06-12-2022, 06:18 PM | #1 |
Rep 655
High Plains Raceway
High Plains Raceway
Open Lapping June 9th 2022 Michelin Cup2 * BMW BMW 963M wheels Millway Camber Plates (Street Version) Motul 600 Brake Fluid Cobalt Race Pads Speed Engineering Brake Duct Cooling System this was my 1st lap without encountering anyone else, 6th lap ever with this car. Obviously much different than the M235iR. the weight is really noticeable coming off the back straight, hitting 140+ and then needing to brake. comparing my best lap with the M235iR (2:08), every corner in the M235iR i took 8-12 MPH faster, so the g80 just point and shoot and its power made up for my poor driving and slow corning, just lack of feel for the car given it was my first time out with it. camber plates + track alignment was almost spot on. some pretty nice even wear on the tires. very happy there. cobalt pads, held up, but i am still unsure of them. compared to the M235iR, the g80 braking was a lot less confidence inspiring. probably just not use to the weight. the brakes run so f'ing hot. i can't imagine the brake temps without the speed engineering duct system. used the following settings: engine: sport+ chassis: sport steering: sport brakes: sport drive: 4wd sport dsc: off once all that was set, i pressed and held the m-mode button for 4 seconds to activate track mode. confirmed that on the idrive. using those settings, i did not have any weird systems come on while driving, no windows up emergencies, etc. other friends i went with had E92 (6MT) with supercharger and m4 gts Last edited by dirtyfreebooter; 06-12-2022 at 06:32 PM.. |
06-12-2022, 06:19 PM | #2 |
Rep 655
now the ugly bits...
car overheated twice. limp mode until i drove some cool downs and then let it sit. brake rotors needed multiple cool down laps, otherwise crazy loud pings from the metal cooling. brakes so f'ing hot. ambient temps were pretty hot outside, like 85F at the start of the session. limp mode once from low fuel (not a big deal), my mistake for just not looking at the gas gauge. finally towards the end of the night, i got limp mode again, any time i accelerated. bunch of errors from bimmerlink. boost pressure, drivetrain. had to stop at this point. going to dealer this week for full diagnosis. Last edited by dirtyfreebooter; 06-12-2022 at 06:39 PM.. |
jmg18710.50 |
06-13-2022, 12:32 AM | #3 |
Rep 290
Nice video!!
Just curious, is yours an xDrive? How long was your session? I was doing 25 minute sessions at the BMWCCA HPDE last month…was also getting the same crazy loud pings from the rotors, though I had stock pads on. Assuming you remove the plastic brake vent covers inside the wheel well with the Speed Engineering system? Definitely agree you really feel the car’s weight at the end of the back straight dropping from 145-ish down to 70-ish. I never got over the pucker factor, though my brakes never let me down once. Looks like you definitely managed tire pressure/wear better than I did. What pressure were you targeting when hot? Only tip I got from my instructor that I’d pass on is to not run the engine setting on sport+. Doesn’t make the car any faster and makes the throttle input more touchy/less smooth. I was noticeably faster/smoother on regular sport. He said same applies to brake setting - sport just makes them more touchy. I was already on comfort and he recommended leaving them there. Hope the error codes are an easy fix…it was a cooler day when I was running out there so I didn’t have any overheating issues…hope that doesn’t become a common thing. |
jmg18710.50 |
06-13-2022, 01:09 AM | #4 | |
Rep 655
yea, will try and back off sport+ for engine next time! i was targeting for pressures around 34 psi hot, but i used the Michelin Connect app, which while is kinda gimmicky, i did notice the stock TPMS was quite slow at updating compared to the connect app. so i targeted whatever the app said, which it basically shows you, too little or too much air, i just dialed it in until i had 4 green squares on the app (which i ran off an old iphone 12 mini) since i was using my primary phone for trackaddict. i am sure over time i could eliminate the connect app and probably will as i will eventually move to more affordable tires, but for first time out, it was nice to not have to think about it and the results in the tire wear speak for themselves. yea, its xdrive, i drove the entire time in 4wd sport, which was interesting, losing grip, its almost counterintuitive to apply plenty of gas to regain grip, letting the front wheels pull you straight.. normally i am used to this: just spinning out. haha. |
jmg18710.50 |
06-20-2022, 05:07 PM | #5 |
Rep 14,115
Drives: G82 M4C X-Drive
What are you track alignment settings? Did you find the connected app to be on par with real world measurements if you took any? I just got a set of cup 2*, and will follow your 34 psi suggestion.
Agreed that sport engine setting is sufficient for track duty. But my EBC Bluestuff gives better feedback in sport braking for some reason. Maybe it's compound dependent.
06-20-2022, 07:30 PM | #6 | |
Rep 924
Your tires look like they got overheated. You should keep them below 180 in tpms and do cool downs when they climb over 180. Also 34 hot is too high in my experience they get greasy at that pressure and I wonder if your awd masked it. Based on your tread picture If definitely say you were overdriving the tires. You definitely want to cool the brakes before coming in. Last lap should be slow enough to not touch the brakes. The ting ting sound will become a loud crack eventually of you don't. Your overheated situation is unnerving. I have driven in 95+ texas heat on track and never had an overheated car other than the brake heat warning, which I haven't had since doing brake ducting. G82 is definitely not an endurance platform as is…needs close management of temp windows to stay in high performance. I agree on brakes I dont use sport braking..too grabby. But never felt like my brakes weren't there, I also moved from hard threshold braking to a early progressive squeeze style, and find I dont get as squirrelly in the rear. These are my new cups after 4x30 min sessions.
2023 F90 M5
06-24-2022, 04:07 PM | #7 |
Rep 655
long story short, one of my turbo's seized. dealer was able to get a replacement ASAP as 1 was available in the USA from parts warehouse. BMW germany was involved. they wanted the turbo shipped back to them. there will be no further info on the actual failure. tech said he couldn't see anything obvious, other than it was seized up.
things seem normal now. heading back to HPR end of july, will certainly be watching things more carefully, but honestly, i know this isn't an endurance car, but overheating and limp mode stuff was happening 3-5 laps into a session, so like more than 15 min of driving tops, ~2 min per lap.. thanks for all your feedback though, definitely some new stuff to try out next time around. i think i will be more ready to deal with the weight, as i think driving the m235iR prior, i was having a hard time breaking some of my habits from that car's agility, grip, and braking. |
06-24-2022, 04:27 PM | #8 | |
Rep 655
yea, normally i certainly do run 1-2 laps cooldown, but when your car is going into limp mode and you can't go > 50 mph and 3800 RPM, you can be a danger on the track, so i would come off and drive around the back parking lot for 5 min, lol. i noticed the pinging just when i stopped in the hot pit to let out pressure, but now i realized, maybe i should have done a cool down lap before even hot pitting. also first time out with a big heavy car with tons of power, so was also just getting used to these new track behaviors. should be a lot better 2nd time around, and hopefully no turbos blow up. |
06-24-2022, 07:49 PM | #9 | ||||
Rep 924
2023 F90 M5
06-24-2022, 09:30 PM | #10 | |||||
Rep 655
06-25-2022, 12:18 AM | #11 | |
Rep 290
06-25-2022, 10:38 AM | #12 | ||||||
Rep 924
2023 F90 M5
08-03-2022, 10:56 PM | #13 | ||
#Driver
373
Rep 418
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan insta: gtsdaddy |
Tags |
high plains raceway, track day |
