04-16-2023, 06:31 PM | #45 |
Rep 145
I have fond memories of driving my Golf R on twisty back roads. I loved the feeling of slingshotting out of tight corners and feeling the push as soon as you dip into the throttle. The g80 is close, but hitting that sweet spot is sometimes harder. G80 is an absolute rocketship though. I really notice the difference on an on ramp. Golf R didn’t have much pull once at highway speeds. G80 feels like barely begun stretching it’s legs before I have to let off because going too fast.
04-20-2024, 05:52 PM | #46 | |
Rep 495
04-20-2024, 10:20 PM | #47 |
Rep 5,497
Drives: 23 X7 40i; 23 M3; 24 cooper s
He tried. The car wouldn't allow him to shift at certain points. It's a torque converter auto not a DCT so you don't truly have 100% control over the shift points.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
04-20-2024, 10:31 PM | #48 | |
Rep 1,439
For the S58, they dropped the compression ratio way down to 9.3:1, which means as an "NA engine" it makes very little power. But that low CR also means you can pile on an incredible amount of boost. ~19psi in the base and ~25psi in the comp layers a ton of power on, especially at higher revs. But you have to ask for it. Unlike the B58, it's not "just there" right off idle. So how do you make it feel quicker? You've got three pedals, one of them is a lot larger than the others and is attached to the floor. That should help. If you need more than that, definitely look at a tune. |
FaceBiter194.50 |
04-20-2024, 11:50 PM | #49 |
Rep 1,001
Flash the DME, end of story. Anyone purchasing a base model to save money and get the same engine at a lesser cost I would think has the intention to flash the DME. If you’re auto, also do the CSL flash/coding to the rest of it and you won’t be complaining any more.
04-21-2024, 12:01 AM | #50 |
Rep 66
Drives: BMW M4 Competition
Remove isolation, put windows down, will feel like that R. 😊
