      06-21-2023, 09:34 AM   #1
HXS
Licensed Drug Dealer
HXS's Avatar
Drives: F10 M5
Alignment question.....
I lowered my car with KW HAS suspension and I got an alignment done last year to fix my toe and camber.
Recently, I'd been feeling the car sits a bit too low, so I raised it about one-half inch all around. I know my camber setting has changed, but has my toe setting changed also?
      06-21-2023, 12:42 PM   #2
Skyscraper
Skyscraper's Avatar
2196
Yes. You will have increased toe-in by raising it. A 1/2" raise probably moved the toe 1/8" in. Which will put you at about 1/4" total toe-in from where it was set.
You will get increased outer tread wear with that much.
HXS742.00
      06-21-2023, 05:30 PM   #3
seals9121
Drives: bmw
you will need to redo alignment again if any suspension parts has been change or updated.
if you raise the car , it's likely toe and camber are changed. better redo it to save the tire.
HXS742.00
