12-07-2022, 04:15 PM | #1 |
Rep 33
Michelin Cup 2 after 5 track days
Pretty sure it was from running in the cold at COTA for 3 days in Nov., temps around +/- 40.
Then followed by 2 days at MSR houston, warmer temps, but not hot. As well a few chilly mornings in the upper 30's as a daily driver, the tires are only 2 months old. Running camber plates at -3.2 and KW HAS. Obviously going to back off the camber. Opinions? Thoughts? |
12-07-2022, 10:05 PM | #2 |
Rep 7,008
Wheew, spicy. Thunderhill is an hour from my house. This is what keeps me from going, weekly.
YT: G Dubyou |
12-08-2022, 12:54 PM | #3 |
Riding the knock sensor
2413
Rep 1,605
Drives: 21 X5MC | 23 M4CSL
Check hot temps across the tire with your next set and back off camber until temps even out inside to out. It's also possible you are over driving a bit causing understeer rather than getting the car rotated so that outside front can get set.
Limegrntaln13599.50 |
12-09-2022, 12:36 AM | #4 |
6920
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
That's sexy
12-10-2022, 09:42 PM | #6 |
Rep 2,700
I'd second that, definitely some overdriving going here, what is your toe setting 0 ?
12-11-2022, 01:19 AM | #7 |
Όλα ρόδες
760
Rep 561
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
12-11-2022, 08:16 AM | #8 |
Rep 924
The camber and pressure adjustments will help a bit but 5 days is to be expected on a 3,900 lbs front engine car.
12-11-2022, 12:20 PM | #9 |
Rep 2,700
Indeed, on the M4C Vert (4300lbs) I had to replace the front cup2s after 3 days and the rear were shot after 5.
D_SheerDrivingPleasure1100.00 Limegrntaln13599.50 |
12-11-2022, 12:51 PM | #10 | |
Rep 924
It's been Toyo RRs ever since. They are a tad slower but wear great, tolerate heat and cost half the price of most super 200TW tires. You can't street drive them though. |
PLF693770.00 |
12-13-2022, 12:40 AM | #12 |
Rep 14,138
Drives: G82 M4C X-Drive
I'm also running -3.2 on the same tires. Will report if I can make them last longer than 5 days, but honestly, 5 sounds about right.
12-24-2022, 02:43 PM | #13 |
Rep 394
Are you running square setup? I if so what sizes and wheels? I'd like to run a square setup, but having xDrive might make it a little more sensitive to matching circumference..?
12-28-2022, 11:13 PM | #14 |
Rep 33
