01-10-2022, 04:24 AM | #1 |
Rep 10
6MT auto hold
Does anyone know of a way to disable auto hold on 6MT? I would much rather manually control whether my car rolls back or not.
The owner's manual says there's a button for automatics, but there's no information for their manual brethren. I looked through iDrive car settings but didn't see anything. |
01-10-2022, 05:04 AM | #2 | |
Rep 1,661
That's different from Auto Hold, which prevents BMWs with automatics from rolling forward without the brake pedal depressed. |
01-10-2022, 06:13 AM | #3 |
Rep 10
Thanks for clarifying. I didn't even realize that the automatic's Auto Hold feature had a totally different intent.
So for the feature I meant to refer to (which I'll just call hill assist), I take it there is no configurability? |
01-10-2022, 07:15 AM | #4 |
Rep 957
Funny you mentioned this as this is the first manual I have owned with auto hold. Honestly at first I hated it and was harder for me to get initiated up a big hill without over reving, etc. now I have it figured out and think it's a pretty cool feature, but not sure how or if you can deactivate.
I'll never forget my first manual and getting on steep hills only to stop at a light with the car behind me on my ass. Also make me nervous as hell until I get used to it.
[/SIGPIC]
maelfyn156.50 |
01-10-2022, 08:25 AM | #5 |
Rep 2,138
Funny, I noticed mine does NOT engage the auto hold and rolls back a little on uphills.
But then, I've only driven my car a couple of hundreds of miles so far so I may have not met a steeper hill that triggers this feature. It definitely does not engage as often as my previous F87 for sure. Doesn't bother me much but it's something I've noticed on my G82. |
01-10-2022, 09:37 AM | #6 |
Rep 1,334
If you come to a complete stop and release the brake it holds for 2 seconds. If you don’t come to a full stop using the brakes, if you touch the brake again after releasing, or if you move forward at all, it will cancel the hold. There is no setting to turn it off but it’s pretty non- intrusive.
NightWriter4844.00 |
01-10-2022, 03:11 PM | #7 |
Rep 50
... adapt...
I'm guessing you don't live in sf where having to do a hill stop in a manual with a parking brake is a pain and having the benefit of a double tap on the brakes and not needing to burn the clutch to get started is a plus. |
01-10-2022, 05:28 PM | #8 |
Rep 453
I don't believe you can turn it off. Of the many modern manuals I've had that have this feature, I find the G80's hill hold assist to be the least intrusive (as someone stated above), the most predictable, and frankly the least offensive.
01-10-2022, 05:33 PM | #9 |
Rep 17,396
As far as i know, no. But it helps especially parking on hills in the city.
01-10-2022, 05:34 PM | #10 | |
Rep 17,396
The hill assist is awesome when parking in the city...but then you gotta worry about those who just bump your car to get into a space |
ram9cc96.50 |
01-10-2022, 06:19 PM | #12 | |
Rep 453
Not sure if you're on a downhill facing forward, clutch in, shifter in reverse, whether it holds you as you come off the brake pedal to back up. I've had cars that held in both directions, and some that don't. Need to try it out. |
01-10-2022, 06:46 PM | #13 | |
Rep 50
This car really is generous to a manual transmission driver - none of my other cars, all manuals save one, have been so easy to crawl around in traffic. The hill hold i got used to in my first WRX STI. Its really pleasant when one lives on a hill, parks on a hill and drives around San Francisco. Thats just me - i'm not interested in working against such an intelligent design 🙏😂☺️ |
01-11-2022, 07:57 AM | #14 |
Part Time Firetruck Crash Barrier
792
Rep 1,567
You have multiple options if for some reason you want to roll backwards on public roads without your reverse lights on in a world where 99% of other drivers do not understand what a manual transmission is or does, or what its purpose may be:
All of these scenarios will result in you rolling backwards down a hill towards whatever end that may serve. Hill assist, while a little weird, takes away the need to use the e-brake on a particularly steep hill (especially when a dumbass is sitting right on your bumper behind you). I never found it to be invasive on any of my BMWs. The final note i'll leave you with is that playing with brake pressure did actually impact the engagement on my F80. . . I can't comment on the G80 programming yet, but if you lightly depress the brake, hill assist generally won't kick on. You have to get to like 20%/25% depression. Try playing with the brake depress amount as noted above on a hill (with no other moron drivers around) and see what happens. Also confirm that the neutral/in gear requirement is still in effect in the G80. Hope this helps a bit!
m340ix Mineral Grey/Tacora Red |
01-12-2022, 02:12 PM | #15 | |
Rep 375
Flying051307.00 |
01-12-2022, 08:50 PM | #16 |
Rep 10
Thanks for the detailed breakdown on how it engages. I’ll just get used to it. Shouldn’t be a big deal.
I was mainly unnerved when it was kicking in on a very very slight grade in a parking spot. It was the first time I experienced hill assist and I thought I was colliding with the parking block or something worse. Also takes some getting used to creeping forward very slightly on a shallow slope. |
01-12-2022, 09:06 PM | #17 |
Rep 742
10-27-2023, 07:28 AM | #18 | |
Rep 1,669
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
10-27-2023, 07:39 AM | #19 |
Rep 1,439
It's not as necessary. If you're on flat ground, you won't roll anyway. Unlike in an automatic, when you will always roll unless you happen to be on a steep enough upslope to counteract the torque converter.
