12-29-2021, 08:58 AM | #1 |
Rep 862
Drives: 2021 BSM G80 comp
Possible Interference with radar detector?
Is anyone having any issues with their radar detector going off , mostly laser false alarms. I have V1 mounted with a blendmount. Could there be any sensors causing it ? Or my radar is broken.
2021 G80 Comp
12-29-2021, 09:07 AM | #2 |
Rep 7,997
Drives: 2024 X5 M60i
I believe I've read on here previously that this is due to the gesture control. Probably need to play around with the placement of the radar detector and find the sweet spot for it.
12-29-2021, 12:59 PM | #3 |
Rep 862
I turned off gesture control a while ago before Installing the radar. But i notice it happens sometimes and then randomly will work normal. Must be when it moves slightly up or down.
2021 G80 Comp
12-29-2021, 03:26 PM | #4 |
Rep 568
I have a v1 gen 2 also mounted w/ blendmount. I had to program it to deactivate the rear laser warning, not sure what was setting that off because I turned off gesture controls.
12-29-2021, 03:46 PM | #5 |
Rep 1,237
It’s the gesture control, turning off the feature doesn’t disable the emitter. If you physically cover it, the laser falses will stop.
chicagofan0019077.00 |
12-29-2021, 04:21 PM | #6 |
Rep 862
Makes sense. Thanks
2021 G80 Comp
12-30-2021, 07:37 AM | #7 |
Rep 1,107
Anyone have another brand of detector (besides Valentine) where this is happening? I have an Escort 360 Max and am curious if this will potentially affect my car when it comes in.
12-30-2021, 09:27 AM | #9 |
Rep 862
Don't think you can turn off the rear laser on the V1 gen 1. Gen 2 perhaps you can
2021 G80 Comp
12-30-2021, 10:20 AM | #10 |
Rep 1,237
You really shouldn't need to turn anything off, Is this happening all the time for you ? I have a v1 gen2 and blendmount and the only time I get the false rear laser is when i put my hand up near the detector, which is rare. Try adjusting the mount and the detector so that it is pushed as far forward as possible.
12-30-2021, 01:16 PM | #11 | |
Rep 862
2021 G80 Comp
01-02-2022, 07:02 PM | #12 | |
///M ♥ Recycled Dinosaurs
3190
Rep 1,774
Drives: BMW M4, BMW X5 45e
For the OP: I have both the V1 gen1 and the V1 gen2 in cars with gesture control, both blendmounted. Neither of them beep unless I raise my hand up to near the gesture control emitter and that causes some IR to land on the V1. Work on your V1 positioning. You don't need to upgrade to the gen2 if you already have a newer V1. I have both and can't say that the gen2 is particularly spectacular or anything. It looks newer, sure, but the gen 1 is not bad looking.
01-16-2022, 11:52 AM | #13 |
Rep 121
01-16-2022, 12:47 PM | #14 |
Rep 6,587
Just put black tape over the gesture laser sensor. Gesture control is dumb anyway.
Delmoney335908.50 |
01-16-2022, 01:32 PM | #15 |
Rep 754
Drives: 2022 M3 Competition
I have gesture control enabled and there are no laser false alarms with my R7.
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
01-19-2022, 09:33 PM | #18 |
Rep 321
Where do I put the tape on?
01-20-2022, 04:06 PM | #19 | |
Rep 1,107
01-20-2022, 04:13 PM | #20 | ||
Rep 321
01-21-2022, 03:57 PM | #22 | |
Rep 321
