05-14-2023, 08:42 PM | #1 |
Rep 35
M4CSL Steering Wheel fit M4 Comp with driving assistant professional option??
Hey guys, anyone fitted an M4CSL Steering wheel to an M4 Comp with driving assistant professional option ??
According to IND's website it won't fit... However I can't see why not if I just use my existing carbon button faceplate, i.e. just change the actual Wheel only and use my Carbon button faceplate. Anyone done this yet? Mark. Last edited by MarkyB656; 05-14-2023 at 09:03 PM.. |
05-14-2023, 08:47 PM | #2 |
Rep 752
Drives: 22 M4c vert
Pro tip - you can retain your advanced driver assist by buying an emulator module that makes the system believe you have your hands on at all times.
05-14-2023, 08:51 PM | #3 |
Rep 35
Oh so "My" wheel has some kind of hand sensor on it? ok well that will make it a bit harder... Any tip on where to get this emulator module from? thanks
05-15-2023, 04:41 AM | #4 | |
Rep 752
Drives: 22 M4c vert
https://www.ebay.com/itm/37406158738...&segname=11050 Have one in my car, and it works perfectly |
05-15-2023, 07:10 AM | #6 | |
Rep 35
G Series 3' G20 3' G21 3' G28 5' G30 5' G31 5' G38 6' G32 GT 7' G11 7' G11 LCI 7' G12 7' G12 LCI 8' G14 8' F91 M8 8' G15 8' G16 X3 G01 X3 G08 X4 G02 X5 G05 X6 G06 X7 G07 Z4 G29 8' F92 M8 X3 M F97 X4 M F98 |
05-16-2023, 05:27 AM | #8 |
Rep 752
Drives: 22 M4c vert
Yep. Before I ordered, I pinged them - they thought the G8x didn't have the option, so it wasn't listed. I gambled and tried, works perfectly. (I then told them it works on the G8x, but they still haven't updated their listing.)
05-16-2023, 09:11 PM | #9 |
Rep 35
Nice do you know what Dip switch setting ended up working for you?
05-16-2023, 11:08 PM | #10 | |
Rep 752
Drives: 22 M4c vert
Aargh should have written it down. I'm 90% sure it was the first option in the instructions, not the "try this if the first doesn't work". Nice part is that you don't have to pull the whole wheel to change it - it's accessible with just the airbag out. |
