08-18-2022, 10:53 AM | #507 |
Rep 270
I can't seem to get it to work. Does car need to be in Drive? I have my IPhone plugged into USB, had a movie playing via Amazon Prime. For Airplay it should be connecting via the USB port and displaying that for connection on my phone correct? I can hear the movie - but not sure how to display what is playing or what mode from the display I should be on?
08-18-2022, 11:11 AM | #508 | |
You got my money?
3173
Rep 4,657
Drives: Ice Cream Truck
Not sure if you know this, but once you activate the 5 blinker in bimmercode, you then have to go into idrive and check the 5 blinker box to activate it.
08-18-2022, 12:41 PM | #509 |
Rep 270
I didn't know that, but now I have figured it out!!! Works now.
08-18-2022, 12:49 PM | #510 |
BMW DRIVER ///M
106
Rep 317
Yes from what i was told I searched in my g80 and all the items listed exist in the modules listed
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey 2004 E46 M3 White END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci |
08-19-2022, 06:36 AM | #511 | |
Rep 300
08-19-2022, 08:46 AM | #512 | |
Rep 207
08-23-2022, 09:23 AM | #513 |
Rep 57
08-25-2022, 03:04 PM | #514 |
Rep 265
Can you or can you not code out ASD and it actually works with Android without using testflight? Since testflight seems to only be for apple and the Bimmercode can not transfer from Android to apple without paying for another subscription.
I have both phones but I prefer the Android. The main reason for me using bimmercode is to turn off ASD. I will code other items but my main concern is ASD. Also again I want to use the Android not apple lol. Worst case I will have to buy it for apple but people have stated they got the Android to work. Just trying to confirm before I purchase. Thanks. |
08-25-2022, 09:43 PM | #515 | |
Rep 664
Impulse20098386.00 |
08-26-2022, 07:44 AM | #516 |
Rep 265
You heard the difference in the sound? I can definitely tell a lot of the noise is coming through the speakers in my car. From what I understand that it is a instantly noticeable change in sound once it is deactivated.
Thanks.
2021 - X3 M40i Phytonic Blue
2022 - M3 xDrive Frozen Brilliant Metallic White |
Medal484.50 |
08-26-2022, 10:30 AM | #518 | |
Rep 692
On my m340i I still can't tell a difference.
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
08-26-2022, 10:49 AM | #519 |
Rep 265
Eh looks like I'll just go through the apple and testflight to guarantee it works.
08-26-2022, 10:52 AM | #520 |
Rep 692
I did apple and TestFlight. 3 times. Doesn't make a difference to my ears.
08-26-2022, 08:28 PM | #521 |
Rep 3
I had installed a 10" JL and amp tapped into the underseat oem 8" subwoofer signal and the ASD was unbearable. Definitely a huge difference. I really just wanted the exhaust valves opened for the extra burbles...
At first, I wasn't able to code out the ASD using the standard steps but I contacted Bimmercode, sent the logs, and they sent instructions for Android. This method worked great, and no TestFlight needed. 1. Connect 2. SELECT Receiver Module 3. SELECT Activation codes from the menu in the top right corner 4. SELECT the ASD activation code 5. SELECT Deactivate activation code Last edited by quattrings; 08-26-2022 at 08:39 PM.. |
gnolivos319.00 Impulse20098386.00 |
08-27-2022, 01:02 PM | #522 | |
Rep 265
EDIT: I just tried this exact method and THANK YOU. It worked perfectly. The car no longer has ASD working. It is definitely extremely quiet inside the cabin now. I can not believe how much noise was actually coming through the speakers. This made my day lol. Also I was using an android. Pixel 6 Pro for anyone wondering. On android 13. Using the Enet cable and ethernet to usb-c connection.
2022 - M3 xDrive Frozen Brilliant Metallic White Last edited by Impulse20098; 08-27-2022 at 02:13 PM.. |
08-28-2022, 09:02 AM | #523 | ||
Rep 692
08-28-2022, 01:23 PM | #525 |
Rep 605
Finally did it - man superrrrr easy
Also embarrassed to say didn't realize m mode didn't change engine mode settings and found my real car today playing with settings - set m1 to most aggressive settings and wow - there she is! Coded Blue/red ambient lighting for m, currently had orange to match classic bmw color, may go back to this B+O sound Turned off seat belt chime for driver Brighter display - will have to wait til night time to see the difference Five blinks Any other must do's? Waiting on my pry tool kit to install my wireless pad and I understand I'll need some coding for full functionality for that too Reached out to our fellow member to do anti/dazzle - what equipment do I need on my end for him to do it remotely? |
08-28-2022, 06:13 PM | #526 | |
You got my money?
3173
Rep 4,657
You dont need a pry tool to remove the wifi tray. Remove the cup holder rubber bottoms. Unscrew the bolt, pull it up and out.
08-28-2022, 10:28 PM | #527 | ||
Rep 605
BIGW0RM3172.50 |
08-28-2022, 10:41 PM | #528 |
Rep 664
