03-21-2022, 11:30 AM | #1 |
Rep 10,878
IND | Eventuri G8X M3 / M4 Carbon Intake System Released
PERFORMANCE GAIN: 13-18HP, 12-16FT/LBS (STOCK TUNE) Eventuri has pulled the curtain back on their latest masterpiece—their G8X M3 / M4 black carbon intake system. More than its undisputed visual appeal, this new intake promises 13-18HP as a standalone add-on, but also promises to stand up to 1000+hp power hungry builds in the future. This future proofing effort takes an engineering prowess that only Eventuri has been able to deliver. It's a real testament to how much specific attention has been paid to completely re-design the OE intake to achieve their lofty goals. By cleverly maximizing the available usage space in the G8X's engine bay, the Eventuri intake boasts a 40% increase in filtration area over stock as well as a whopping 160% improvement in inlet volume. A NEW BENCHMARK To set themselves even further apart from the competition, Eventuri has created an advanced dimpled inner surface within each turbo inlet. This unique design detail reduces frictional losses between the actual air flow and the wall of the inlet by creating a cushion of air between them. This space allows air to move through the inlet at higher flow rates, thereby delivering more air to the turbos with less effort. This design, coupled with the aforementioned 160% increase in inlet volume, are huge contributing factors to why the Eventuri intake has shown a healthy increase in performance—and why it will continue to do so as the car is tuned. PROVEN PERFORMANCE This isn't the first time we've mentioned performance in this newsletter, but this continues to be an Eventuri trait that has not been repeatable from other competitors. The independent dyno results confirm a consistent power gain throughout the RPM range, while also delivering improved throttle response in real-world usage.
03-21-2022, 12:04 PM | #2 |
Rep 8,033
Drives: 2024 X5 M60i
Looking forward to mine.
Will you guys or Evolve have an install video up soon? Would love to have a video to follow along with for install as this one looks pretty involved.
Limegrntaln13472.00 destoyan521.50 |
03-25-2022, 02:03 PM | #3 | |
Rep 10,878
Eventuri's installation guide was also just made available and does a good job highlighting what you'll need to do.
04-05-2022, 11:19 PM | #4 |
Rep 8,033
Mine arrived this evening. Install scheduled for early next week alongside my Remus exhaust.
The quality of this intake is amazing. Definitely some carbon fiber porn material.
9
Grumpy514624.50 dirtyfreebooter340.50 Joeg80m349.00 iviegatron2542.00 IND-Distribution9586.50 translux481.00 destoyan521.50 mmmaustin30383.00 904_FireG80308.50 |
04-06-2022, 08:31 AM | #5 |
Rep 1,682
Let me know how the intake sounds. Would be nice if you can make a video of it as well.
chicagofan0019147.50 |
04-06-2022, 09:28 AM | #6 | ||
Rep 8,033
04-06-2022, 09:42 AM | #7 |
Rep 1,682
04-06-2022, 10:34 AM | #8 |
Rep 1,075
Be careful with that cross pipe. Get a microfiber towel between it and the radiator during install.
04-08-2022, 08:06 AM | #9 |
driver
816
Rep 777
I decided to prep for the install as my eventuri intakes are arriving later today.
If you are attempting to do this your self make sure you have plenty of time and don't rush. Here are some helpful tips Plug all the holes below with microfiber towels so you don't drop any tools or screws/bolts. To get to the turbo inlets and to remove them is a pain in the ass. The turbo inlet for the driver side intake is especially hard to get to. See pictures below, I had to remove the entire assembly and a total of 5 screws and some sensor plugs. You can use a 6mm (7mm or 1/4 inch can work too) socket. I don't have special tools. See some pictures below and good luck |
04-08-2022, 11:51 AM | #10 |
driver
816
Rep 777
Took about an hour to install and I wasn't rushing
As expected putting back the right side turbo inlet tube was really a pain and specialty tools would be helpful. Still managed to drop one bolt onto the pan but the eventuri kit came with 3 extra (a bit different head but it works). The left eventuri filter is a bit harder to put in and if you can get someone to help you so you don't scratch up the carbon that would be great, as you have to lift the coolant tank up and a bit out of the way in order to fit the filter in. There is almost no wiggle room on this side. Again good luck if you're doing it yourself. It's not complicated just hard to get to This is what it looks like installed Going to try it out |
IND-Distribution9586.50 ROBERT11831569.00 Mowe2456.00 translux481.00 chicagofan0019147.50 Seedster2279.00 destoyan521.50 nptguy116.50 |
04-08-2022, 12:18 PM | #11 | |
Rep 989
IG:F80M3ROB
NEDC member |
04-08-2022, 01:05 PM | #12 | ||
i can haz horsepowr ??
3830
Rep 1,927
Dakar Yellow G80 M3
chicagofan0019147.50 Seedster2279.00 |
04-08-2022, 01:10 PM | #13 |
Rep 989
That was my initial thought too. But I plan on keeping this car long term so I figured I mine as well buy the best of what I can for it. After the $4500 exhaust and Hre wheels whats another $3k for carbon intakes hahaha lol
IG:F80M3ROB
NEDC member |
04-18-2022, 09:04 PM | #14 |
Rep 8,033
Some photos from the day of install.
04-18-2022, 10:05 PM | #15 | |
Rep 6,723
I said the same thing when I got my Eventuri intake for my F80 |
04-18-2022, 10:18 PM | #16 |
Rep 217
Drives: BMW M3 Competition XDrive
chicagofan0019147.50 mmmaustin30383.00 |
04-18-2022, 10:19 PM | #17 | |
Rep 217
coldsteelrain815.50 |
05-20-2022, 06:06 AM | #18 |
Rep 217
Today is a good day. Tomorrow will be better (installation time).
05-23-2022, 01:19 AM | #19 |
Rep 217
Another Twilight Purple with Eventuri
I have an appointment on friday to measure the car on dyno. So I will let you know the results. |
IND-Distribution9586.50 chicagofan0019147.50 dirtyfreebooter340.50 Sbm007613.50 Seedster2279.00 BMWRacer5232519.00 T0RM3NT3642.00 |
05-27-2022, 04:00 AM | #20 |
Rep 217
I got the dyno results. The car got MHtronik from Manhart and now additionaly Eventuri intake.
However: 1. It was warmer today 2. I put additionaly octane booster (for the scond time and the car doesn't work well at high rpm - it cuts). Still: 1. In low range noticably more torque 2. The overboost comes little bit earlier 3. After 6k there is small pump in torque and hp I will test the car without octane booster on the street and will see what time will get. I will try to simulate the same conditions as my best run (10.73 1/4 mile) without Eventuri. |
Sbm007613.50 IND-Distribution9586.50 chicagofan0019147.50 somer966.00 BMWRacer5232519.00 Limegrntaln13472.00 Matt@Evolve1971.50 |
07-26-2022, 07:52 PM | #22 |
Rep 989
Had them installed today. Well worth the money. Fit and finish is unmatched. Sounds awesome.
IG:F80M3ROB
NEDC member |
