03-06-2024, 05:03 PM | #1 |
Rep 2,067
Hesitation at around 2k rpm
So I’m approaching the 30k mile mark and in the last 2-3k miles I’m getting an odd sensation when I’m just putting around town in efficient/d1.
It’s kind of like a momentary lapse in torque leading up to the 2k mark. There’s no audible stutter sound or anything like that, just a sudden sensation of the power not being there then having it suddenly come back. All in 1/2 a second. I may also be in my head about this part but it seems like the engine suddenly has more power once I’m at the 2.2k mark. Like my foot is in the same position but the car just starts to accelerate a bit harder out of nowhere. I’ve narrowed it down to being between 1.8k-2.1k rpms. It’s also substantially more noticeable while the car is warming up. Could it be spark plugs? Maybe a sensor? It’s a small thing but doesn’t seem right to me. Lmk what you guys think👍🏼 |
03-06-2024, 05:44 PM | #2 |
Rep 851
Could be time for spark plug change. That said, I had this issue after changing out VVTI solenoids on my S4 for non-Audi ones and the cam phasing control was a little on the lazy side for some reason. I was feeling the same sensation you’re describing.
03-06-2024, 06:10 PM | #3 | |
Rep 2,067
I wouldn’t put it past the guys in the bay just skipping that and saying they did it. I’ll take a peek at them this weekend, hopefully that’s it and not a cam position sensor. |
03-06-2024, 08:05 PM | #4 |
Rep 851
Yeah, in my case it was just bullshit Chinese made VVT solenoids. Got them replaced as defective when new and problem went away. I only changed them because the seals were leaking. Putting back originals got rid of the timing out of phase codes, so it was obvious to the parts place I just got some duds or something.
TrentMeister2860.00 |
03-06-2024, 08:08 PM | #5 |
Rep 851
Unless you see the parts list show spark plugs on your receipt or work order, they probably didn’t change them. If you install new ones, get a proper gapping tool and go with .026 on the gap and it should be all smooth if it was stumbly hesitation that you’re feeling.
