01-23-2023, 12:37 PM | #45 |
Rep 343
The law changed, but US requirements are still more stringent than other countries. US requires higher refresh and scan rates from anti-dazzle equipment, which differs from other countries, so it may require more than just coding or software from BMW because it seems those requirements maybe beyond current hardware capabilities.
jimbethesda1865.00 thecakeisalie105.50 |
01-23-2023, 04:23 PM | #46 | |
Rep 7,016
Drives: 2022 DG/BLk xDrive M4C Wk 34
https://www.nytimes.com/2022/02/18/b...eadlights.html
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
jimbethesda1865.00 |
01-24-2023, 07:05 AM | #47 |
Rep 924
So I did Bimmercode anti-dazzle and had a drive last night. Most noticeable was the left to right sweeping based in steering angle. Tunneling was not so obvious but the car definitely lit up the sides without oncoming cars, and seemed to light up around the car ahead.
High beams on street signs are obnoxiously bright, and the car seems to know this and switches them off when there are a few bright reflective signs, its actually irritating to my eyes, so I appreciate it. Overall worth the 5 mins it took.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
01-24-2023, 02:35 PM | #48 | |
Rep 47
You did the coding with Bimmercode? What coding did you use? |
01-24-2023, 03:35 PM | #50 | |
Rep 924
https://www.bimmerpost.com/forums/sh...php?p=27650517
2023 F90 M5
DocWeatherington2943.50 BvB190960.00 |
01-29-2023, 02:45 AM | #51 |
Rep 8,364
01-29-2023, 02:57 AM | #52 |
Rep 27
DocWeatherington2943.50 Almaretto2374.00 |
01-31-2023, 02:38 AM | #53 |
///MFlight Member
457
Rep 249
Question about warranty.. If anti-dazzle is coded I assume this will make the brights turn on more than usual. I read on various other threads this can cause the headlights to get hotter than normal. That being said, this would cause the headlights to burn out faster. If you take it to service, BMW will see you coded anti-dazzle so the headlights won't be covered under warranty.
I also saw a YouTube video where a guy coded his X3 to have a different instrument gauge cluster and his BMW service center wanted to void his entire warranty. Do any of you have any factual experience with any of the above?
Current - 2022 M3 G80X Competition/Brooklyn Grey/Silverstone
- 2022 X3 M40i/Brooklyn Grey Sold - 2021 M3 G80 RWD Competition/Brooklyn Grey/Merino Black Follow Me on IG: BrooklynGreyM3 |
01-31-2023, 08:43 PM | #54 | |
Rep 8,364
Dealership does not have ability to see coding changes (only behavior), unless they call in specialist, which would have to prove coding resulted in fault. |
02-01-2023, 08:38 AM | #55 | |
Rep 750
Drives: 22 M4c vert
I tried this after the 7/22 update - all coded successfully, but anti dazzle no longer works. My suspicion: 1DF8 LUT_AFS_CODRV_HOR: G05_Laser_ECE 1DF8 LUT_AFS_DRV_HOR: G05_Laser_ECE In the "base" coding (which i had applied before, and it worked) these values are different: LUT_AFS_CODRV_HOR Laser_US/G007_US standard/init LUT_AFS_DRV_HOR Laser_US F040_G005_AHL/G015_G020_Laser *however* post 7/22 the co-driver whore (sorry, I'm 12) target value no longer exists. It's just laser_us. I re set these 2 values - verified all else is set. Let's see if it works. Will report back tonight. |
FISH225413.50 |
02-01-2023, 08:17 PM | #56 | |
Rep 750
Drives: 22 M4c vert
Unsure if the new coding makes a substantive difference, but it can't hurt? |
02-02-2023, 01:23 AM | #57 | |
///MFlight Member
457
Rep 249
What (if any) difference do you see between the old coding and the new one? Thanks.
02-02-2023, 02:18 AM | #58 | |
Rep 8,364
KKSigs1270.00 Limegrntaln13611.50 |
02-02-2023, 07:50 AM | #59 | |
Rep 750
Drives: 22 M4c vert
I just had a quick drive last night, but even the revised coding is still very aggressive in shutting down the high beams upon street sign reflections |
02-03-2023, 03:06 AM | #60 |
///MFlight Member
457
Rep 249
Could you repost the entire new coding with the values you used to make it work? Based on your comments I wanted to verify that you made this work with the 7.22 update?
02-04-2023, 02:59 AM | #61 | |
Rep 8,364
02-07-2023, 01:37 AM | #62 |
///MFlight Member
457
Rep 249
So I had Steve from "Code My Bimmer" code in anti-dazzle for my 2022 X3 M40i (LED Lights) and my 2022 G80 (Laser Lights). It took him about 20 minutes to do each vehicle. I won't advertise his exact fee for this but I can say he charged me less than $100 per vehicle.
I tested it out and it was amazing to see the lights do their magic. I highly recommend Steve. Communication was great the entire time from start to finish to include appointment confirmation via WhatsApp. Go check him out: https://www.codemybimmer.ca/
02-08-2023, 12:13 AM | #63 |
Banned
6920
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
Just to confirm after this is coded do the hi beams stay on all the time when in the city or is this only when the auto hi beams would normally come on (ie outside the city).
02-08-2023, 01:15 AM | #64 |
Rep 8,364
02-11-2023, 07:15 PM | #66 |
Rep 8,364
Unimatrix074.00 |
