08-04-2023, 05:16 PM | #727 |
Rep 57
Drives: BMW M3 Comp xDr
Hey chris3g. You helped me out with my ASD a month ago or so. Thanks again. Anyway, you're saying it can't be done with Bimmercode, yeah? Or are you of the position it cannot be programmed at all?
08-04-2023, 05:22 PM | #728 |
Rep 2,049
08-04-2023, 06:00 PM | #729 |
Rep 1,280
I don’t think it will ever be in bimmercode, afaik there is not any coding variable for this. BimmerLink (sister app to bimmercode) supports flap control but it doesn’t work on the g8x platform - if they figure out the correct commands it will be in BimmerLink. Also you would need to do it every time you start the car.
The flaps are easily controlled via ecu tune but you need to be unlocked. |
08-04-2023, 06:30 PM | #730 | |
Rep 18,848
08-04-2023, 06:59 PM | #731 |
Rep 57
tom @ eas I understand that valves r only partially open in idle while in sport & plus. However, they open 100% at full throttle in sport and plus. Ie, they don't stay at a particular % open for each mode; they do open 100%. Additionally, you can code them 100% all the time as well as revise the mapping to open at various throttle levels. I know it can be done with bootmod3. I just want to be able to do it with Bimmercode. But the consensus thus far is "not yet"
08-04-2023, 08:14 PM | #732 |
Rep 229
Somewhere on the forums, it was reported that the sound difference between the max software open and full zip tied open wasn't discernable. Would take a db meter to be certain, but seems possible full software open is just dandy.
08-04-2023, 09:38 PM | #733 | |
Rep 258
Needsdecaf6723.00 thatguyM4206.50 |
08-04-2023, 09:51 PM | #734 | ||
Rep 18,848
https://g80.bimmerpost.com/forums/sh...php?p=30170455 Quote:
09-19-2023, 10:02 AM | #735 |
Rep 2,717
10-04-2023, 10:48 AM | #736 |
Rep 649
I actually switched mine to MINI. I prefer the blinker sounds of the MINI but prefer the default BMW PDC tone
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels |
11-30-2023, 11:30 AM | #737 |
You got my money?
3186
Rep 4,664
Drives: Ice Cream Truck
Any updates to disabling the single yellow LED light in the headlights?
wavyyyy1045.50 |
12-03-2023, 07:22 PM | #738 |
Rep 941
12-03-2023, 08:45 PM | #739 | |
Rep 2,049
You are talking about DME level stuff that cannot be done with BimmerCode. BM3 is very different from BimmerCode |
12-04-2023, 09:27 PM | #740 |
You got my money?
3186
Rep 4,664
I think I read somewhere that we will need esys or whatever its called to do that.
12-13-2023, 11:00 AM | #741 |
Rep 180
OEM exhaust flaps cant be coded at this time I've tried so many different ways and it cant be done through coding - The way the exhaust flaps work in the G80 series is variable engine control with doesn't open fully unless your wide open race track mode - On the normal operating and this has been proven time and time again they dont open fully and stay open at 100% - you will need a valve controller that is why I hard wire my exhaust valves with aftermarket exhaust flap controllers to stay open at 100% all the time or closed when ever I want to to be quiet in my neighborhood ... I am working on the exhaust sport button to fully open at a 100% all the time and close when i want to - this required a more in dept wiring but works 100% with the factory Exhaust Flaps to fully Open not partially but fully at 100% all the time - I'm working on so many projects right now but getting them done and released to the public
12-13-2023, 11:06 AM | #742 | |
Rep 180
J_Supplanter59.50 |
12-13-2023, 11:12 AM | #743 |
Rep 180
very familiar with the Awron exhaust flap controller using the steering wheel button but what if we could us the exact button it was intended to the exhaust button - I'm working on that currently and will release it to the public
AlfonsM3.00 GolfCoyote629.50 |
12-14-2023, 12:18 AM | #744 |
Rep 1,462
Drives: 2023 G81 M3 Touring
Coded in the front DRL menu toggle and disabled the boot up nag screen the other day, can't believe it took me this long to do it 😆
12-14-2023, 07:48 AM | #745 | |
Rep 6,749
I will try these instructions and see if I can get it to connect first time. One thing I love about the cable is that it codes the car so quickly. |
12-14-2023, 08:14 AM | #746 | |
Rep 6,749
In the video notes, he posts: Bronze bytes: 18,19,20 23,24,25 28,29,30 Lilac bytes: 78,79, 80 83,84,85 88,89,90 Blue bytes: 48,49,50 53,54,55 58,59,60 I want to understand correctly: The three sets of numbers correspond to the three areas of the car mentioned above. So if you want a multi-colored combination, you would change, let's say: 18,19,20 - To one set of color hex numbers 23,24,25 - to another set of color hex numbers 28,29,30 - to a third set of color hex numbers Do I have that correct? Also, do we have a full list of what Bytes correspond to all the colors listed in the iDrive picker? Thanks. |
12-14-2023, 10:25 AM | #747 | |
Rep 2,670
Needsdecaf6723.00 |
12-14-2023, 05:43 PM | #748 | |
Rep 14,122
Drives: G82 M4C X-Drive
I posted a clearer explanation here: The definitive BIMMERCODE guide for custom AMBIENT LIGHTING It's a bit outdated as I haven't tested it on newer versions of iDrive though.
Needsdecaf6723.00 Berzerker3006.50 |
