04-08-2023, 09:23 AM | #67 |
Rep 2,030
Drives: G80 M3 Competition
Here is how my pipes sit. After realigning the entire setup this morning, I can see how yours could sit lower. If you loosen all 4 clamps, you can rotate the link pipes and get to a position that you like and tighten. As much as this system isn’t very easy to get perfect, I do like there is a ton of adjustability for aligning.
04-08-2023, 01:06 PM | #68 | |
Rep 17,391
04-08-2023, 01:14 PM | #69 | |
Rep 179
2023 Brooklyn Grey Metallic M3 Competition xDrive
Build Progress IG: @g80_arie |
FISH225412.00 |
04-08-2023, 04:54 PM | #70 | |
Rep 328
FISH225412.00 |
04-08-2023, 06:24 PM | #71 |
Rep 2,030
04-08-2023, 06:27 PM | #72 |
Rep 2,030
The trick is slightly bending the steel spring that sits between the controller and valve slot. I was able to tweak mine in a vice so the left valve is fully closed now while in comfort. Slight fluttering sounds there (bypassing, OEM exhaust does this slightly as well) but nothing like it was with the big gap before.
hamzag20557.00 |
04-09-2023, 07:35 AM | #73 |
Rep 2,030
First drive this morning, nice deep sound, and this setup looks incredible from the rear! I was expecting it to be a bit louder under load (seemed very loud free reviving), but I think my resonated single midpipe is keeping this quieter, which is ok with me.
My only complaint; I’ve spent a few hours fine tuning the left valve assembly. There’s a very small threshold to get it just right (by tweaking the spring that sits between the valve and controller). Too loose, and you’ll have some bypassing noises. Too tight, and the valve could vibrate against the gate in the pipe. Not a very big deal, and I’ll probably continue to tweak the spring. Overall, very happy with this exhaust. I’ve mentioned it before, but due to the two sections, and adjustable tips, this system has a lot of adjustability. May be annoying to some, but I love that you can truly fine tune this thing to sit how you want. |
04-09-2023, 07:29 PM | #74 |
Rep 179
just placed an order on the midpipe and exhaust. will update once installed!
FISH225412.00 Dinan_Engineering3916.50 |
04-10-2023, 06:27 AM | #75 |
Rep 2,030
For anyone interested in trying this exhaust with valves fully open; it’s not as easy as the OE exhaust. Had some L brackets lying around, reshaped them, and bolted them onto the valve slot.
04-10-2023, 07:35 AM | #76 | |
Rep 3,130
Couple specific points: 1. Rotating pipes typically resolves pipes hanging low and or different levels on either bank of tips. 2. Also note the hangar placement/orientation in the instructions (not fully 90 degree) as that will assist in bringing the exhaust upwards into the body in general. 3. The valve spring may require some light tweaking. It's briefly noted in the instructions but ultimately the spring should be compressed once installed and not fit loosely. If it does fit loosely, it needs to be spread apart a bit is all so there is tension when installed. Seems to be some minor manufacturing tolerance variability in the OEM fixing bow/spring (PN #18307620323). Have been using the same spring for a long time and while rare it has come up on occassion hence the inclusion of the note. |
FISH225412.00 |
04-14-2023, 09:00 AM | #77 |
Rep 2,030
Has anyone with this installed experience any valve rattling? I have fiddled with the springs quite a bit, vertical (stretching) and horizontal (twisting) to put more tension between the controller and valve top slot, and to better align the valve when it's in closed/comfort mode. It's mostly on cold start, but I do sometimes hear it against walls while driving. Seems to be mostly the left valve.
I even ordered two new springs to start from scratch. |
04-14-2023, 01:26 PM | #78 | |
Rep 17,391
FISH225412.00 |
04-14-2023, 04:11 PM | #79 | |
Rep 2,030
The Dinan support team is great and has been a huge help. Worst case, I do a one for one on the rear section. |
04-14-2023, 08:25 PM | #80 | |
Rep 477
04-26-2023, 09:42 AM | #82 |
Rep 3,130
Still unsure which Dinan G8x exhaust configuration is right for you and have queries you need answered?
Is the deeper axle back tone enough? Is there adequate extra volume, and/or an undesirable rasp introduced, with only the X-pipe? Is the full system just too much awesome to handle? Put on your headphones, sit back and prepare yourself for nearly three minutes of sensory magic to help you answer those questions and find your goldilocks setup. Initial post updated to include the additional video as well. |
04-29-2023, 03:15 AM | #83 | |
Rep 179
04-29-2023, 04:03 PM | #84 | |
Rep 17,391
Ariboon379.50 |
04-30-2023, 08:50 AM | #85 |
Rep 1,636
I had the x-pipe installed few days ago. It transformed the sound of the car to what it should have been from the factory. No drone and easy to live with almost stock when the valves are closed and deeper tone with more pronounced bubbles when the valves are open. Very satisfied with the sound. The installation was done at the dealership.
04-30-2023, 03:14 PM | #86 |
Rep 179
Real dumb question since, I had my exhaust installed at a shop due to limited driveway and garage space.
How do you access the exhaust tip clamp/bolt for tip adjustment? I removed the rear defuser and still didn't have enough room from the rear with a socket wrench and/or wrench to loosen the clamps. Or is the only way to drop the whole exhaust but, this does not make sense since the instructions has you install the tips once the system is mounted. Thanks in advanced! hamzag20 FISH22 Dinan_Engineering evoi19
FISH225412.00 |
05-01-2023, 12:17 PM | #87 | |
Rep 3,130
05-01-2023, 05:42 PM | #88 | |
Rep 2,030
I’ve found a ratchet wrench to work well too. Small turns, but it works. |
Ariboon379.50 |
