01-19-2023, 12:01 PM | #1 |
this is the way
18467
Rep 8,589
BMW M: How to customize your M setup (featuring Frozen Black M3 Touring)
Featured on BIMMERPOST.com |
01-19-2023, 02:36 PM | #2 |
Rep 14,147
Drives: G82 M4C X-Drive
It's the same method in the iDrive7. Here's a tip: When you have a setup you like, hold down the M1 or M2 button and it will set it to that button's memory.
01-20-2023, 09:06 AM | #3 |
Rep 5,204
Is there a way to make the M1/2 button also bring up the sport/track dash…I can’t figure that out.
01-20-2023, 09:09 AM | #4 |
Rep 53
Will someone explain what the up down button on the shifter knob for my m3 does specifically? What do the 3 adjustable levels represent?
Seems different from engine and transmission as those options don't change on the setup screen when I adjust from 1 to 3? |
01-20-2023, 09:09 AM | #5 |
///M-Thusiast
3689
Rep 957
Drives: '23 X5 M50i
No longer possible in iDrive 8. I looked everywhere.
Current: 2023 G05 X5 M50i xDrive
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i |
01-20-2023, 09:12 AM | #6 |
Rep 5,204
That and the stupid radio/preset list disappearing to what’s playing instead of keeping the list up makes me mad.
Edwardsc1255.50 sbgolfer2221121.00 |
01-20-2023, 09:15 AM | #8 | |
///M-Thusiast
3689
Rep 957
Drives: '23 X5 M50i
The radio thing however is a setting you can turn off. In the radio menu, hit right on the iDrive Controller until you see the options. Turn off "Full Screen".
01-20-2023, 09:30 AM | #9 |
Rep 5,204
Thank you…of course it would be under radio settings and not display settings. I can hear them lecturing me now about how I’m using the radio, not the display.
01-20-2023, 09:33 AM | #10 |
Rep 1,184
Drives: 2022 M340i Mineral Grey
Transmission setting. How aggressive you want the shifting.
Present: 2022 M340i Mineral Grey
Past: 2019 330i, 2012 Evo X GSR |
01-20-2023, 09:53 AM | #11 |
Rep 53
01-20-2023, 01:17 PM | #12 |
///M4
51
Rep 149
They should have mentioned the transmissions settings on the auto stick and the M-Mode button
Instagram: @Dracula.M3CX
Current BMWs: '23 M3CX, '23 X7 Previous BMWs: '21 X7, '19 M4 CS, '20 X7, '15 M4, '18 X3, '17 X5, '17 X1, '06 325i, '02 M3, '03 330i ZCP |
01-20-2023, 01:26 PM | #13 |
Rep 5,204
Is it not poasible to have odometer mileage and trip be permanently displayed on the bottom below the gauges? That seems so absurd.
01-20-2023, 09:33 PM | #15 |
Rep 1,184
I think it only does when turning off the vehicle. Otherwise you need to scroll through the tach menu.
