04-11-2023, 03:48 PM | #1 |
Rep 31
How to Make the Car FEEL Quicker
My G82 6MT overall has been great so far. Great cornering, AEWSOME top end, the engine just keeps on pulling even at well above highway speed. There is, however, a problem. At say 35mph, if I floor the car in second gear, the rev just shoots up way too fast and I don't really get the sensation of a 470hp car. To me honestly it doesn't really FEEL that much quicker than the Golf R I had a few years ago although it is in fact a lot quicker.
Looking for advices on how to best feel the car's acceleration at semi-legal speeds. Thanks. |
04-11-2023, 04:21 PM | #2 |
6921
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
Buy a comp
13
MmmmmM22598.00 Limegrntaln13623.50 ScullyD5165.50 M4CompConv/X7482.50 ottm354.00 DO4441410.50 GixY2K519.00 suffer101.50 static_void968.50 Ram_Rx165.50 GolfCoyote692.50 Needsdecaf6835.50 xvicx9412.00 |
04-11-2023, 04:23 PM | #3 |
Rep 382
Just do a fetmo unlock with bootmod3 ots tune. Completely transforms the car. Auto is for girls.
LuckyBrand1440.00 Laguna01///M31400.50 Tall Tom Cruise1012.00 Nkr151124.50 Alvinmark12668.00 sbgolfer222195.50 jbirb305108.00 |
04-11-2023, 04:37 PM | #5 |
6921
Rep 3,276
It was a joke
04-11-2023, 05:32 PM | #6 |
Rep 31
04-11-2023, 06:08 PM | #8 |
Rep 610
Only options are:
1. Not sure what the top speed is in first, but maybe try taking off in 1st gear around 4K - 4.5K rpms? 2. Get a tune Generally speaking, I'm excited about having to work for the speed a bit. Revving out a car to redline and feeling the power and speed build is what makes for a great driving experience in my opinion, especially in a manual. I'd much prefer that than flat power delivery such that there is no visceral reward from revving it all the way out to redline. |
04-11-2023, 06:20 PM | #9 |
Rep 620
I’m confused. You mentioned that RPM shoots up way too fast when you floor it. Doesn’t this mean you’re accelerating hard? Or are you saying you’re just spinning?
I have a 6MT as well and I never had the feeling that this thing needs more power. Maybe I’m getting old 😂😂😂 As long as you don’t lug your engine, this thing is a rocket ship, relatively speaking especially if you want to keep your license. If you want to feel the power, set it with Sport+ and keep the RPM above 3K. |
04-11-2023, 06:35 PM | #10 |
Rep 5,497
Drives: 23 X7 40i; 23 M3; 24 cooper s
Not sure there's much you can do outside of tuning. 2nd gear is the sweetspot to maximize acceleration while still being at stay out of jail speeds. The s58 generally lives in the higher revs and higher speeds as torque builds more progressively. In fact you'll get much more of a torquey sensation from the b58 in the m340i in the lower speeds. But... no manual option there...
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
04-11-2023, 06:50 PM | #11 | |
Rep 31
04-11-2023, 06:54 PM | #12 | |
Rep 31
wtwo318066.00 |
04-12-2023, 08:18 AM | #13 |
Rep 294
Drives: 2013 Focus ST, 2022 M3Cx
Very much willing to say this is because I'm used to driving faaaaaaaaaaaaar lesser cars...but when I pin mine in 1st or 2nd (which is an xDrive, to be fair) it's borderline dizzying. To my perspective, at least, it just...becomes fast. It's bonkers.
Very much agree with the "jailbound" comments. I want to drive it for an extended period in something more than a straight line and in the top half of 3rd gear but that's...not wise. Need to find a track, but I'm too skrrrd. |
04-12-2023, 09:50 AM | #14 |
Rep 402
Easiest way to make the car feel faster is to drive something slow for a few weeks. Every spring when my fun car comes out of hibernation it always feels real quick, but that only last for like a week until I get used to the speed again. You could also just tune it and it will feel fast, but as well you will get used to the speed real quick.
04-12-2023, 10:14 AM | #15 |
Rep 742
If you are not talking about losing traction, and sounds like you're not, then yeah you need some sort of tune to be able to just punch it from lower rpms in 2nd and feel the acceleration you're looking for. Alternatively, if you take first to redline and keep boost up by shifting quickly (but still smoothly, and CDV delete really helps here) it will really pull hard in 2nd. Can also try brake boosting in 2nd at slightly lower rpms, but I've found that not to work quite as well as I had hoped.
I had similar thoughts when car was stock. Now with JB4 traction in 2nd is the problem, so trying to burn up the stock pirellis ASAP and get stickier tires for this summer. |
04-12-2023, 10:24 AM | #16 | |
Rep 272
Valvetronic V2 Cat Back, CS Flash. -VPC Delivery Day. |
04-12-2023, 10:50 AM | #17 | |
Rep 5,497
If anything turbo lag is better mitigated with the manual because you have more control over the gears... which is why Randy Pobst posted a better lap time at VIR with the 6MT vs. the 8AT. The 8AT was refusing to downshift at a critical corner, costing it time on exit. What OP is talking about is the availability of low-down torque - and that's an inherent "issue" in the S58 regardless of 6MT or comp trim. Torque with this motor is naturally more progressive, so you don't feel the traditional down-low pin to your seat sensation that turbo-charged cars are typically known for. Yes, there's an obvious difference in torque between the 6MT and the comp model (no denying the extra 70 lb-ft), but if you're expecting that push you back into your seat at low speeds feeling similar to what you might get from the b58 in the m340i.... neither the 6MT nor the comp model will give you that. These cars live in the top end, because on a track, that's what makes power delivery more predictable and manageable.
04-12-2023, 12:03 PM | #18 | |
Rep 31
DO4441410.50 |
04-12-2023, 12:08 PM | #19 | |
Rep 31
I guess what I'm trying to convey is that I kinda wish the car doesn't rev so quickly. I drove my friend's gt350 one time and that car also only wakes up at high rpm but (I don't remember if it revved slower or it was because of the extra 2000 rpm vs. our cars or both ) that car gave me time to feel the power before I had to shift. |
wtwo318066.00 |
04-12-2023, 12:53 PM | #20 |
Rep 1,335
the rotation of the engine is physically connected through the transmission to the wheels of car, if the car revved slower it would BE slower, it's not like the speed at which the engine RPM increases is some separate thing that can be altered.
i will say though that having both a 6MT and a comp xdrive G80, the comp does feel quite a bit faster even though my 6MT measures faster (stock vs modded at the moment). I'm not exactly sure what creates that sensation, probably a combination of things which have mostly been mentioned already. |
04-12-2023, 12:56 PM | #21 |
Rep 256
What you seem to be looking for is taller gearing to have it rev slower. That would mean less low end torque though and an even more gradual build of power. I used to have a golf r as well and it was a little punchier in the mid range (not as much as a gti with its baby turbo) but definitely doesn’t have the high end power of s58. I think maybe you need to shift your mindset of what you are looking for in power delivery. Basically coming to appreciate power building. It’s different and I like it more. Way more satisfying than a hit of power that dies off a the top
04-12-2023, 01:23 PM | #22 | |
Rep 31
