06-14-2021, 03:56 PM | #46 |
Rep 158
06-14-2021, 04:16 PM | #47 |
Rep 679
I see you are in Seattle, why not hit up Cantrell or Truline in Bellevue to help dial in alignment. They are good at setting up for track etc.
06-14-2021, 04:25 PM | #48 |
Rep 158
Thanks for reply and recommendation. I was actually referring to initial spring height adjuster settings for a 1" front drop and .25" rear drop. Was hoping Imran@Evolve would have some suggestions.
06-14-2021, 04:34 PM | #49 |
Rep 679
Great question, I am installing mine tomorrow and plan to set the adjusters to the max height and then use calipers to measure 30mm for front ant 25mm for rear on my first go. I will do fender measurements pre and post and let you know.
FITM3NT542.00 |
06-14-2021, 04:42 PM | #50 |
Rep 158
Awesome! Thanks in advance for sharing this info.
06-14-2021, 04:51 PM | #51 | |
Rep 10,169
I know some that lower, that like to keep the drops static front and rear which keeps the gaps slightly different.
06-14-2021, 04:57 PM | #52 |
Rep 679
I am gonna go 5-10mm lower in the front. I want it to be slightly more raked/or equal. I will probably do with 5mm first, drive it for a 100 miles and if I am happy, then I will go ahead and get it aligned.
06-14-2021, 07:00 PM | #53 | |
Potato peeler
542
Rep 208
If it's not too much to ask, could you please take a few pics and measurements of where you set the height of the spring? I'm assuming that max top setting would be stock for both front and rear and you would adjust the height lower to preference. Would just like to confirm my assumption to avoid readjusting after the first try. Edit: hadn't read the rest of the thread before I commented. Thanks!
2021 Brooklyn Grey G80 M3
2015 Mineral Grey F80 M3 | 2014 Glacier Silver F30 335i M-Sport | 2006 Jet Black E46 M3 | 1999 Arctic Silver E36 M3 |
06-14-2021, 07:26 PM | #54 | |
Rep 679
06-14-2021, 07:30 PM | #55 |
Rep 1,740
You're gonna have to measure the drop from the center of your wheels to the fender top. Don't measure from the adjusters. They will also settle so I would aim for a higher drop initially. Good luck and take some pics for us
06-14-2021, 10:45 PM | #56 | ||
Potato peeler
542
Rep 208
06-15-2021, 09:55 AM | #58 |
Rep 3,789
Guys - wind the adjusters down to max lowering then measure up from there.
Testing with Bilstein Damptronic - if and when they release we will for sure. |
06-15-2021, 12:00 PM | #59 | |
Rep 10,169
on the rear is it like the F8X where you dont need to go into the trunk area?
06-16-2021, 06:09 PM | #60 |
Potato peeler
542
Rep 208
Springs just arrived, a few more weeks until my car is delivered.
06-18-2021, 08:41 AM | #61 |
Rep 3,789
06-18-2021, 08:44 AM | #62 |
Rep 10,169
My bad i meant for MSS?
06-18-2021, 08:49 AM | #63 |
Rep 3,789
Our G80 with 20/21 6Sixty Wheels and MSS HAS kit.
06-18-2021, 04:18 PM | #65 |
Rep 158
Did you do your install and how did it go? Pics please?
06-19-2021, 09:35 AM | #66 |
Rep 679
The install was super easy so if a shop quotes you at 500+ in the Seattle area, they are charging too much.
We ran into a problem were the fronts did not lower much at all when the adjusters were set to the lowest setting. Going to wait if it settles a bit and go from there. We will be adjusting the rear height on Sunday as the rear is sitting too low for my taste. Once I have the heights dialed in, I will take measurements of the adjusters gaps so people can refer to that. |
