04-22-2024, 06:37 PM | #1 |
Rep 507
Jack For Lowered Cars
Could somebody that actually owns a jack that works well with lowered cars please recommend a jack to buy ? I don't want to work under the car. Just high enough to change wheels at home. And bonus points for something small, compact. Thanks.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
04-22-2024, 07:26 PM | #2 |
Rep 7
If you're looking for something to just swap out wheels, check out the Daytona 1.5 ton low profile/low weight (only 36lbs) from harbor freight. (I know HF doesn't have the greatest reputation but the daytona jacks are pretty good, at least in my experience).
https://www.harborfreight.com/15-ton...ump-58811.html |
04-22-2024, 07:55 PM | #3 |
Rep 35
I bought this CAT 3-ton low-profile jack from a local place called Princess Auto, paid $299 CAD for it. It is long and low enough to get to the front and rear center jack points on my M2, at stock height. Would probably need to put a couple of wood boards down to get the car up a bit if it was lowered.
https://www.catpremiumproducts.com/p...ift-floor-jack Very heavy, really well built. It is my first floor jack so I'm not an expert by any means. |
04-22-2024, 07:57 PM | #4 |
Rep 1,345
My car has M-Sport suspension lowered 10 mm compared to basic. That makes 135 mm of ground clearance as I recall.
I started with this OEM kit: https://www.m3post.com/forums/showthread.php?t=1840053. It turned out a complete piece of shit (this may be why they don't offer it any longer). The jack, in particular, withstood only a few (it looks like 4!) seasonal wheel changes (no overloads!): the plastic bushing gave up (when lowering the car after the last wheel was changed ). So I bought PITTSBURGH AUTOMOTIVE 1.5 Ton Low-Profile Aluminum Racing Floor Jack, 60569 (min. height 3-1/2", max. height 14-1/8") in 2015 and I am using it since, twice a year. I am very happy with it. |
04-23-2024, 06:58 AM | #5 |
Rep 177
I got this. I picked it up for a lot more couple years back. It's 275 now.
JEGS Professional Low-Profile 3-Ton Aluminum Floor Jack | 3 ½ Inch Minimum Saddle Height | Lightweight Construction | 360 Degree Rotating Saddle https://a.co/d/aWLNSsM |
04-23-2024, 08:40 AM | #6 |
Loves me some MHD!
1861
Rep 1,722
Fan of the long reach low profile jack, it's nice to reach the center jack points easily
however, the one I have is neither light nor small.... https://www.harborfreight.com/automo...ack-64781.html
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
chris7197353.00 |
04-23-2024, 08:59 AM | #7 |
Rep 1,277
i also use the daytona long reach and i recommend it, but if all you want to do is lift one corner at a time, high enough to change wheels you don't need that. you also don't need the $300 ultra-low profile model, i would just get the regular aluminum low-profile daytona model for ~ $130, it's low enough and it's also only 32 lbs. this one https://www.harborfreight.com/automo...ump-58206.html
Rich150001108.50 |
04-23-2024, 09:12 AM | #8 |
Rep 1,016
If anyone in the Tri State NY area is interested in a AC Hydraulic DK13HLQ, I one one new FS.
That Harbor Freight Bruzenhoil style aluminum jack is nice - maybe for jack points - not sure if it's low and long enough to reach the center jack point on lowered car |
04-23-2024, 09:19 AM | #9 |
Rep 6,301
I guess it depends on your exact car. To reach my center point on my lowered E92 with a lip, I need to bring the car on low profile ramps then jack the front side point with another jack to then reach the central jack point. And that's why my low profile long reach jack.
But yeah as someone mentioned, depends on how you want to do this. Jack one corner at a time? Or do it "properly" with jack stands one axle or all 4 at a time? |
04-23-2024, 09:31 AM | #10 |
Rep 59
Lift from the rear, place axle stand on the front. Then repeat same for the rear.
Can't have all 4 axle stands at the same time but no need for any ramps or other accessories. So you work at the front and then move to the rear. I've been contemplating getting ramps and an extra jack but all in it worked out around £400 + 1 week to deliver and my Intrax 1k2 has just arrived so sod it, I'll do it with what I got. |
04-23-2024, 10:16 AM | #11 |
The Seeker
13942
Rep 3,346
I use this one, but got it for $199 on sale. Not sure I'd pay $324 for it.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-23-2024, 07:06 PM | #12 |
Rep 1,102
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
I have a couple of lowered cars, including a stock 335is. This is the one that works for me:
https://www.harborfreight.com/3-ton-...ack-64781.html |
04-24-2024, 07:12 PM | #15 |
Rep 947
Is there any way to safely remove the wheels on these things without a floor jack? I absolutely do not have the space for one, but not being able to really clean my wheels and calipers is driving me crazy.
04-24-2024, 07:16 PM | #16 |
Rep 6,301
What do you mean? How are you going to raise the car and remove the wheels without a jack/lift?
04-25-2024, 05:01 AM | #17 | |
Rep 366
https://bimmerzone.com/products/afte...-and-tire-iron |
04-25-2024, 09:26 AM | #18 |
Rep 947
04-25-2024, 09:28 AM | #19 | |
Rep 947
04-25-2024, 09:47 AM | #20 | |
Rep 6,301
But yeah if you use a scissor jack you can't really place a stand at the jack point. Instead you can find a spot on the subframe or suspension |
04-25-2024, 04:32 PM | #21 | |
Rep 1,345
Dackelone seems to know how to do it: https://www.1addicts.com/forums/showthread.php?t=835379. |
04-25-2024, 06:37 PM | #22 |
Rep 1,240
That Daytona looks slick, I have the Pittsburg one I use on my 2006 Mustang...
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
