01-11-2024, 07:39 AM | #1 |
Rep 36
Noobie here.
I recently got a 2024 m3 base with p zero tires and am in the process of buying two 20" 825m with Michelin tires. Will any issues be running with 20 " Square (rear wheels)? I know this might sound stupid but is it okay to run Michelin tires in the front and P Zero in the back? (I will replace to the same tire brand in a few months) |
01-11-2024, 11:56 AM | #2 |
Rep 273
Drives: 2023 M3 Comp
No issues running 20” square except for maybe minor rubbing on the plastic fins of the front wheel arches when backing up and turning the wheel. This also depends on lowered height and spacers if used. I currently run 20” squared on m perf HAS and 12mm front and 15mm rear spacers. Should be no issue running 2 separate tire brands but is obviously not ideal.
You can check out images of this and several other members installs by searching the forum as there’s several current threads for this along with how to cure/eliminate the rubbing. |
AiBiasEdi9.50 |
01-11-2024, 12:36 PM | #3 | |
Rep 36
I also plan on purchasing m perf has and having my local performance shop install it. Do you know if I need BMW do install it? Leaning this route because of warranty. Do you mind sharing the the drop height? Is it 10mm/10mm per BMW recommendation? |
Limegrntaln13473.50 |
01-11-2024, 01:26 PM | #4 |
Rep 273
Its a max of 20mm for m perf HAS. Really up to your preference… I’m 20 in rear and 15mm in front. Tons of info here Limegrntaln
https://www.bimmerpost.com/forums/sh...php?p=30803273 As far as warranty goes and this is debatable, your warranty should not be affected whether BMW installs, DIY, or reputable shop so long as it’s correctly installed. My recommendation would be to find a local Independant shop that performs maintenance and service on BMW’s over the dealer just due to pricing, but everyone has their thoughts and opinion on this. I would assume Houston has their fair share of choices compared to where I’m at! |
AiBiasEdi9.50 Limegrntaln13473.50 |
01-12-2024, 04:31 PM | #5 | |
Rep 6,962
Stay away from places like "Tire Queen" or something similar, that operates out of an old gas station, and only sells used tires, and runs out to your car in the parking lot, with a floor jack to change your tires.
YT: G Dubyou |
AiBiasEdi9.50 |
