07-24-2021, 04:59 AM | #111 |
Rep 32
I taped a microphone on my rear bumper and took few vids. Sorry for the bumpy videos. Please focus on the burble sound😂
https://www.dropbox.com/sh/8th3hkkw3...0sqQLO-Ia?dl=0 |
skyscraper_g80371.50 |
07-24-2021, 06:46 AM | #112 | |
The Dad
89
Rep 178
Drives: M4 G82 Competition
The Dad was here ?
07-24-2021, 07:01 AM | #113 | ||
Rep 32
Keep pushing I drive dial forward and press MEDIA, HOME, MEDIA quickly. You can be in Speedlock mode and check the below options. I'm in Japan and I don't know if this works in your region tho. |
The Dad88.50 |
07-24-2021, 07:53 AM | #114 | |||
The Dad
89
Rep 178
The Dad was here ?
SG82JP148.00 |
07-24-2021, 08:31 PM | #115 | |
Rep 170
Sincerely yours,
The Meat Man |
07-31-2021, 11:38 PM | #116 |
Rep 474
thx for your videos SG82JP ... immediate noticable diff is the farts on upshifts which I can only hear when pushing full throttle
i will try to get this done soon then
G82 M4C - SPY, YMB extended, 826M Black, Carbon Buckets, Carbon Inlay, Prem Pack, Driver Assist
SG82JP148.00 |
08-10-2021, 10:34 AM | #119 | |
Rep 800
What I end up doing was leave it unplugged and start the car, plug it in right after I press the engine start button, I notice immediate sound difference as if the valves have already opened up fully you might say well it's from cold start but the "grunt" stayed even after a couple minutes In terms of controlling it, when I'm parked on the driveway and I press the "Resume" button on the steering wheel for a couple seconds, I can see the left blinker light blinks twice meaning the vavle controller is working, and if I press the button again for 2 seconds I can see the right blinks twice and I notice the "grunt" is weakened and sound back to stock I must say even with the valve controller set to "ON" the exhaust, sounds throatier and deeper however is still nothing like the sound of some folks on here who modified their midpipes or did resonator/2nd cat delete, it is still very mild. and last but not least I have not figured out how this valve controller works along side with the ASC, my initial observation is when VC is "ON" even with ASC turned off the valves stay open, but I need more observation on this though and hopefully can get some video and post here in coming days
2022 Lexus LC500
2021 BMW M3 6MT 2020 Porsche 911 C4S Cab PDK 2018 Audi R8 V10 RWS RTronic 2017 Porsche 911 C4 Cab 7MT 2009 BMW E93 M3 6MT 2008 BMW E90 335i 2004 Audi A4 1.8t 6MT 2001 VW GTI 1.8T |
08-10-2021, 11:53 AM | #120 | |
Rep 897
The only thing I can think of at this point is that I have coded active sound off and perhaps that is messing with the units programming. If that's the case it's a bummer because I was looking to decrease fake sound/increase real sound with this thing. EDIT: Nope, I reverted it and still nothing, no response at all to Resume button. Last edited by Murf; 08-10-2021 at 12:51 PM.. |
08-12-2021, 12:09 AM | #121 |
Rep 344
You dont have to start the car or do anything with engine on /off / sport. The process is simple:
1. Open the controller from 3 bolts. 2. Turn the valve manually with the pliers to the open position, confirm via visual looking in the exhaust). Use a wire to secure it in that position. 3. Install back the controller with thick spacers and longer bolts so that the motor has clearance and does not touch the valve. Done. The tricky part is to find the bolts that are the same size with factory ones but longer to accommodate the thick spacers (I make some rubber spacers) Last edited by MMnut; 08-12-2021 at 12:49 AM.. Reason: adding photos |
09-05-2021, 04:02 PM | #122 |
Rep 43
The wire method works great. I'm an idiot when it comes to anything mechanical and even I could do it (in about 45 min) Too easy to justify purchasing the valve controller. Sound is WAY better. Resonators need to go next and should be good.
@loanercar
09-06-2021, 02:05 PM | #123 |
Rep 148
Guys just unplug a fuse to leave the flap open, I did this on my friend's manual and the flaps stayed open. It was a 7.5 on the left side of the fuse box. Can someone share a picture of the fuse box I can circle out which fuse to pull.
SG82JP148.00 |
09-07-2021, 03:22 AM | #125 | |
Rep 148
SG82JP148.00 |
09-07-2021, 05:03 AM | #126 | |
Rep 412
09-07-2021, 06:59 AM | #128 |
Rep 2,068
09-07-2021, 07:54 AM | #129 |
2531
Rep 1,908
As has been described previously in this thread in terms of wiring the valve open, the stock actuator never fully opens the valve and the maximal opening achieved is very transient.
If this were not the case, it would have simply been a matter of unplugging the valve actuator with the valves fully open. . . but the valves never fully open unless manually opened. So, regarding pulling the fuse, I am not sure how it would be any different than unplugging the valve actuator? How are you going to get the valves fully open before pulling the fuse? It seems pulling the fuse would require the same process as wiring the valves open. Namely, you would have to remove the valve actuator, manually open the valve fully, then pull fuse (instead of wiring valve open). Further, since the actuator cannot be manually turned to the fully open position, you would still have to leave the actuator off. There is a problem with manually opening the valves fully and not replacing the actuator. The problem is the valves have been shown to ‘flap’ and ‘rattle’ and ‘close’ if not secured in open position with a wire. Again, the actuator cannot be manually turned to fully opened position and, thus, it cannot be replaced to hold the fully opened valves in place. If it could, you would be able to replace the unplugged actuator and not have to secure (wire) the valves open in the first place. Thus, I see no advantage or even effective manner by which pulling the fuse could work? Perhaps I am missing something and look forward to hearing feedback from others. ///AVM Cc vetteflier Last edited by ///AVM; 09-07-2021 at 05:49 PM.. |
09-07-2021, 03:24 PM | #130 | |
Rep 148
09-07-2021, 03:41 PM | #131 |
2531
Rep 1,908
@babyghost
If you read the earlier posts in this thread, many of us have confirmed the valves never fully open and are only open transiently. That is how we know the only way to open them fully is by doing so manually. Plus, you cannot manually open the actuator fully. Honestly, not even sure the actuator is capable of turning to a full open valve position. Hope that helps. ///AVM |
09-07-2021, 05:24 PM | #132 |
Rep 609
No. Valves will never be fully open at the time you pull the fuse. They are only fully open for a split second--under full throttle. That's why I initially used my method to tie them open permanently. And AVM's pictorial is foolproof. Read the thread from the start.
///AVM2531.00 |
