04-18-2024, 10:24 PM | #1 |
Rep 19
LAUNCH CONTROL The first gear speed cannot run at full speed
Use 1st gear transmission and then switch to 2nd gear at 4000 rpm. I want to know why it cannot run to 7000rpm
04-19-2024, 02:01 PM | #3 |
Rep 1,936
That's how launch control is programmed, it short shifts into second. But if you brake boost and launch the car normally it'll be slower than using launch control so the short shift is beneficial and whatever else bmw programed into it.
04-19-2024, 02:25 PM | #4 |
Rep 336
Someone correct me if I am wrong, but I noticed ever since flashing XHP the early upshift to second does NOT happen anymore. It allows you to spin through first if needed.
04-19-2024, 04:04 PM | #5 |
2022 M4 Comp Xdrive
1019
Rep 1,538
Even in launch control you will reach 7k in first gear.
04-19-2024, 04:48 PM | #6 |
Rep 1,936
Post a video of that.
04-19-2024, 10:00 PM | #8 |
salty cowboys fan
6185
Rep 3,418
Don’t mind the shaky hand and crappy 60ft
04-19-2024, 10:36 PM | #10 |
Rep 19
04-19-2024, 11:04 PM | #11 |
Rep 1,936
What mods? Xhp? My car is stock and it short shifts into second.
04-20-2024, 11:57 AM | #14 |
Rep 336
Yea just stage 3 no other settings changed, I am not running Drag race mode.
I am also flashed with BM3, but I dont think that changed the short shift setting, I am pretty certain it was the XHP trans flash. |
04-20-2024, 12:19 PM | #15 |
Rep 19
Thank you very much for informing us. Also, have you tested a 1/4 mile launch test at this stage
hellcat2m4227.00 |
04-20-2024, 12:25 PM | #16 |
Rep 336
I don't have a road long enough to do a 1/4 hit near me unfortunately. But have done around 20 launches using launch control, and roughly about the same with just foot braking in D3 without launch control.
Also many 60-130 runs (over 250 at this point) |
04-20-2024, 12:46 PM | #17 |
Rep 19
What is your 0-60 launch time? May I know your ins so that I can contact you easily
04-21-2024, 11:48 AM | #20 |
Rep 248
You are spinning hence why the up shift. You’ll either have to put Drag radials on or have your tuner input the proper tq limits in each gear for you. Unfortunately can’t set tq limits in XHP if you are on BM3 custom rom so your tuner has to set it inside the tune. I’ve cut a 2.3 0-60 on stock tires with a 1.52 60ft using LC and limiting the tq in 1st gear
IG Perseus_Actual Performance: DP, Intakes, BM3 Flex Fuel tune By Bend Calibrations Cosmetic: CF front lip, Diffuser, and Spoiler |
