08-06-2022, 07:06 AM | #23 | |
Rep 290
With an extra 5mm of clearance you’ll have a nice safety factor. |
12-21-2022, 09:55 PM | #24 |
Rep 691
This thread needs a bump because it’s helpful in determining offsets.
I have a question on why everyone jumps to a 11” rear when only adding 10mm more tire? With the 285 on 10” front it would take a 305 on 11” to keep the same sidewall stretch. But people end up on a 295 to prevent rubbing. IMO a 10” front 285 and 10.5 rear 295 is almost square with the same sidewall flex. But I haven’t seen it posted. |
12-21-2022, 10:49 PM | #25 | |
Rep 373
I already have a bit of a hypothesis that the car would handle better with less front tire. I’m working on my summer wheels now and I’m thinking I’ll keep 9.5/10.5 and run 265/285. Everyone rushes to go wider without thinking about whether or not it’s going to actually improve the car IMHO. It’s different on AWD cars obviously but for a RWD performance car to only have a 10MM difference front/rear is bizarre to me.
2023 G80 6MT | Tartufo Full
12-22-2022, 05:32 AM | #26 | |
Rep 39
12-22-2022, 09:22 AM | #27 |
Rep 691
12-22-2022, 09:46 AM | #28 |
Rep 33
I have been searching and i think iam going to run the following specs below. Still working on the offsets. This will give me the same od as factory, so should be good.
20x10 F 285-30-20 Conti 20x11 R 295-30-20 Conti |
12-22-2022, 10:48 AM | #29 | |
Rep 691
You're only adding 10mm wider tire with 25mm wider wheel. I need to look up some good sidewall pictures to see if the 15mm more stretch is noticeable from front to back. |
12-22-2022, 11:15 AM | #30 |
Rep 378
The 11" rear wheel is primarily for looks. It does make a visual difference. I will be ordering BCs 20x10 and 20x11 too. The front and rear tire will only be 10mm wider than OEM. This is for looks alone. Of course the added contact patch would not hurt traction but it is minimal.
12-22-2022, 10:27 PM | #31 |
Rep 39
Skyscraper2212.50 |
01-08-2023, 11:09 AM | #32 | |
Rep 691
01-09-2023, 09:46 PM | #33 | |
Rep 1,837
Skyscraper2212.50 |
01-09-2023, 10:06 PM | #34 | |
Rep 373
Broader point was about people arbitrarily putting much wider tires (front and rear). It wasn’t super clear.
01-12-2023, 01:20 AM | #35 |
Rep 167
My M3 Comp RWD:
20x10 ET12 285/30/20 20x11 ET14 305/30/20 Perfect fitment with AST Springs, no rubbing and is the absolute perfect look. |
01-14-2023, 03:04 PM | #36 |
Rep 924
01-15-2023, 12:53 AM | #37 |
Rep 39
Hopefully that works. Haven’t posted on here before.
RM73343.50 playswcars3648.50 VELGEN WHEELS236.50 OEM31592.00 AhsanU3838.50 JDUNITNOW3559.50 modeno85.00 Kev.k12.00 |
01-16-2023, 11:41 AM | #39 |
Rep 707
The wheel color combo is superb. One of my favorite wheels.
03-04-2023, 11:02 AM | #40 |
Rep 87
This is a good thread.
I just ordered some custom wheels somewhat using your chart to figure out offsets. Keeping the stock tires, too many potholes in the Bay Area ca. Artis Forged Wheels 19x9.5 et7 20x10.5 et5 |
03-15-2023, 02:22 PM | #42 |
Rep 286
Hey guys looking to order a set of wheels. What offsets should i do if i want the most flush fit to the fender. Doing 20" up front and 21" in the rear. Does this make sense:
20" x 10" with ET12; Michelin PS4 285/30/20 21" x 11" with ET14; Michelin PS4 295/25/21 This tire ratio gives me OEM ratio. Was thinking going 285/30/20 and 305/25/21 but that gives me ration of 1.1%. Don't want to push it Currently on my stock wheel/tire setup I'm running 18mm spacer up front and 15mm in the rear. Slight rubbing in the front on full steer but I can tolerate that. Last edited by PMW0801; 03-15-2023 at 02:41 PM.. |
03-17-2023, 04:54 PM | #43 | |
Rep 90
03-17-2023, 05:04 PM | #44 |
Rep 286
I heard the same but I’m worried about the 1.1% ratio. The running I’m not too concerned with. I’m running 18mm spacer up front with some rubbing in reverse on full lock. Other than that it’s fine.
