10-28-2023, 10:20 AM | #1 |
Rep 5
2024 M4 Competiton Tramlining
Have a new M4 with 300 miles. Not quite tramlining but feels as though ti wants to follow grooves in the freeway. Anybody have this feeling. ? thx
10-28-2023, 10:56 AM | #3 |
Rep 227
Drives: 2024 PB M4 Comp xDrive
I definitely experience the same thing, will look into if any driver assistance helps. I drive with the sport display mode 99% of the time so all driver assistance is off
10-29-2023, 05:04 AM | #4 |
Rep 1,277
Drives: 2024 BMW M4 Base
Make sure “steering intervention” is off. That feature nearly killed a biker on my X3MC. Turned it off immediately and turned off in my G82 before leaving the dealers lot.
mathys202.50 |
10-29-2023, 06:01 AM | #5 | |
Rep 437
My Subaru has a button on the steering wheel for that feature. With the BMW you have to dig through the settings to get at it. I tried to use the voice commands to turn it off and haven't been successful so far. I wonder what other features (such as the auto lane change feature and the one that prevents you from changing into a lane if there is a vehicle in the blind spot) are disabled at the same time. |
10-29-2023, 07:22 AM | #6 | |
Rep 437
10-29-2023, 12:42 PM | #7 |
Rep 301
It could be the steering intervention (turn that off first) but don't forget the M3/M4 has really wide tires all around so they will naturally follow the deviations in the road a bit more. Had this on a lot of cars myself and its nothing to worry about.
natmad667.00 |
10-30-2023, 06:44 AM | #10 |
BMW N00b
124
Rep 78
10-30-2023, 08:29 AM | #11 |
Rep 437
10-30-2023, 12:34 PM | #12 |
Rep 27
It may actually be following subtle grooves/ruts in the pavement. On some highways/secondary roads there are grooves made by heavier vehicles like tractor trailers, etc. The wide track and tires of the M's don't fit in the grooves well and will impact your ability to track straight.
10-30-2023, 06:51 PM | #13 |
Rep 14,115
Drives: G82 M4C X-Drive
I experience this with aggressive ride height and camber plates. If your car is new stock, then it's likely an alignment, but double check your tire pressures too.
If it's lowered, then invest in some SPL Bump Steer Adjustable Tie Rod Ends
