05-01-2023, 07:58 PM | #1 |
Rep 77
G80 xDrive springs install $950?
My shop quoted $950 for HR super sport springs and spacers also alignment installation. Is this a reasonable price or is this too much? And does anyone recommend a shop in NorCal
06-07-2023, 04:24 PM | #2 |
Rep 468
I see no one answered - My m4 comp x-drive needs all four springs. I've ordered Eibachs/20mm.
My trusted local shop = 1000$ without alignment. They are good guys - honest. Clearly have not done this on an M4. They are only guys who are willing to work on my Porsche 968. Then called a well- reputed import/performance alignment/suspension shop in the larger town next to me. They work on everything - but no xdrive m3/4's so far. They want to look before they'll even agree to work on it. "Might take a day and a half" etc. HAS ANYONE w/ an xdrive done this on there own and regretted it?? Lessons to impart?? Thanks... |
06-07-2023, 06:01 PM | #3 | |
Rep 118
I got quote for springs at 2 different location about 150 cheaper then that . VT Motorworks and Performance dynamic |
06-07-2023, 06:47 PM | #4 | |
Rep 1,929
Springs are an easy install, also don't do an alignment right after, wait a few weeks till they settle.
06-07-2023, 08:03 PM | #5 |
Rep 468
06-08-2023, 09:17 AM | #6 |
Rep 190,807
Whats the hourly rate in your area?
06-08-2023, 10:17 AM | #7 |
Rep 6,726
I think Limegrntaln had his done at SVB with alignment for a good price.
My local dealership quoted me $2800-$3000 to install (I supply parts) a MPHAS on Xdrive, so compared to that, your getting a hell of a deal. 🙄 Probably going to just do it myself and get it aligned locally at a great shop for about $120 |
Limegrntaln13477.50 |
06-08-2023, 04:30 PM | #8 | |
Rep 6,962
I think SVB is much cheaper. Like $850 with supplied springs, which also includes alignment. Im happy with my install, they took their time and did a really good job. More than I wanted to pay, and I knew SVB was cheaper. I just had more people referring me to PT.
YT: G Dubyou |
06-09-2023, 06:03 AM | #9 | |
Rep 468
Thanks for advice. I had a good talk w/ owner - I just don't think they've done an M3/4 xdrive. I've collected most of parts, special tools, etc and guess I'll do it myself. Last springs I did (last year) were rear leafs on a 78 Z28 along w/ the front coil springs. ...lol. |
forcefed2567.00 |
06-09-2023, 06:42 AM | #10 | |
Rep 1,929
06-09-2023, 07:15 AM | #11 | |
Rep 468
xdrive (from what I've seen) you have to either disconnect driveshaft and +/- remove strut. Or leave driveshaft connected and for sure remove strut/compress spring, etc. If you know different - please tell me!! Thnx for help. |
06-09-2023, 10:10 AM | #12 |
Rep 6,726
This is a great video that shows the MP HAS but will be similar to what you need to do to just replace springs.
https://youtu.be/PZ94E-Gp0JY Limegrntaln pointed me to this vid. Explains a lot. Pay close attention to around the 7 min mark as he explains how to do it without removing axle nut. Clever. |
06-09-2023, 02:45 PM | #13 | |
Rep 468
06-10-2023, 03:47 PM | #14 |
Rep 208
I would ask them to unpack that by telling you the number of hours they estimate for the job and their hourly rate. It seems a bit high for non-height adjustable springs, even with an alignment.
06-11-2023, 11:00 AM | #16 | |
Rep 468
06-11-2023, 11:15 AM | #17 | |
Rep 6,726
I know a lot of people do not replace TTY bolts. To each their own. |
06-11-2023, 02:12 PM | #18 |
Rep 6,962
The place I had my springs installed, ordered the TTY bolts the morning of the install, and went to the dealer to pick them up. They gave me the old ones in a little bag when I left. Maybe just to show what they replaced.
YT: G Dubyou |
M4Lou415.50 |
06-19-2023, 04:46 PM | #19 | |
Rep 468
So - just did it this weekend past. You do NOT need to loosen the front lower control arm bolts. Also - the front fender liner, is in two pieces. You only need to remove the front. Also, the xdrive axle keeps the lower control arms (on my car) from going too low that it hurt the headlight sensor. I left attached. But check yours. A trolley jack helps. Once lowered, I pulled out boot and bump stop. To get spring out..slipped the top coil off the strut and then uncoiled the spring from around the strut. Spun it. My new coils are Eibachs and the top and bottom coils are tighter to next coil than stock springs. U gotta push it on backwards from bottom of coil. Then spin it and slip top coil over top of strut. The strut hat is in two main pieces w/ a bearing/race in it. Snaps together. On one side mine popped open. Just had to snap back together. Once coil is in w/ upper boot, stop and strut hat back in, jack up slow and guide the strut into hat and make sure coil goes even around the base of the strut hat. It can get off center. Strut bolt is 52ft/lb. The strut hat bolts are tty (good luck). Once you do one side, second side is a breeze. The backs kinda suck more (I have a runway lift - did these on lift, but fronts I did on ground). Tons of youtube videos' to watch. Getting the inside control arm bolts re-centered sucks and good luck w/ torque values. The shock bolt is smaller, hard to believe they both have same torque values. I put on new xdrive Eibachs..super happy. I just didnt' want adjusting stuff on there. Just good springs. Watch the linked video and others before you tackle. It is not hard. |
06-19-2023, 09:42 PM | #20 | |
Rep 6,962
YT: G Dubyou |
06-21-2023, 05:31 PM | #21 |
Rep 16
It's too cheap for this kind of job.
just alignment alone should be about 2 hours charge. installation should be about 4 hours. height adjustment with installation plus alignment , 900ish is way too low for a good job. |
06-23-2023, 12:54 AM | #22 | |
Rep 279
Drives: G80 M3 Comp xDrive
