07-04-2021, 10:50 AM | #45 |
Rep 2,545
With appreciation to Imran@Evolve for sharing his 1/4 mile data. I compiled the numbers from the first 5 stock runs (before the beta Eventuri intakes were installed) and placed next to the top 8 runs from our Stock X3MC category found in the F97/98 !/4 mile thread [ https://x3.xbimmers.com/forums/showthread.php?t=1444613 ].
Results as predicted but interesting to see actual data showing how 'Cd x A' (and weight) can influence interval times in vehicles with otherwise similar engines. Suspect the AWD may run in the 11.3xx range? Edit 6 Jul 2021 – I appreciate Imran’s PM discussions in which he shared formal drag slip data for his 5 stock runs, the actual DA, his octane rating and his tire psi (OEM standard rec). This has improved the analysis so I’ve replaced the preliminary spreadsheet with this final version. Would be interesting to also add formal slips from a stock X5MC as suspect it should be very close to these ETs. A rather unique collection of vehicle styles and sizes to run such similar fast times. Last edited by Max Well; 07-06-2021 at 08:25 AM.. Reason: Updated spreadsheet with Imran's formal drag slip data |
07-06-2021, 12:02 PM | #46 | |
Rep 1,584
The G80 is building boost until it says "launch control ready" and after the ready message comes up, it has reached whatever boost level they target for the launch and you need to launch within 5 seconds or the system will disengage to prevent excess heat and wear from having the system loaded up for too long. |
07-06-2021, 12:20 PM | #47 | |
1082
Rep 949
07-06-2021, 12:24 PM | #48 |
Rep 494
If awd launches it first gear i think you might be able to get better times if the brake is released during the “preparing launch control” message due to hooking up better.
07-06-2021, 02:24 PM | #49 |
1082
Rep 949
I don't think you will be worrying about traction with the AWD at only 500 HP. Unless the boost is some crazy number on the launch which I highly doubt!!
07-06-2021, 02:27 PM | #50 | |
Rep 10,190
The AWD system from BMW is really good and arguably better than my departed E63S with 4Matic Plus.
07-06-2021, 02:38 PM | #51 |
Rep 280
I have a GTR as well as my M4 Competition. With the GTR in Launch Control one has only 3-4 seconds to launch. If one does not launch within that time frame the launch control function shuts down as a safety precaution regarding the DCT transmission clutch overheating. I learned while at the drag strip to let the other guy stage first therefore I did not have to stay in launch control too long.
07-06-2021, 02:41 PM | #52 | |
1082
Rep 949
07-06-2021, 02:43 PM | #53 |
1082
Rep 949
Yes sir. If anyone has worries, get the R888's and be done with it!!! When those things are warmed up, it's STICKY
