02-07-2023, 07:07 PM | #1 |
Rep 1,161
M Performance Suspension Install Cost at Port
Has anyone had the M Performance HAS kit installed at port prior to delivery? My SA just quoted $2820 for it. I’m debating doing it because it will be warrantied for the full factory warranty period.
Is that price reasonable? How does it compare to those that have had it installed by the dealer or an Indy after delivery? Also, I’m not looking to slam the car at all, just want to lower front to match rear gap and benefit from some added tightness from the M performance suspension. I’m coming from a Porsche with PASM and the suspension/chassis was my favorite part of the car. Any thoughts? |
02-07-2023, 07:12 PM | #2 | |
Rep 180
Please read through this post, you will find a lot of help. Good luck |
02-07-2023, 07:25 PM | #3 | |
Rep 1,161
02-07-2023, 07:57 PM | #6 |
Rep 497
02-07-2023, 08:03 PM | #7 | |
Rep 180
On my F80 I got the KW kit installed from a local shop paid $300 and never had any issues. Good luck |
vmalho2703.50 |
02-07-2023, 08:26 PM | #8 | |
Rep 488
Hey, so Fugly M3 (sorry for the tag) got his installed at the port and that price is correct. I believe the code was Z58 Option Code which your CA has to look into if this is something you want done at the port. There will be some minor delays at the port if you go this route. I originally was going to do this, but I decided to just order the kit and get it installed at an indy shop near me for way less. I also tried asking the dealer to get it installed, but their cost ($1800) wasn't adding up and not worth it IMO. |
fanofbmwe462098.50 Limegrntaln13562.00 |
02-07-2023, 09:45 PM | #9 | |
Rep 5,154
It’s not that much work…it’s do you have the CA who is willing to do the work or research. And yes, it’s option code Z58 or 0Z58 it sometimes reads.
vmalho2703.50 Limegrntaln13562.00 |
02-07-2023, 10:03 PM | #10 |
Rep 8,082
Drives: 2024 X5 M60i
Pretty sure the port will just do it to BMW specs, which is a 10mm drop.
02-08-2023, 02:28 AM | #11 |
Rep 417
$3k seems a lot considering the part retails for $1700. Aren’t port installed parts no cost labor? Or does that only apply to cosmetic parts like lips, side skirts etc.
02-08-2023, 03:04 AM | #12 |
Rep 7,004
Much cheaper than ordering them with the car. But, there are some caveats to ordering them with the car. You can finance the price into the car, they should come on the window sticker. Maybe Fugly M3 can show us that.
It would be cool to see. You can also residualize the cost into a lease, if you're leasing, and just overall not having to mess with it, when the car gets here. I paid about $1,250 to get them to my door, from Germany.
YT: G Dubyou |
vmalho2703.50 |
02-08-2023, 07:47 AM | #13 | ||
Rep 5,154
Is the price reasonable? That depends on you and your definition of reasonable. I thought it was a steal. Assume you can get the parts for $1,250 to your door like Limegrntaln. (He was the guinea pig for US install period, I believe. He ordered it well before it could be specced at port.) What will the install cost you? If you're having it done at the dealer, as is required for warranty coverage, expect there to be no difference in overall cost. If you have it installed at an indy shop, expect to save a few hundred dollars. If not doing it at the port, you also have to decide, can you really trust the dealer to install this vs. a good indy shop? If you get it installed at an indy shop, and for whatever reason completely unrelated to the HAS kit, one of your electronic dampers craps out on you under warranty period. Sure, the law says BMW can't deny the warranty unless they prove the aftermarket part did it - remember they're now looked at like eBay springs because they weren't installed at the dealer. In practice, if they weren't installed by the dealer, they'll void first and have you fight it out. Likely, you'll realize the cost to fight it is more than the cost to fix it, stick your tail between your legs and pay. If you want to save money, buy aftermarket and have in installed at an indy shop. You might save $500-750 given the labor time. To me, a warrantied, port-installed setup was well worth the money.
vmalho2703.50 fanofbmwe462098.50 Jackie Chiles999.50 Callmeracerb3.00 AP's G8067.50 Adcampo888.50 nizona31.50 harperium1319.00 |
02-08-2023, 07:59 AM | #14 | |
Rep 699
If they deny a suspension warranty after I install the kit. I won’t even threaten the dealer. I’ll just go on line and file. Then wait for the call and apology from the service director. At which point I’ll ask when my car will be ready… |
02-08-2023, 08:23 AM | #15 | |
Rep 1,161
How many miles do you have on your car now? Are you happy with the M Performance suspension. I feel like I’m looking for the asthetic benefits more than anything. I’ve never drive a G series BMW so not sure what it’s like stock vs with this upgraded suspension. I had an F80 and it was fine for me, didn’t need it any stiffer than stock. One advantage to doing it after delivery is you can keep your stock springs and swap back if ever desired. I could also see how the look and feel is before changing anything. But agree the warranty benefits of port install are super compelling and cost difference minimal. Biggest cost difference would be if I was good with the feel and just wanted simply to lower front by about an inch.. the eibach front springs and minimal cost to install would be the most economical route. And perhaps if a suspension component ever went bad.. I could swap out the springs to stock for minimal cost and bring it in for dealer warranty repair. |
02-08-2023, 08:26 AM | #16 | |
Rep 1,390
Drives: 2020 X3MC
02-08-2023, 09:31 AM | #17 | |
Rep 5,154
02-08-2023, 11:16 AM | #18 |
Rep 1,161
Thanks. Did you make any adjustment to height after delivery? If the front gap is high for a stock car and then coilovers lower the same amount front and rear, does that mean the front still has a larger gap? I’d want to get similar gap front and back which would require more lowering in front and less lowering in back.
02-08-2023, 11:18 AM | #19 |
Rep 7,004
This thread is turning into a duplicate of my already lengthy thread on the same subject. But.
https://consumer.ftc.gov/articles/au...vice-contracts
YT: G Dubyou |
02-08-2023, 12:08 PM | #20 | |
Rep 699
They have to show up and explain why the law doesn't apply to them? Because they sure can't prove my install is any different than their technicians install. And if the part is covered with their install why not my install? I would frame that judgement and hang it in my office. |
Jackie Chiles999.50 |
02-08-2023, 06:22 PM | #21 |
Rep 5,154
fanofbmwe462098.50 |
