02-23-2023, 07:58 PM | #1 |
Rep 303
Enjoy The Shoot Manual G80
Did a photo shoot Sunday
My White G80 M3 Manual Fall-Line front traction arm spherical bushings, SPL Rear traction Arms, SPL Rear Toe link and Essential Lockout kit, KW Has kit with 15mm rear KW spacer, BMC drop-in filters, H&R 12mm Spacers all around, MHC front lip, Turner duckbill. Should have all the SPL Arms replaced soon. I do all the work myself. |
02-24-2023, 07:25 PM | #6 | |
Rep 750
I'm getting the Fall Line monoballs put on in a couple weeks, I've read that that alone improves the feel. But, I'm skeptical that it will give me what I want. With all of that said, I've considered the SPL hardware if I still feel lacking in the feel department after the monoball upgrade. What are your thoughts on the SPL hardware so far? It sounds like you're doing a couple upgrades at a time, so I'd be anxious to hear about your experiences as you add more hardware.
02-24-2023, 07:49 PM | #7 | |
Rep 303
With the Fall-Line monoballs alone you’ll definitely a big difference with feedback. The steering feels a lot tighter. I love it. The SPL arms also helped with the overall feedback and stability. My cars much tighter all around under braking and cornering. Feels a lot more stable. Definitely recommend it. I did all the work myself and make sure whom ever does the Fall-line front spherical bushing for the front traction does proper work. They would need to completely disassemble the front bumper, air ducts ,braces and a lot of brackets just to get to the bolts that mount to the inner part of the chassis. |
02-25-2023, 02:41 AM | #8 | |
Rep 750
kevin @ eas EAS is doing the install. I'm re-doing the grills and adding a lower rock guard at the same time, so the bumper has to come off no matter what.
02-25-2023, 10:58 AM | #9 | |
Rep 303
You’ll definitely be happy with the results |
m4ml1895.00 |
