall results were achieved with larger wheels.
I don’t think the main target was a lower profile rear tire instead it was a larger contact patch. The sidewall was likely just tuned as a secondary parameter.
For the G8X we haven’t gotten a detailed explanation to why it ended up were it did. Your guess is as good as any. I think mkoesel is close to the truth that this is more an empirical result of testing than a formula based decision.
heavyD^23688.50
      01-04-2021, 03:41 PM   #36
CanAutM3
General
CanAutM3's Avatar
Originally Posted by BBoyM3 View Post
I found this on the Lamborghini of Palm Beach website. It discusses the rear wheel diameter:
https://www.lamborghinipalmbeach.com...o%20the%20rear.
The UK product manager explains the front wheel diameter for the M3/M4 at 2:43:
Funny tidbit, the "product manager" says the ZF8 gear ratios "are very specific to these cars (the G8X)". That's The G8X shares the same gear ratios as all other 8HP75/8HHP50 ZF8 applications .
Just shows how you can't rely on everything you hear, even if it seems from reliable sources...
solstice5457.50
Remonster824.00
Boss3301718.00
      01-04-2021, 03:43 PM   #37
Transfer
Transfer's Avatar
5255
I'm still gonna stick with they did it because it looks cool and has no ill effect on the car. Plus they can ramble on about improved turn in up front (presumably compared to a 20" front wheel). The G8x design is clearly about brash looks and 19" front/rear doesn't fit that theme.
      01-04-2021, 03:57 PM   #38
solstice
Drives: 2015 M3 6MT
Well, I did check when I drove the 992. It really has staggered wheels
CanAutM321121.00
      01-04-2021, 04:03 PM   #39
CanAutM3
General
CanAutM3's Avatar
They did increase the tire diameter stagger significantly on the 992 (5.2%) vs the 991 (1.4%). They learned that from the 991.2 GT2/3RS . OK, so in the case of the 992, lets say you want a larger rear diameter tire but do not want to increase tire sidewall too much relative to the front to maintain response balance, how would you do it ? Of note, the G8X has less than 1% tire diameter stagger.
While we do not know the specifics of the G8X tire engineering, I did read up a lot about my M4cs, which also has staggered diameter rims.
      01-04-2021, 04:04 PM   #40
CanAutM3
General
CanAutM3's Avatar
Your own eyes is definitely the most reliable source
solstice5457.50
      01-04-2021, 04:06 PM   #41
heavyD^2
heavyD^2's Avatar
Dude it was not my intention to make you feel stupid. I just answered your question accurately and here we are.
      01-04-2021, 04:08 PM   #42
CanAutM3
General
CanAutM3's Avatar
False...
      01-04-2021, 04:10 PM   #43
heavyD^2
heavyD^2's Avatar
False...
True: You asked a pretty obvious question (in automobile circles) and didn't like the obvious answer even after another poster has continuously posted Porsche did this specifically for the larger contact patch. Just give it up as this is childish.
      01-04-2021, 04:14 PM   #44
jmg
jmg's Avatar
18711
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
I haven't watched the video and I am no expert, but this is my take on it:
The increased contact patch from increasing diameter is minimal. Tire width is what actually effectively increases contact patch (and in turn the wheel width to accommodate the tire). But with an increased tire and wheel width, comes an increase in rubber, which increases tire deflection on load at a given tire pressure. This gives more grip but sacrifices responsiveness as CanAutM3 pointed out. To help balance this out, we can use a bigger diameter wheel to decrease the tire sidewall which will decrease deflection but maintain the contact patch. So no, WHEEL diameters do not increase contact patch, but they can allow for a wider tire without excessive tire sidewall.
Additionally, having a larger overall diameter wheel/tire combo changes the overall driving ratio of the car. A larger tire means a higher potential speed. I don't know if the G80's rolling diameter will be more than the fronts because I am too lazy to look up the tire sizes, but that would be one potential reason for using a larger rear wheel.
These arguments about the increased weight of larger rear wheels are kind of ironic given BMW increased the weight of the G80 by increasing its size, which isn't as correctable as new rims.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
Remonster824.00
