03-29-2024, 12:25 PM | #1 |
Rep 269
Control SST valve controller from mirror homelink?
My SST works great for my G82. I have set up the default behavior the way I want.
I did “learn” the remote buttons on my car rearview mirror, the mirror confirms it learned the signal. But for some reason, the mirror buttons are unable to control the SST. The mirror light flashes but the flaps don’t move. I am certain the mirror learned the buttons correctly. I have tried it 2-3 times. Is there any reason the mirror buttons do not work to control the SST? Anything else I can try? |
03-29-2024, 12:35 PM | #2 |
Rep 1,301
Drives: 2024 BMW M4 Base
Nope, just try again. I had mine programmed for full open and stock using the HomeLink.
03-29-2024, 03:30 PM | #4 |
Rep 269
It’s in the trunk…there’s a chance it isn’t reaching but seems surprising. Even if I keep trying it never seems to work…
03-29-2024, 03:31 PM | #5 |
Rep 269
03-29-2024, 04:11 PM | #6 |
Rep 1,301
Clear all the homelink buttons and reprogram.
03-31-2024, 12:40 AM | #7 |
Rep 2,034
Try clearing the homelink and reprogramming it. Also when you reprogram it after youve cleared the memory (long press for 20 sec), remember to not do it again when you are setting up the other buttons. Otherwise the previous one you just set up is erased. I set mine up 2 weeks ago and Im never confident that it worked. I found that while you are programming it once your light on the homelink turns solid green, press it again to confirm it and then you are set.
04-02-2024, 11:24 AM | #8 | |
Rep 2,166
04-02-2024, 09:42 PM | #10 |
Rep 272
Programmed mine this weekend. Works flawlessly and mine is mounted in the trunk in the usual location. Also, if you long press the home link button for 20 seconds, that allows you to reprogram only that button. I just followed the instructions in the BMW manual. I did have to reprogram one of the buttons after the first attempt seemed to not take. I did not want to do a full reset of my home link as first button is already programmed to my rolling code garage door opener which is always a bit finicky to program.
dimab0233.50 |
04-02-2024, 10:36 PM | #11 | |
Rep 2,166
I was told that you have to clear all the in-car homelink buttons before programming the SST, having to reset my previous garage door setting. I guess not. Like you, my rolling code garage door opener is definitely finnicky so I would prefer to just ADD the SST and not start over. So, on that note, did you simply long-press the single homelink button you want to set to an SST button, and then once homelink started blinking rapidly, you then held up the SST remote to the homelink and hold the SST button you want to program to that location? or is there another step? My SST is now installed, and I will soon be programming my homelink...so your post timing was perfect. |
04-03-2024, 10:10 AM | #12 | |
Rep 272
KevinGS3365.00 |
04-04-2024, 10:51 AM | #13 | |
Rep 2,166
thank you |
cozye343.00 |
04-04-2024, 01:57 PM | #14 | |
Rep 2,670
KevinGS3365.00 |
04-05-2024, 12:14 AM | #16 | |
Rep 2,166
I just got the SST earlier this week, and so far I really do like the added exhaust sound when I want it...and I love the optionally loud cold start. |
Berzerker3006.50 |
04-05-2024, 03:25 PM | #18 |
Rep 1,301
I’ve not closed mine yet and it was installed a week ago😂 I think the only time I’d close them was if I went out really early. Even with the valves 100% open this car needs more volume for me. My last midpipe was an ER with no secondary cats or resonator and it was just too raspy. I did not have a valve controller on that S58. I’m thinking single midpipe and the valve controller might do the trick.
04-05-2024, 03:43 PM | #19 | |
Rep 269
04-05-2024, 03:56 PM | #20 |
Rep 1,301
Yes I’m stock for now. My ‘22 X3MC had the ER and no controller and yes, at startup it was obnoxious! I would start and put it right into gear to quiet it down. There were times even once warmed up at certain RPM’s the drone was pretty bad.
04-05-2024, 09:56 PM | #21 |
Rep 272
