08-14-2023, 09:51 AM | #1 |
Rep 7,010
System tire pressure abnormally high
I know I’ve seen this before, but, now it’s happening to me. This is a daily occurrence now. Car is permanently in low tire pressure mode.
The preset pressures are stupid high. The only way this could have changed was with the last software update. Starting to get tired of it. I’m already way over the requested door jamb pressures. Any dealer techs have a solution. Am I bringing it in to get it reprogrammed? Is it part of the software update and I’m stuck with it? Because it didn’t make sense, or I’d be seeing dozens of posts about it.
YT: G Dubyou |
08-14-2023, 05:18 PM | #2 |
Rep 1,943
Think the recommended pressures are stuck in the 100mph+ speed rating, you can change that to the lower one somewhere in idrive and it should be back to 33/38 or so.
Limegrntaln13605.50 |
08-15-2023, 06:09 AM | #3 |
Occasionally frequent poster
3007
Rep 2,745
Change your tire in the settings to something else (as @forcefed mentioned, a tire that is less than 100 MPH will work) and then adjust your pressures how you want them and reset the system.
I run my PS4S at 32 PSI.
Current inventory:
08-15-2023, 08:11 PM | #4 |
Rep 7,010
I’ll check it out. I probably changed it when I changed it back when I took the 1000Ms off. I’ll get in there and change it. I remember messing with it.
YT: G Dubyou |
08-20-2023, 05:50 PM | #5 |
Rep 7,010
Changed it back to <100mph. Message went away within 5 seconds. I actually need to take some air out. When I took my 1000Ms off, and put my 826m back on, I aired them to 34. I guess I need to air down a little.
YT: G Dubyou |
08-20-2023, 08:40 PM | #6 |
Rep 2,387
I just switched to regular PS4's and 20's all around and my pressure is up to 36 psi all around. I swear my car feels better and the bumps are not felt as hard as before. Could it be because of non star tires? I'm definitely enjoying my car more.
Formerly Wyndi335I
