01-11-2024, 09:51 AM | #793 |
Rep 2,673
01-11-2024, 04:13 PM | #794 |
Rep 693
Does this apply to M3 only? Mine is m340i xdrive
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
01-11-2024, 04:52 PM | #795 |
Rep 1,937
01-11-2024, 05:09 PM | #796 |
Rep 2,673
01-11-2024, 05:36 PM | #797 |
Rep 693
Whoops!! Somehow I thought this was in the G20 subforum thanks!
Berzerker3015.50 |
01-12-2024, 04:53 AM | #798 | |
Rep 400
[QUOTE=BIGW0RM;30804213]
BIGW0RM3190.50 |
02-08-2024, 12:24 PM | #800 |
Rep 192
I’m searching but not finding. Quick question! When I Bimmercode a car (M4 for me X3 M40 for my wife) is that coding specific to the user profile at the time or is it global for the vehicle?
Thank you! |
02-08-2024, 01:15 PM | #801 |
Rep 2,673
I'm not really sure what you're asking, but when you connect to the car, it reads all the codes before bringing up the options, backups are saved per VIN (as far as I remember), so if you connect to the M4, it'll pull up all the M4 coding stuff and read your current settings, then if you connect to the X3, it'll read all of that and pull up the codes, etc.
02-08-2024, 03:48 PM | #802 | |
Rep 6,759
I believe they are global to the car, regardless of driver profile setting, but I am not sure as I don't use any other driver profiles other than my own. |
adam12hicks253.50 |
02-08-2024, 03:57 PM | #803 | |
Rep 2,673
adam12hicks253.50 |
02-08-2024, 04:43 PM | #804 | |
Rep 258
adam12hicks253.50 |
02-09-2024, 12:02 PM | #807 |
Rep 258
02-12-2024, 01:29 AM | #809 |
Rep 36
ID7 2022 G82 with a fresh 11/2023.50 software update.
Am I the only one having troubles trying to disable ASD in BimmerCode ? Getting "Coding not possible" in Receiver Audio Module area ... Had no troubles whatsoever on the 03/2023 update. |
02-12-2024, 01:50 PM | #810 |
Rep 2,673
I had this issue before; I'm not sure if the update to Bimmercode has been pushed to non-beta, but I needed to be added to the TestFlight version at some point. You can email the dev and he should add you. Once you update to the TestFlight/beta version it should work.
Zircon21.00 |
02-13-2024, 02:52 PM | #811 | |
Rep 56
Zircon21.00 |
03-02-2024, 10:51 PM | #812 |
Rep 947
ASD FSC code saving failed?
Trying to figure out how badly I've fscked myself.
I used BimmerCode to disable the ASD earlier today, and I was prompted to save the FSC code to Google Drive. I thought that I had done so, but hours later I just noticed that Google Drive is showing that the FSC file is still "Waiting to upload." I do see a 316 byte Code:
FSC_... Am I hosed? (I.e. will I be able to restore the ASD functionality if I were, for some odd reason, to want to?) |
03-03-2024, 06:15 AM | #813 | |
Rep 1,937
gnolivos319.00 |
03-03-2024, 11:05 AM | #814 |
Rep 2,305
Yes.
2001 330Ci (sold)
