09-02-2022, 03:09 PM | #23 |
Rep 2,814
UPDATE: So the dealer has had my car for a week now. They say that 100% the problem is not with the braking system. The regional BMW tech asked them to reset the transmission "adaptions" and that did nothing. Now they had them unhook the transfer case thinking it might be a problem with the AWD system (which I told them when I brought the car in that the problem occurs both in AWD and 4WD Sport modes). Anyway, they disconnected the transfer case and the problem still exists. Now they are waiting for the regional tech to tell them what to do next and since it is a holiday weekend, I am probably looking at least another week with no M3. All they have been able to determine for sure so far is that a) its not a brake system problem and b) the problem is more noticeable when it is hot out (which I already told them when I brought the car in). At least they gave me a new X5 loaner that uses 2x as much gas for the same amount of driving as my M3 does
09-04-2022, 02:04 PM | #24 |
Rep 673
I'm having the same issue now, haven't went to the dealer yet. Really interested in what they find out about your car.
Realtor, Architectural Engineering
Remax 200 Realty Winter Park, FL |
09-04-2022, 06:58 PM | #25 |
Rep 2,814
Ill post another update. At this point my SA is not making me feel confident that this is going to be resolved this week. His last comment was “I’d contact BMW if I were you to see if you can get some credit for that amount of time we will ultimately need to figure this out.”
JoNaH279.00 |
09-04-2022, 09:11 PM | #26 | |
Rep 673
09-05-2022, 06:55 AM | #27 | |
Rep 371
Drives: 2022 M4 Convertible
Is this an exaggeration? (Statement in bold). My M4 can suck down some gas in the right mode. I am surprised an SUV with a 22 gallon tank compares to our G8X vehicles in range per tank. I would not be happy. |
09-05-2022, 06:28 PM | #28 | |
Rep 2,814
M4ord805.00 |
09-06-2022, 10:23 AM | #29 |
Rep 371
Thanks for the reply. Hope I didn't come off as dismissive, I was just surprised by that statement based on my own assumptions. Good luck with the original brake issues.
09-07-2022, 05:03 PM | #31 |
Rep 2,814
UPDATE 2: Apparently they have determined they need to replace both my engine mounts. Parts won’t be here until Friday. Based on how quickly this service department usually works, I’m mentally preparing to have no M3 until at least next Monday.
T0RM3NT3731.00 |
09-07-2022, 11:05 PM | #32 |
Rep 673
Wow, glad to hear that it's nothing too crazy. Mine is only doing it every blue moon now. Wondering if it's worth going in for. Might stop and speak to the service manager and see what he thinks after I mention your car.
09-08-2022, 12:13 AM | #33 |
Rep 2,814
Not too crazy? I mean I guess it’s better than having to replace a transfer case or something but it still sounds major to me. I hate the idea of some stateside tech that has barely worked on our cars doing this.
09-08-2022, 01:29 AM | #34 | |
Rep 673
09-09-2022, 09:34 PM | #35 |
this is the way
18366
Rep 8,565
This thread is giving me flashbacks to an issue I had with my previous E92 335is. There are many similarities to what you're describing. I even had a PuMA case opened on that car. It had similar symptoms with vibrations and shuddering when the car was fully warmed up. Sometimes it would be very prominent, but other times not so much. They checked for bad pulleys, replaced engine belts, replaced engine mounts, etc. to no avail. In the end it turned out to be an oil return line from a front heat exchanger which had come lose from its clamp and was resting directly on the chassis. The pumping action of the oil through the line transferred vibrations into the chassis. This also made sense why it only happened once the car was fully warmed up. It took them over a month to figure this out, but it was an easy fix once they knew what it was. If replacing your engine mounts doesn't address your issue maybe you should ask them to look into the oil cooling system. Good luck.
09-09-2022, 10:10 PM | #36 | |
Rep 2,814
Did your situation happen only when braking? |
09-10-2022, 12:33 AM | #37 | |
this is the way
18366
Rep 8,565
It was a weird issue on my previous car. Sometimes it would vibrate, other times it felt like pulsating or shuddering and at other times it wouldn't do it at all. The technician believed the hose was probably moving around from the pumping action of the cooling system and from the normal temperature cycles of the car. So sometimes the hose was right up against the chassis causing a good amount of vibrations, shuddering and other times the hose may have moved and I only felt about 50% of the vibrations. Other times yet I noticed nothing at all. But I would say it had some sort of vibrations in the cabin roughly 75% of the time. |
KANdaddy2505.00 |
09-10-2022, 08:50 AM | #38 | |
Rep 2,814
09-10-2022, 02:51 PM | #39 |
this is the way
18366
Rep 8,565
09-11-2022, 12:45 AM | #40 |
this is the way
18366
Rep 8,565
KANdaddy look what I found. I can't download the attachment referenced in the doc which should better describe the problem and how to resolve it, but it looks like this is the issue you're describing. Hope this helps.
09-11-2022, 11:42 AM | #41 |
Rep 673
Really interested to see if the engine mounts solve this. I'm having a similar issue and want to see what resolves yours so when I go in I can show them this instead of them messing around for 2 weeks.
09-11-2022, 09:42 PM | #42 | |
Rep 2,814
I will definitely be updating everyone here. Hopefully when the time comes, your techs will be open to looking into whatever is found with my car as a starting point.
09-12-2022, 11:10 AM | #44 | ||
Rep 673
