04-14-2024, 04:30 AM | #1 |
Rep 235
Drives: 2012 335is, 2018 M5, 2003 M3,
m3 comp Xdrive ok to run 2 different sets of tires?
Wondering if it would be a problem running a differnt set of tires on the front compared to the rear. I found a good deal on some used pilot sport cup 2's and wondering if it would be a problem or throw off the awd system with having Pzeros on the front. Thanks
FBO 335is + Carbon Goodies
04-14-2024, 06:51 AM | #2 |
Rep 391
The circumference of the same size tires from different manufactures varies... so it is feasible that if you have Xdrive if might play havoc and ultimately cause a reduced power fault.
Secondly, the amount of traction to the road's surface could make the car believe it is loosing traction at a wheel and DSC and traction control step in to help a problem that might not be there. |
mathys202.50 |
