01-12-2024, 07:54 AM | #1 |
Rep 110
Lowest Possible Suspension G80 X-Drive
Hello all! I have a 2022 G80 M3 Comp X-Drive which is currently running the KW HAS kit. I have been running it for almost a year now. Comfort is good, but it doesn't go as low as I would like it to in the front. My front is maxed out and it still is not as close as I'd like. I also noticed on other KW HAS cars.
I am debating on switching to coils. Does anyone know the lowest drop coilover (more importantly lowest in the front) for X-Drive cars? Would like something with good quality as well. Thanks! |
01-12-2024, 11:06 AM | #2 |
Rep 190,807
Ohlins are low
But if you are not tracking the car, you don't need coilovers. You can get adjustable springs instead. AST adjustable and H&R VTF are the best options in my opinion
01-12-2024, 01:48 PM | #3 |
Rep 144
My understanding is the Ohlins require some modifications to be able to go low on the x drive cars.
Also they’re recommended height isn’t really meant for extensive lowering. KW V3 is probably your best bet. Not worth getting another HAS kit. The ast goes a little lower up front but you’ll end up blowing the oem struts |
01-12-2024, 03:06 PM | #4 |
Rep 5,550
HAS systems height adjustment are limited by stock compression travel. You’ll basically be running on the bump stops constantly if you lower front too much. This is the wrong setup if you’re looking to run a low setup.
If you’re looking to go extremely low then BC is your only choice. They are a truly entry level coilover and excel at being able to run ridiculously low. Ride quality is compromised. I’d recommend not using them. If you’re looking to go reasonably low then the KW V3 with 2-way adjustable damping is an option. Improvement in street handling but not a setup for track use. V4 is also available with 3-way adjustable damping but overkill for a street damper. Finally, the V5 is 4-way adjustable and make even less sense for a street setup. Unsure if KW is pushing the V4 and V5 as track coilovers but it’s all marketing bs. KW CS and KW Motorsport are their true track setups. If you’re looking to go functionally low and improve handling then the Ohlins R&T is your best option. Easy to swap spring rates if you add camber plates. Good entry-level track setup. 1-way adjustable (DFV provides small changes in compression with rebound adjustment) dampers. Custom damping available from 3DM and PSI. Moton, MCS and Ohlins TTX 2, 3 and 4 way adjustable dampers if you’re looking for a true track/motorsport damper. Can run them pretty darn low if that’s what you’re looking for. Custom spring rates with a true coilover rear setup option. Moton and MCS can handle a wide range of spring rate whereas Ohlins TTX require revalving for spring rate changes. That captures pretty much every coilover option available for the G8x. Price increase as you move down each option. |
01-15-2024, 07:16 PM | #5 | |
Supreme Allied Commander
3848
Rep 54,378
Drives: F80 M3
01-16-2024, 07:59 AM | #6 | |
Rep 110
