07-07-2023, 03:17 PM | #67 |
Rep 57
Drives: BMW M3 Comp xDr
Yo, I've went through this whole thread and have had a question since you're original comment.
What about swapping out the white DRL boards (in my case for yellow boards)? Would you also not mess with that element of the exterior lighting system? Or is that way less of a concern then swapping in AM plug&play head/tail light housing assemblies? My intention is to buy 4 full module/board assemblies (ie, w/ the boards already heat sunk to the modules), swap those in, and store the OEM assemblies. Sorry for the off topic Q here, y'all. Just need a quick yes/no/maybe from the tier 1 auto mfg retiree. |
07-07-2023, 05:57 PM | #68 | |
Rep 441
View post on imgur.com They are the same as bayoptiks. I can get you connected to the guy who I bought from directly. I think was $7xx shipped. |
Limegrntaln13504.50 |
07-08-2023, 09:25 PM | #69 |
Rep 61
Drives: 2021 Mineral White M440i
They look great! Any issues with fitment? Was it the DHGate link you posted? I am torn between the smoked ones over the red. Afraid they might not be bright enough compared to the red lenses
07-08-2023, 09:59 PM | #70 |
Rep 441
[QUOTE=den110;30290697]They look great! Any issues with fitment? Was it the DHGate link you posted? I am torn between the smoked ones over the red. Afraid they might not be bright enough compared to the red lenses
No fitment issues, I would def go for the red ones. Smoked are hard to see in any configuration of BMW lights. Yes that DH gate link but I contacted the seller directly on WhatsApp and worked through final cost etc - great guy. |
07-08-2023, 10:03 PM | #71 |
Rep 441
Still photo
element561091.00 Laguna01///M31397.50 |
07-09-2023, 09:28 AM | #72 |
Rep 61
07-10-2023, 12:37 PM | #73 | |
Rep 2,135
I'm still on the fence whether I should switch out the OEM boards or not tbh... I'm more concerned that it won't have the same output as the OEM LEDs. (I have the very early version) As for having issues, as long as it's properly affixed to the heat sink and sealed/installed correctly, I wouldn't think it can cause much issues, if any. |
J_Supplanter59.50 |
07-10-2023, 12:44 PM | #74 |
Rep 57
nearwater4me thanks, mans. I'm looking at ice driver's assemblies on AliExpress. 120 USD total for all four modules and boards. Others on here have installed without issue (yet) and a reputable vendor per AE's stats. However, seems suspiciously inexpensive, perhaps cheap. No?
07-15-2023, 04:47 PM | #75 |
Rep 140
For that have done this and have run them for a bit, are they holding up? Are they bright enough during the day time to be safe (as bright or brither than stock)? Any pics of them in the day time?
07-21-2023, 09:57 PM | #76 |
Rep 61
Just installed.
07-21-2023, 11:05 PM | #77 | |
Rep 1,369
2021 ///M3
2019 X3 |
thatguyM4202.00 |
11-16-2023, 10:44 AM | #81 |
Rep 176
Installed mines also and i have 3 different versions which i'll post later so you can see the difference of them so many out there
11-20-2023, 12:03 AM | #82 |
Rep 176
11-22-2023, 11:58 PM | #84 |
Rep 176
well guys finally cracked it got it working with no issues , no error codes , nada .... took me a while to do but like I was sayin there is 3 different versions I have I'll post them later as I got Black Friday going on - So here's the you tube Link Im going to build a harness for this taillight so its as simple as can be
https://youtu.be/55HVOaxXIsU?si=HO5BZ_jxcylD68uF |
11-23-2023, 04:11 AM | #85 | |
Rep 176
Heres the video working in action https://youtu.be/55HVOaxXIsU?si=NfM2opraPQQgkhPG |
11-23-2023, 09:49 AM | #86 | |
Rep 61
thatguyM4202.00 |
11-23-2023, 01:12 PM | #87 | |
Rep 176
den11031.50 |
11-27-2023, 05:57 PM | #88 |
Rep 176
So i have been working on the coding for the CSL Style Tail Lights and got it now Im working on a plug and play no coding needed and I think I did it again but need to find a G82 in the Bay Area to Test it
