11-17-2022, 08:19 PM | #1 |
Rep 302
2021 G80 Manual Engine Vibration 1,800 RPM
I just noticed today I am getting a vibration from the motor to the drivetrain inside the car when I gently rev the motor up and when I hold the throttle at 1,800 RPM and around 2,500 to 3,000 RPM. When I'm stopped in neutral and in gear with the clutch pressed in. It's an obvious vibration.
The second issue I'm having is when I cold start the engine I hear a ticking noise. Could that be the oil the factory uses? |
11-17-2022, 09:25 PM | #2 |
Rep 6,593
Don’t sit and rev at those rpm. Problem solved.
Also, go to the dealer. |
11-17-2022, 10:25 PM | #3 |
Rep 3,421
Engines have explosions and stuff going on inside them. Vibrations and reverberation at very specific RPMs are normal. Most new cars also sound like a clapped out diesel econobox during cold start. That’s pretty normal, too.
nunzo760.50 |
08-02-2023, 10:06 PM | #4 |
Rep 302
08-02-2023, 10:09 PM | #5 | |
Rep 302
You explanation is funny and way off. Harmonic vibration can cause many issues. I was just wondering if anyone else was having the same problem. |
08-03-2023, 09:17 AM | #6 |
Rep 191,065
You can have the car checked by your mechanic, but they likely won't find any issues with it. Your dealer is right, its normal.
08-03-2023, 03:39 PM | #7 | |
Rep 302
My CTSV, GT350, Z/28, S2000, STI, GTR, never had those issues. The problem is vibration from the motor or clutch assembly can ruin the rod and crank bearings. |
08-05-2023, 11:17 AM | #8 |
Rep 477
I get a little vibration at idle. Comes and goes. It’s done it since day 1 and my f80 was the same. Once I’m moving it goes away, but I can still feel a little in the shifter. IMO normal
08-05-2023, 11:41 AM | #9 |
Rep 302
08-05-2023, 04:00 PM | #11 |
Rep 302
I have had twin and triple disc clutch’s from Exedy,Carbonetics, and Tilton never had that issue. It still vibrates when engaged. Hopefully it’s not an issue. Vibration can also cause the transmission input shaft to vibrate which can also effect engaging into gear at high RPM.
08-07-2023, 09:54 AM | #12 | |
Rep 192
But did the cars you put them on have dual mass flywheels? I am sure it's nothing to concerning, luckily you have a warranty if something fails! |
08-14-2023, 08:31 PM | #13 | |
Rep 302
The flywheel design can possibly be it as others have mentioned. It’s dumb that would cause a vibration because vibration is not a good thing |
08-14-2023, 09:19 PM | #14 |
Rep 739
08-15-2023, 04:24 AM | #15 | |
Rep 151
Kirill @ OdinTuned
08-15-2023, 09:20 AM | #16 |
Rep 302
08-23-2023, 09:16 PM | #17 |
Rep 19
I'm having a similar issue, but mine just started at 24K miles. Shortly after my recent scheduled oil change, spark plug and air filter replacement I'm experiencing an overall rougher ride, and vibrations.
Everything was running smooth until now. Now at around 2800-3000 RPM's I feel a slightly rougher engine rev than before. Also the overall feel of the engine has changed and just feel off. I wonder if this is due to wrong oil, wrong spark plugs, or filter? I'll be taking it back to the dealer to get it checked out, but not feeling too confident they will identify the issue. |
08-24-2023, 01:51 PM | #18 | |
Rep 302
Akrem346.50 |
02-10-2024, 02:14 PM | #21 |
Rep 302
