01-13-2022, 08:48 PM | #1 |
Rep 6,593
Super easy install. Consists of the 4k 2ch setup along with the parking mode battery pack.
Hardwired into the rear fuse panel. Fuse 273 is the perfect accessory fuse to tap into. And a simple ground near the main battery. |
mzcp2692.00 dirtyfreebooter340.50 iviegatron2543.50 HTTP 4102141.50 Vinnrox2503021.50 kgelfen3602254.50 dini_g80188.00 |
01-13-2022, 09:20 PM | #3 |
Rep 6,593
01-14-2022, 05:26 AM | #6 | |
Rep 6,593
The battery was at 0% when I fired it up, and it charged very quickly so I'm not sure it would be necessary if you drive daily. |
02-14-2022, 03:56 PM | #10 | |
Rep 6,593
Just drilled a couple 1/8th inch holes and used some nylon strap to secure them with the velcro between to ensure no rattling. Just wanted things out of the way and if anything spilled in the trunk they wouldn't be impacted. |
nearwater4me1918.50 |
02-15-2022, 07:15 AM | #11 | |
Rep 2,138
Those little cubbies could come handy for small items or groceries. Under the rear deck, not so much. Makes sense to make use of that solid mounting space! |
forza19763399.00 |
07-18-2022, 08:57 AM | #12 |
Rep 298
A bit lost if someone could kindly assist. I'm running the wire through the top pillars but I'm having trouble once I'm getting towards the trunk. Where do I continue the wire to hide it? Also I'm using the battery pack to get power from which I'll leave in the little side compartment but the wires are seen. Please take a look at the pictures I attached.
G80 ///M3 XDRIVE
07-18-2022, 09:31 AM | #13 | |
Rep 2,138
It's a bit tedious removing the liners but not difficult at all. |
