02-03-2024, 09:54 PM | #1 |
PC
53
Rep 53
Drives: 2024 M3CX
Wheel Bolt Length Question - odd spacer width
Adding 13mm h&r spacers to the front track of 24M3CX. I thought rule of thumb was extended bolts longer by wheel spacer width, but I find conflicting info on stock bolt length (27 vs 28mm).
Will 40mm 14 x 1.25 extended lug bolts be sufficient length/size (based on 27mm stock)? Or should I find a longer (41/42mm) option somewhere? Does that 1mm make a difference? Thanks.
'12 F30 335i (Mineral Gray, Black, Sport Pkg), '15 F32 435i (BSM, Black, MPPK), '18 G30 540i (BSM, Black Nappa, M Sport), '21 G05 X5 x40i (BSM, Tartufo Merino, M Sport)
'24 G80 M3 Competition (DG, SS Full, xDrive) |
02-04-2024, 06:28 AM | #2 |
Rep 477
When I originally purchased 12.5mm Spacers, 14x1.25x40MM was the bolts that came with them.
Now I know that doesn’t exactly answer your question but it gives you some more info to consider. Another 0.5mm spacer, surely these would work with 13mm, but that’s just my opinion and no data or experience to support it. |
